Re: Profiling JUnit tests Headless to get Code Coverage. [message #96675 is a reply to message #90433] |
Mon, 23 April 2007 11:15 |
Paul Slauenwhite Messages: 975 Registered: July 2009 |
Hi Ravi,
In TPTP, you can use the Method Level code coverage function. Method
Level code coverage is another analysis type for the Java Profiler data
collector in the Profiling launch configuration. For more information, see:
http://help.eclipse.org/help32/topic/org.eclipse.tptp.platfo rm.doc.user/tasks/tevwcode.htm
Alternatively, you can use the Line Level code coverage Technology
Preview. You can learn about the TPTP Line Level Code Coverage tooling
(including
a viewlet) for the latest release at:
http://www.eclipse.org/tptp/home/downloads/downloads.php >> Technology
Preview >> Code Coverage
If you are interested in using the TPTP Line Level Code Coverage tooling
with TPTP JUnit tests, please see the work-around here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=138736#c17
I am not aware of any function in TPTP that allows you to generate
headless reports. However, you could write a service using the Automatable
Services Framework (AS) to reuse the exiting BIRT report templates. For
http://help.eclipse.org/help32/topic/org.eclipse.hyades.test .doc.user/tasks/tlaunching-tests-from-scripts-and-applicatio ns.htm
Paul
"Ravi Roy" <ravi.aroy@gmail.com> wrote in message
news:em3i5p$d6d$1@utils.eclipse.org...
> Hi.
> I have two questions about the code coverage headless and generating the
> HTML reports from trace.trcxml (question about generating HTML reports
> from trace.trcxml have been posted ealier too but I did not get any
> response on the same, I am not sure if this is possible or not in TPTP
> 4.3.0)
> 1.I want to profile the JUnit tests in headless way to get the Code
> Coverage. I am not sure how can I specify the Code Coverage as profiling
> resource in profile / filters.txt, becuase I do not find any documentation
> for the same or any other way exists for the same (which I am not aware
> of).
> 2.How to generate HTML / BIRT Reports from trace data (trace.trcxml) in a
> headless way, I am not sure, if any Tool / Utitlity / Log Analyzer exists
> for the same.
> I appreciate any pointers provided for these questions.
> Regards,
> Ravi.
Re: Profiling JUnit tests Headless to get Code Coverage. [message #96984 is a reply to message #96675] |
Wed, 25 April 2007 11:51 |
Hi Rave,
One correction:
If you are interested in using the TPTP Method Level Code Coverage tooling
Moving forward, we are working at integrating EMMA for line level code
coverage with test execution in TPTP (see defect
https://bugs.eclipse.org/bugs/show_bug.cgi?id=170800). Please feel free to
comment or contribute to this defect.
Paul
"Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
news:f0i4hd$udk$1@build.eclipse.org...
> Hi Ravi,
> see:
> (including
> tooling with TPTP JUnit tests, please see the work-around here:
> Automatable Services Framework (AS) to reuse the exiting BIRT report
> templates. For more information, see:
> Paul
>> Hi.
>> 4.3.0)
>> documentation for the same or any other way exists for the same (which I
>> am not aware of).
>> for the same.
>> Regards,
>> Ravi.
FUDForum. Page generated in 0.06638 seconds
