Re: My validatorV2 extension disables XML source validation [message #786097 is a reply to message #785407] |
Mon, 30 January 2012 01:20 |
On 1/28/2012 7:19 PM, John Ruud wrote:
> I'd like to add XML editor source (as-you-type) validation for my own
> xml based content type ("xml2"). However, contributing the
> org.eclipse.wst.validation.validatorV2 extension as shown below seems to
> disable source validation for the original org.eclipse.core.runtime.xml
> content type (and it doesn't work for my xml2 type either).
> Normal batch validation still works for both xml and xml2. Source
> validation clearly stopped working because no red squiggly lines are
> drawn for invalid <tag></tag2> elements (for example) when editing xml
> or xml2 files using the WST XML editor. I'm using Eclipse JEE/Indigo SR1:
> <?eclipse version="3.4"?>
> <plugin>
> <extension
> point="org.eclipse.core.contenttype.contentTypes">
> <content-type
> base-type="org.eclipse.core.runtime.xml"
> file-extensions="xml2"
> id="validator-test.xml2"
> name="XML2"
> priority="normal">
> </content-type>
> </extension>
> <extension
> id="id1"
> name="name"
> point="org.eclipse.wst.validation.validatorV2">
> <validator
> build="true"
> class="org.eclipse.wst.xml.core.internal.validation.eclipse.Validator"
> manual="true"
> markerId="org.eclipse.wst.xml.core.validationMarker"
> sourceid="org.eclipse.wst.xml.ui.internal.validation.DelegatingSourceValidatorForXML"
> version="3">
> <include>
> <rules>
> <contentType
> exactMatch="true"
> id="validator-test.xml2">
> </contentType>
> </rules>
> </include>
> </validator>
> </extension>
> If I remove the source validator entry
> (sourceid="org.eclipse.wst.xml.ui.internal.validation.DelegatingSourceValidatorForXML")
> from my plugin.xml then source validation starts working again for the
> normal xml content type (but obviously not for my own content type).
> Has anybody been able to get source validation to work for their own XML
> based content type? DelegatingSourceValidatorForXML seems to stop
> working properly after it's been re-contributed. Source validation
> *mostly* works if I remove the validatorV2 extension and instead
> manually add my content type to: Preferences + Validation + XML
> validator + Settings, while there has been a couple of times when that
> stopped working as well (and I needed to remove and then add them back in).
A few things to try:
1) Don't borrow the XML Problem marker type, use your own. The
Validation Framework will not be able to manage them properly if they
come from more than one validator.
2) Don't associate your batch validator with an unrelated source
validator. You're confusing the framework.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: My validatorV2 extension disables XML source validation [message #827040 is a reply to message #826945] |
Thu, 22 March 2012 20:28 |
olivier pod Messages: 3 Registered: March 2012 |
at first, I didn't try to manually associate the validators as I didn't initially considered to override any existing implementation (I just want the exactly same behaviour as the XML, but for my own content-type which only differs from the XML content-type by the file extension).
(By the way, I'm not sure of what you mean when you ask "Do your validators work if you manually make the associations ?").
So, I just tried to "duplicate" as many contributions needed for the XML content-type, but for my own specific "XML-like" content-type to get the same functionalities (problem marker, sourcevalidation and ValidatorV2 as far as I remember).
For now, all functionnalities work for XML and only the "as-you-type" validation doesn't work for my content-type.
Now, I'm trying to figure out why it doesn't work by debugging the WST validator framework by comparing the call stacks/code calling tree between an editor on an XML file and another one on my own content-type.
I think I'm not far of a solution by declaring a sourcevalidation contribution and a ValidatorV2 pointing on a Validator class which default internal validator ID is pointing on the Validator markerId value. I'll detail a little bit more this particular point tomorrow from work.
Regards and sorry for the long post.
FUDForum. Page generated in 0.03464 seconds
