Home » Newcomers » Newcomers » hello world swt
hello world swt [message #783198] Wed, 25 January 2012 04:15 Go to next message
hi;
i am a newcomer to eclipse and i try to study the hello world swt tut but when i run the tut i get the error:
The project: org.eclipse.swt.win32.win32.x86_3.7.1.v3738a which is referenced by the classpath, does not exist.
i don't understand because i have the the project:org.eclipse.swt.win32.win32.x86
in the package explorer
help me please
Re: hello world swt [message #988419 is a reply to message #783198] Thu, 29 November 2012 15:41 Go to previous messageGo to next message
I am having a similar problem:
The HelloWorldSWT tutorial does not work for me.
I am using a brand new out-of-the-box MacBookPro with Retina Display, 13", with i7.
My library is org.eclipse.swt,cocoa.macosx.x86
The following errors appear in the console when trying to compile:
Exception in thread "main" java.lang.UnsatisfiedLinkError: Could not load SWT library. Reasons:
no swt-cocoa-4234 in java.library.path
no swt-cocoa in java.library.path
Can't load library: /Users/Nafty/.swt/lib/macosx/x86_64/libswt-cocoa-4234.jnilib
Can't load library: /Users/Nafty/.swt/lib/macosx/x86_64/libswt-cocoa.jnilib
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:331)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:240)
at org.eclipse.swt.internal.C.<clinit>(C.java:21)
at org.eclipse.swt.widgets.Display.<clinit>(Display.java:101)
at HelloWorldSWT.main(HelloWorldSWT.java:13)
Re: hello world swt [message #988657 is a reply to message #988419] Fri, 30 November 2012 17:10 Go to previous messageGo to next message
The tutorial instructions still leave out adding the SWT jar to the project libraries. Here's one way to do it.
Right click your project, choose Properties.
Select Java Build Path.
Select the Libraries tab and click the 'Add External Jars' button.
Now find your eclipse installation folder, /pathtoeclipse/eclipse, and drill down into the 'plugins' folder.
Find and highlight the org.eclipse.swt.[os].[arch].v4233d.jar file and click OK (or Open as the case may be).
Now you have a referenced libraries entry for the swt jar in your project and you should be able to run HelloWorldSWT.
Here's another way to add the reference - http://www.mkyong.com/swt/how-to-import-swt-library-into-eclipse-workspace/
Re: hello world swt [message #1702280 is a reply to message #783198] Tue, 21 July 2015 05:50 Go to previous message
I resolved this by moving C:\Program Files\eclipse to C:\eclipse
Answer also found here, Eclipse Mars: ANT Task references missing SWT library
Previous Topic:SWT Browser Issue
Next Topic:Which Eclipse Mars for PyDev
Current Time: Mon Jun 16 06:47:08 EDT 2025
Powered by FUDForum. Page generated in 0.46044 seconds
