Home » Eclipse Projects » Remote Application Platform (RAP) » WidgetUtil.CUSTOM_VARIANT(WidgetUtil.CUSTOM_VARIANT not working)
WidgetUtil.CUSTOM_VARIANT [message #783417] |
Wed, 25 January 2012 17:20 |
Sudesh Bulathsinhala Messages: 193 Registered: October 2010 |
I'm applying the following style using WidgetUtil.CUSTOM_VARIANT to mimic a gradient effect on my composite.
composite.setData(WidgetUtil.CUSTOM_VARIANT, "gradient_metal");
and my css file contains the following snippet :
Composite.gradient_metal {
background-image: gradient(linear, left top, left bottom, from(#FFFFFF),
color-stop(100%, #E5EFF9), color-stop(100%, #FFFFFF), to(#E5EFF9) );
The above code snippet was working perfect, until RAP 1.5.
Is this a bug, or am I missing something here in 1.5 ?
Re: WidgetUtil.CUSTOM_VARIANT [message #783427 is a reply to message #783417] |
Wed, 25 January 2012 17:37 |
Ivan Furnadjiev Messages: 2426 Registered: July 2009 Location: Sofia, Bulgaria |
Hi Sudesh,
just checked your code with current CVS HEAD and it's working without
problem. Which milestone are you using? Could you provide a complete
test project that demonstrate the issue?
Best,
Ivan
On 1/25/2012 7:20 PM, Sudesh Bulathsinhala wrote:
> from(#FFFFFF),
> to(#E5EFF9) );
> Regards,
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: WidgetUtil.CUSTOM_VARIANT [message #783438 is a reply to message #783427] |
Wed, 25 January 2012 18:05 |
Hi Ivan,
Thanks for the quick reply as usual from you.
I'm using 1.5 M4 Milestone Build.
I just installed the latest build 1.5M4 and imported our project.
With 1.4 it was working perfect.
I also encountered the following errors in console :
!ENTRY org.eclipse.rap.rwt.testfixture 4 0 2012-01-25 23:26:05.381
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.rap.rwt.testfixture_1.5.0.20110926-1702 [10]" could not be resolved. Reason: Missing Constraint: Import-Package: javax.servlet; version="[3.0.0,4.0.0)"
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1328)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1312)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:323)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1177)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
2012-01-25 23:26:05.469:INFO:org.mortbay.log:Logging to STDERRorg.mortbay.log via org.mortbay.log.Slf4jLog
2012-01-25 23:26:05.530:INFO::jetty-6.1.x
2012-01-25 23:26:05.586:INFO::Started SelectChannelConnector@0.0.0.0:52436
!ENTRY org.eclipse.osgi 4 0 2012-01-25 23:26:08.918
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.rap.rwt.testfixture_1.5.0.20110926-1702.jar/ was not resolved.
!ENTRY org.eclipse.osgi 2 0 2012-01-25 23:26:08.941
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-01-25 23:26:08.941
!SUBENTRY 2 org.eclipse.rap.rwt.testfixture 2 0 2012-01-25 23:26:08.942
!MESSAGE Missing imported package javax.servlet_[3.0.0,4.0.0).
!MESSAGE Missing imported package org.json_0.0.0.
!MESSAGE Missing imported package javax.servlet.descriptor_[3.0.0,4.0.0).
!SUBENTRY 2 org.eclipse.rap.rwt.testfixture 2 0 2012-01-25 23:26:08.943
!MESSAGE Missing imported package javax.servlet.http_[3.0.0,4.0.0).
!ENTRY org.eclipse.osgi 2 0 2012-01-25 23:26:08.948
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-01-25 23:26:08.948
!MESSAGE Bundle org.eclipse.rap.rwt.testfixture_1.5.0.20110926-1702 [10] was not resolved.
!SUBENTRY 2 org.eclipse.rap.rwt.testfixture 2 0 2012-01-25 23:26:08.948
!SUBENTRY 2 org.eclipse.rap.rwt.testfixture 2 0 2012-01-25 23:26:08.949
!SUBENTRY 2 org.eclipse.rap.rwt.testfixture 2 0 2012-01-25 23:26:08.950
Any idea what it could be ?
Sudesh
Re: WidgetUtil.CUSTOM_VARIANT [message #783450 is a reply to message #783438] |
Wed, 25 January 2012 18:31 |
Hi Sudesh,
org.eclipse.rap.rwt.testfixture bundle is only needed to run the RAP
JUnit tests. It's safe to remove this bundle from your launch
configuration. About the theming issue - please provide a complete tests
project that demonstrate the issue. You could test the latest nightly
build as well.
Best,
Ivan
On 1/25/2012 8:05 PM, Sudesh Bulathsinhala wrote:
> Hi Ivan,
> !STACK 0
> "org.eclipse.rap.rwt.testfixture_1.5.0.20110926-1702 " could not
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> was not resolved.
> Sudesh
Ivan Furnadjiev
Re: WidgetUtil.CUSTOM_VARIANT [message #793917 is a reply to message #783450] |
Wed, 08 February 2012 18:40 |
hello Ivan,
i just replaced the following gradient configuration in css and it worked !
not-working
background-image: gradient(linear, left top, left bottom, from(#ffffff),
color-stop(48%, #f0f0f0), color-stop(52%, #e0e0e0), to(#cccccc) );
working
background-image: url("/themes/icons/header_bg.png");
where "header_bg.png" is an image with predefined gradient.
Sudesh
Re: WidgetUtil.CUSTOM_VARIANT [message #793922 is a reply to message #783450] |
hello Ivan,
not-working
working
Sudesh
Re: WidgetUtil.CUSTOM_VARIANT [message #795410 is a reply to message #793917] |
Fri, 10 February 2012 12:51 |
Hi Sudesh,
a I said before, setting Composite background gradient through the
custom variant is working form me. If it doesn't work for you, please
open a bugzilla and attach a simple project to reproduce the issue.
Note: Setting composite background color from a Java code will remove
the background gradient set by theming.
Ivan
On 2/8/2012 8:40 PM, Sudesh Bulathsinhala wrote:
> hello Ivan,
> worked !
> not-working
> to(#cccccc) );
> working
> Regards,
> Sudesh
Ivan Furnadjiev
Current Time: Fri Apr 26 03:12:28 GMT 2024
Powered by FUDForum. Page generated in 0.03648 seconds
