Re: Problems with installation of TPTP 4.3 on Windows [message #90069 is a reply to message #89979] |
Wed, 13 December 2006 08:02 |
Asaf Yaffe Messages: 333 Registered: July 2009 |
Sebastian,
What OS/Architecture/Eclipse/TPTP versions are you using?
Generally speaking, the JVMTI Profiler does not officially support Java
6. This enhancement is tracked under Bugzilla
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=148936), feel free to add
yourself to the CC list to track our progress.
Now, let's try to understand what's really going on:
1. Verify that the JVMTI Profiler runtime files are installed in the <AC
Install Dir>\plugins\org.eclipse.tptp.javaprofiler directory. If not,
download and install them from the TPTP 4.3 download page.
2. Edit the pluginconfig.xml file in <AC Install
Dir>\plugins\org.eclipse.tptp.javaprofiler\config directory, and add the
following XML elements directly below the
<Variable name="JAVA_PROFILER_HOME".../> element:
<Variable name="MARTINI_LOGGER_DIRECTORY" position="replace"
value="%JAVA_PROFILER_HOME%\log" />
<Variable name="MARTINI_LOGGER_LOG_LEVEL" position="replace" value="5" />
3. Create a directory named 'log' under
<AC Install Dir>\plugins\org.eclipse.tptp.javaprofiler
4. Restart the Agent Controller, and try to launch the profiler again
from the Eclipse workbench. Then, check the new 'log' directory. It
should contain a log file. Please post the log file here.
5. Optionally, try using different JVMTI collectors (Memory Analysis or
Thread Analysis) and check if they also fail.
Waiting for your response,
Asaf
Asaf Yaffe
Eclipse TPTP Committer, Platform Project (JVMTI Profiler)
Re: Problems with installation of TPTP 4.3 on Windows [message #90420 is a reply to message #90069] |
Sun, 17 December 2006 11:04 |
Sebastian Bauer Messages: 25 Registered: July 2009 |
--------------070604010900010400030905
Asaf Yaffe schrieb:
> Sebastian,
I'm using Eclipse 3.2 on Windows. TPTP is 4.3.0.
I attched the contents, unfortunately it seems to be rather small.
Anything more I could do?
Ciao,
Sebastian
name="MLog01760.log"
Content-Disposition: inline;
filename="MLog01760.log"
Process ID: 1760
Process command line: "C:\Programme\Java\jre1.6.0\bin\java.exe" -agentlib:JPIBootLoader=JPIAgent:server=controlled;CGProf bayesnet.BN
Machine name: THINKY
Type Date Time TID Level Client Message
Informative 12/17/06 11:00:47 3292 0 CJVMTIInterface Using JVMTI
--------------070604010900010400030905--
FUDForum. Page generated in 0.07001 seconds
