Home » Eclipse Projects » Plugin Development Environment (PDE) » How to implement Quick Fix / Quick Assist for custom editor?
icon5.gif  How to implement Quick Fix / Quick Assist for custom editor? [message #781144] Fri, 20 January 2012 12:22 Go to next message
I have extended org.eclipse.ui.editors.text.TextEditor to implement a custom editor.
For this editor, I have defined a marker type (org.eclipse.core.resources.markers extension point) and an annotation type (org.eclipse.ui.editors.annotationTypes extension point) to mark specific parts of code in my editor. I use a reconciler to update my annotation model.
Now I want to add a quick fix / quick assist feature. I simply want eclipse, to show a box with proposals, when I hover over an annotated part of the code and replace that part with a given string, when I click on a proposal. Just like the quick fix feature for the java editor.
So, what is the best way to implement this behavior?
I read about marker resolution generators and quick assist processors, but I'm still confused how it all works together...
I would be glad, if someone could point me to the right direction.
Re: How to implement Quick Fix / Quick Assist for custom editor? [message #783193 is a reply to message #781144] Wed, 25 January 2012 04:09 Go to previous messageGo to next message
I finally found out how to get Quick Fix to work for my editor.
I use the annotationTypes extension point to register my own annotation type and the markerAnnotationSpecification extension point to specify the look and feel. In my custom SourceViewerConfiguration class I override getAnnotationHover(...) to return a DefaultAnnotationHover object and getTextHover(...) to return a DefaultTextHover object, so the annotations are shown in my source viewer.
Then I override getReconciler(...) to return a MonoReconciler with my own implementation of IReconcilingStrategy to create the annotations in its reconcile(...) method. And finally I override getQuickAssistAssistant(...) to return a QuickAssistAssistant with my own implementation of IQuickAssistProcessor. The computeQuickAssistProposals(...) method in the processor class computes the quick fix proposals which show up, when I press CTRL+1.
I don't create any Marker objects and don't use a MarkerResolutionGenerator, since the marker concept is much more heavyweight than using only annotations and the functionality which annotations provide fits my needs.
Re: How to implement Quick Fix / Quick Assist for custom editor? [message #1734126 is a reply to message #781144] Sat, 04 June 2016 07:58 Go to previous message
I know this is an old Thread, but can you provide some further details?
Previous Topic:PropertyTester for Classpath Folder
Next Topic:Problem during product configuration
Current Time: Sun Oct 19 19:33:18 EDT 2025
Powered by FUDForum. Page generated in 0.03836 seconds
