Re: Item expand to page break [message #782840 is a reply to message #782821] |
Tue, 24 January 2012 14:56 |
Is the report in fixed layout (general report properties)? Did you set
the height of the grid rows?
Jason
On 1/24/2012 9:16 AM, Frizz K wrote:
> I need to put an item A at the bottom of a page, so I thought at a
> item(grid) that cover the rest of tha page to put the item A at the
> bottom of it, but I can expand an item ad I described.
Re: Item expand to page break [message #783026 is a reply to message #782923] |
Tue, 24 January 2012 23:02 |
Can you reproduce the issue with the sample db and post an example that
we can debug? What version of BIRT are you using?
Jason
On 1/24/2012 1:32 PM, Frizz K wrote:
> Fixed layout; I've tried setting the height of previous rows and with
> only one row, but without success
Re: Item expand to page break [message #783362 is a reply to message #783176] |
Wed, 25 January 2012 15:30 |
Take a look at the attached modified sample.
Jason
On 1/25/2012 3:26 AM, Frizz K wrote:
> Jason Weathersby wrote on Tue, 24 January 2012 18:02
>> Jason
> Yes, it's very simply.
> A grid with two rows, the second row has yellow background.
> I want to expand the yellow row height until the end of the page (so I can put the label at the bottom).
> In this sample I'm using 3.7.1, but I have the same beaviour with other versions
Re: Item expand to page break [message #783887 is a reply to message #783801] |
Thu, 26 January 2012 16:56 |
The only way I know to handle this is to use the page footer to display
the label.
Jason
On 1/26/2012 8:52 AM, Frizz K wrote:
> It's not what I want because I don't know how many lines I have in the first row of the grid, so I don't know the height of the first row.
FUDForum. Page generated in 0.04564 seconds
