Home » Archived » AMP » Tutorials Problem with Actions Part 2
Tutorials Problem with Actions Part 2 [message #784208] Fri, 27 January 2012 02:43
I was working through the tutorials. I was stumped on this for the Actions Part II tutorial (eclipse.org/amp/documentation/contents/Tutorials.html#Actions_Part_II).
When I did (as best I understood to do) the steps described in the tutorial I was receiving a compiler error in the generated code:
	 * <!-- begin-user-doc -->
	 * Bug Rule Rule. Executed every period.
	 * <!-- end-user-doc -->
	 * @generated
	public void bugRule() {
		Object nextLocation = (Object) ((org.ascape.model.space.Discrete) getStupidModel1()
				.getGrid2D().getSpace()).findRandomAvailable(
				((org.ascape.model.CellOccupant) this).getHostCell(), null,
				false, nextLocation.getStupidModel1().getBugVision());
		if (nextLocation != null) {
			if (getHostScape() != ((Agent) nextLocation).getScape()) {
				die();
				getStupidModel1().getBugScape().add(this);
			moveTo(((HostCell) nextLocation));
The error being caught was "The method getSimpleModel1 is undefined for the type Object"
Simply modifying the
nextLocation.getSimpleModel1().getBugVision()
to
fixed the problem, and I was able to then run the model.
I am just wanting to point out this error in the generated code. Is anyone else experiencing this problem? I tried to look around this forum, but there were no results on a search. Google yielded nothing as well.
Mathew Grabau
Previous Topic:Cannot see graph view
Next Topic:Importing external jars for custom code.
Current Time: Thu Apr 24 23:50:21 EDT 2025
Powered by FUDForum. Page generated in 12.94648 seconds
