Home » Archived » M2M (model-to-model transformation) » Metamodel in workspace in QVTO Problem (Metamodel in workspace in QVTO Problem)
Metamodel in workspace in QVTO Problem [message #779461] Sun, 15 January 2012 15:16 Go to next message
Hi all,
Sorry for my English, I am beginner.
I have a problem with the use of a metamodel in workspace from a QVTO' transformation.
I have defined the following mapping:
<mapping sourceURI="rdbExtended/rdb" targetURI="platform:/resource/rdbExtended/model/rdbExtended.ecore"/>
And this is a piece of my transformation:
modeltype RDB uses 'rdbExtended/rdb';
--IN THIS WAY DOES NOT WORK:
--modeltype RDB uses 'platform:/resource/rdbExtended/model/rdbExtended.ecore';
transformation rdb2rdb(inout model: RDB);
main() {
  model.rootObjects()[RDB::Model]->map model2RModel();
THE PROBLEM IS THAT THE DEBUGGER SAYS THE Set 'model.rootObjects()[RDB::Model]' IS EMPTY, BUT ACTUALLY MY MODEL HAS AN ELEMENT OF TYPE Model.
See the attached image.
index.php/fa/6743/0/
This works if I use:
modeltype RDB uses 'ht..://www.eclipse.org/qvt/1.0.0/Operational/examples/rdb';
Thanks, Regards.
Gustavo.
  • Attachment: qvto.jpg
    (Size: 85.91KB, Downloaded 1064 times)
Re: Metamodel in workspace in QVTO Problem [message #780363 is a reply to message #779461] Tue, 17 January 2012 12:03 Go to previous messageGo to next message
Hi Gustavo
I suspect that you have my 'favourite' problem; meta-model schizophrenia.
You are referencing the same meta-model by two different names and so
you have two distinct copies. You loaded a 'left-hand' Model but are
transforming 'right-hand' Models.
Make sure you only use one of platform: ... or http: ... of file:... to
reference it.
Ed Willink
On 15/01/2012 20:16, Gustavo Bartolomeo wrote:
> Hi all,
> main() {
> Thanks, Regards.
> Gustavo.
Re: Metamodel in workspace in QVTO Problem [message #817876 is a reply to message #780363] Sat, 10 March 2012 15:15 Go to previous messageGo to next message
Thanks Ed,
In this case the problem was the use of dynamic instances.
I built an editor for my local metamodel.
Then create an instance using the editor, and the transformation worked!
Re: Metamodel in workspace in QVTO Problem [message #818148 is a reply to message #817876] Sun, 11 March 2012 01:10 Go to previous message
Hi Gustavo
What you describe is a workaround that works for you.
I am successfully using QVTo for a cascade of transformations without
generating a Java model, let alone a Java editor.
Ed Willink
On 10/03/2012 20:15, Gustavo Bartolomeo wrote:
> Thanks Ed,
Re: Metamodel in workspace in QVTO Problem [message #818153 is a reply to message #817876] Sun, 11 March 2012 01:10 Go to previous message
Hi Gustavo
Ed Willink
> Thanks Ed,
Re: Metamodel in workspace in QVTO Problem [message #818158 is a reply to message #817876] Sun, 11 March 2012 01:10 Go to previous message
Hi Gustavo
Ed Willink
> Thanks Ed,
Re: Metamodel in workspace in QVTO Problem [message #818163 is a reply to message #817876] Sun, 11 March 2012 01:10 Go to previous message
Hi Gustavo
Ed Willink
> Thanks Ed,
Re: Metamodel in workspace in QVTO Problem [message #818168 is a reply to message #817876] Sun, 11 March 2012 01:10 Go to previous message
Hi Gustavo
Ed Willink
> Thanks Ed,
Re: Metamodel in workspace in QVTO Problem [message #818173 is a reply to message #817876] Sun, 11 March 2012 01:10 Go to previous message
Hi Gustavo
Ed Willink
> Thanks Ed,
Re: Metamodel in workspace in QVTO Problem [message #818178 is a reply to message #817876] Sun, 11 March 2012 01:10 Go to previous message
Hi Gustavo
Ed Willink
> Thanks Ed,
Re: Metamodel in workspace in QVTO Problem [message #818183 is a reply to message #817876] Sun, 11 March 2012 01:10 Go to previous message
Hi Gustavo
Ed Willink
> Thanks Ed,
Previous Topic:[QVTo] Standalone execution
Next Topic:Simulink M2M transformation - what is a good approach?
Current Time: Wed Mar 19 06:43:11 EDT 2025
Powered by FUDForum. Page generated in 0.05391 seconds
