Re: Birt Viewer and export OutOfMemory [message #780604 is a reply to message #780440] |
Wed, 18 January 2012 18:15 |
Do you have -XX:MaxPermSize=256m set?
Jason
On 1/17/2012 4:48 PM, kumar alagia wrote:
> I am using the open source Birt Viewer with BIRT report engine 2.6.
> Viewer works fine for a large data set but I see OutOfMemory exceptions
> when I export to Excel (native format emitter from Tribix). Is there any
> parameter in web.xml that can specify that can leverage disk caching or
> some form of caching.
> JVM: -Xms1024m -Xmx1792m
> Number of records are 50k and output report size shouldn't be more than
> 20MB.
> Any suggestion appreciated!
> Thanks
Re: Birt Viewer and export OutOfMemory [message #780871 is a reply to message #780643] |
Thu, 19 January 2012 18:37 |
Are you running this with the frameset mapping and then exporting to
excel. Using the native xls emitter are you getting the memory error?
Jason
On 1/18/2012 4:00 PM, kumar alagia wrote:
> Both -XX:PermSize and -XX:MaxPermSize are set to 256m
Re: Birt Viewer and export OutOfMemory [message #803908 is a reply to message #803763] |
Wed, 22 February 2012 00:46 |
I believe this is an issue with poi currently.
Jason
On 2/21/2012 2:24 PM, kumar alagia wrote:
> Yes, I am using frameset to render HTML report and then exporting to
> Excel. I was directly using tribix native excel emitter. I didnt modify
> the plugin.
> Thanks for the reply.
FUDForum. Page generated in 0.03345 seconds
