Re: Report with RunningCount Throws NullPointerException [message #780409 is a reply to message #779562] |
Tue, 17 January 2012 18:39 |
This does appear to be a bug for the runningcount aggregate. Can you
log a bugzilla request for this? To work around it can you add the
aggregate to the dataset as a computed column. See attached example.
Jasoon
On 1/15/2012 10:47 PM, Arun P Johny wrote:
> I'm trying to create a report with a RunningCount aggregation. The report is working fine when generated with the WebViewer within the report designer. But when the report is exported as a PDF from the designer it throws an NullPointerException as given below.
> Caused by: java.lang.NullPointerException
> at org.eclipse.birt.core.util.IOUtil.writeInt(IOUtil.java:226)
> at org.eclipse.birt.core.util.IOUtil.writeObject(IOUtil.java:674)
> at org.eclipse.birt.data.engine.executor.transform.SimpleGroupCalculator.next(SimpleGroupCalculator.java:233)
> at org.eclipse.birt.data.engine.executor.transform.SimpleResultSet.next(SimpleResultSet.java:562)
> at org.eclipse.birt.data.engine.executor.transform.ResultSetWrapper.next(ResultSetWrapper.java:81)
> at org.eclipse.birt.data.engine.impl.ResultIterator.hasNextRow(ResultIterator.java:584)
> at org.eclipse.birt.data.engine.impl.ResultIterator.nextRow(ResultIterator.java:525)
> at org.eclipse.birt.data.engine.impl.ResultIterator.next(ResultIterator.java:475)
> at org.eclipse.birt.report.engine.data.dte.QueryResultSet.next(QueryResultSet.java:191)
> at org.eclipse.birt.report.engine.executor.ListingElementExecutor.hasNextChild(ListingElementExecutor.java:244)
> at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.hasNextChild(WrappedReportItemExecutor.java:86)
> at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:62)
> at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChildren(HTMLStackingLM.java:26)
> at org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layoutChildren(HTMLTableLM.java:132)
> at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:140)
> at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:70)
> at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
> at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
> at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:180)
> All other report forms like excel, word etc also is throwing the NullPointerException.
> Is it a known issue with BIRT 3.7.1 or Am I doing something wrong? I'm attaching my test case below(A rptdesign file and a xml data file).
> Please help me to solve this issue.
> Thank you.
Re: Report with RunningCount Throws NullPointerException [message #780411 is a reply to message #779562] |
Jasoon
> Thank you.
Re: Report with RunningCount Throws NullPointerException [message #780414 is a reply to message #779562] |
Jasoon
> Thank you.
FUDForum. Page generated in 0.03573 seconds
