Home » Newcomers » Newcomers » Error after installation: warning: sun.rmi.activation.execPolicy
Error after installation: warning: sun.rmi.activation.execPolicy [message #90963] Sun, 31 July 2005 10:49
Originally posted by: mrapattoni.entelesis.com
Ok, I downloaded Eclipse 3.1 last night, installed it and walked my way
through
the introductions, downloaded the SWT examples, and on running any of them
get an activation error message.
Searching eclipse.org on the pertinent terms returns hits only on the
message
included below, which is the same error that I am seeing. Unfortunately, it
doesn't
look like there was any real resolution...
Could someone please help?
Mike
>Aron replied:
>James, I've never seen this error, but am writing just so you don't feel
>all
>alone ;-) Have you been able to run any project at all? Even a "hello
>world!" one? If so, uh, *shrug*; else, it could be an installation issue
>(though there's not much "installation" involved in unzipping the
>distribution!), and a reinstall may help.
>Regards,
>--A
>>"James" james.dixon@xxxxxxxxxxxxxxx> wrote >> Hi
>> I'm a newbie to Eclipse. UI have set it up, and it seems to be running
>> well - until I try and execute the project I am working on. I get the
>> following message:
>> Activation.main: warning: sun.rmi.activation.execPolicy system
>> property unspecified and no ExecPermissions/ExecOptionPermissions
>> granted; subsequent activation attempts may fail due to unsuccessful
>> ExecPermission/ExecOptionPermission permission checks. For
>> documentation on how to configure rmid security, refer to:
>> http://java.sun.com/j2se/1.4/docs/tooldocs/solaris/rmid.html
>> http://java.sun.com/j2se/1.4/docs/tooldocs/win32/rmid.html
>> I have checked the website as instructed (I am using a Windows OS) and
>> everything seems to be OK. I have run a netstat, and it says that
>> javaw.exe is using port 1098 - I assume this is the process that calls
>> the
>> RMID daemon?
>> Anyway, I've not had much luck getting my projects to run, so any help
>> would be gratefully received!
>> I am running Eclipse 3.0(.02) using j2re1.4.2_06. Am I missing a plug-in
>> or something? It's very frustrating. Grateful for any advice or
>> pointers.
Previous Topic:The only way I can get my java files to build, is to run Clean...
Next Topic:Where to store icons etc & how to deploy them (Java Application)
Current Time: Sun Oct 19 05:00:41 EDT 2025
Powered by FUDForum. Page generated in 0.09710 seconds
