Home » Eclipse Projects » Memory Analyzer » CompressedOop
CompressedOop [message #784052] Thu, 26 January 2012 21:09 Go to next message
Does MAT support analysis of heap dumps corresponding to hotspot JVM with CompressedOop enabled?
We see significant difference when comparing a heap in yourkit with MAT. yourkit supports reading CompressedOop heap's, need to find out if MAT does and if not, maybe this is the reason for the delta in reported memory consumption.
Re: CompressedOop [message #784346 is a reply to message #784052] Fri, 27 January 2012 06:40 Go to previous messageGo to next message
AFAIK MAT does not currently support compressed oops, but there is a bug for it.
Re: CompressedOop [message #784614 is a reply to message #784346] Fri, 27 January 2012 14:26 Go to previous messageGo to next message
So when viewing a heap dump from a CompressedOop enabled JVM is it fair to say the allocated sizes are incorrect?
Re: CompressedOop [message #786387 is a reply to message #784614] Mon, 30 January 2012 06:00 Go to previous message
The Hprof parser doesn't currently take account of -XX:+UseCompresssedOops
I'm busy doing other things, so this isn't a priority for me at the moment. However, Memory Analyzer is an open source project, so you do have access to the source to make changes. I've put some comments in bug 346317 for how it could be solved. We'd welcome a contribution under the Eclipse Public License for this.
Previous Topic:New tutorial available: an efficient way to detect duplicated/conflicting libs/classes
Next Topic:Import Index Files?
Current Time: Wed Mar 19 00:10:17 EDT 2025
Powered by FUDForum. Page generated in 0.03737 seconds
