Announcement: Subversive 1.1.3 release [message #8096] |
Mon, 16 July 2007 09:19 |
Igor Vinnykov Messages: 61 Registered: July 2009 |
Member |
------=_NextPart_000_0016_01C7C7A3.85852280
Content-Type: text/plain;
charset="koi8-r"
Content-Transfer-Encoding: quoted-printable
Hello Subversive Community,
=20
We are pleased to announce a new release in the 1.1.x stream: version =
1.1.3. Main target of 1.1.3 version is compatibility with Eclipse 3.3 =
and Mylyn. Starting from this version JavaHL becomes the default SVN =
client. This change caused by licensing topics and future project =
transfer to the eclipse.org: previous default client JavaSVN/SVNKit =
doesn't have a license, which allows defining it as default client, =
distributed from the eclipse.org.
=20
Important: Subversive is prepackaged only by JavaHL binaries for =
Windows. If you work under Linux, MacOS or other operation systems you =
should build/install required JavaHL binaries by yourself. JavaHL is a =
part of official Subversion source distribution available at =
http://subversion.tigris.org/project_packages.html.=20
Alternatively you can install and use optional pure Java SVNKit client. =
After SVNKit installation through update site you can switch to it in =
the dialog Window > Preferences: > Team > SVN > SVN Client.
=20
If you use FastTrack, the free tracker plugin for Eclipse, please note =
that FastTrack 1.1.0 is compatible with Subversive 1.1.3. So you can =
just update Subversive if you use FastTrack 1.1.0.
=20
Change log:
=20
Version 1.1.3 [13 July 2007]
=20
Features:
* Add SVN menu and toolbar button (SBV-2501)
+ special thanks to contributor Rene Link
+ special thanks to Marcel Schulte, Daniel Winterstein, Bjorn Schorre
=20
* Add global shortcut keys for SVN actions (SBV-3494)
+ special thanks to Thomas Bayen, Stig Kleppe-Jorgensen
=20
* Support Mylar to Mylyn project name change (SBV-4971)
+ special thanks to Jim Lombardo, Omry Yadan, Nikola Milutinovic, =
Kevin Baughman, Antonel Pazargic
=20
* Check compatibility with Eclipse 3.3.RC3 IDE (SBV-4973)
* Use latest Subversion binaries (SBV-5045)
* Use SVN Kit 1.1.2 binaries (SBV-5035)
* Use open-source JavaMail version (1.4) (SBV-4986)
* Add option to switch off console pattern matcher (SBV-4761)
=20
Fixes:
* Usage of disposed font in the History View (SBV-5048)=20
+ special thanks to Jorg von Frantzius
=20
* Workaround for the deadlock bug in the Eclipse IDE console (194456)=20
+ special thanks to Rafael Chaves
=20
* Remove the annoying dialog of resource history (Eclipse.org, Bug =
#188311)
+ special thanks to Marko Schulz
=20
* NPE in SaveProjectMeta operation (SBV-4871)
+ special thanks to Karl Godel
=20
* Zend Technologies patch: fixes deadlock problem in SVNTeamPlugin =
activation (SBV-4589)
+ special thanks to Zend Technologies
* NPE in SVN Properties when view is disconnected in background thread =
(SBV-4869)
* Negative revision number in Show Annotation operation (SBV-4179)
* BadLocationException in "Add hyperlink to console" operation =
(SBV-4421)
* NPE in "Get File Content" operation on files without extensions =
(SBV-5094)
* Cache incorrectly filled after case-sensitive rename on Windows-based =
platforms (SBV-5100)
=20
Igor Vinnykov
Subversive Team
Content-Type: text/html;
charset="koi8-r"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; charset=3Dkoi8-r">
<META content=3D"MSHTML 6.00.5730.11" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV>
<P class=3DMsoNormal style=3D"MARGIN: 0cm 0cm 0pt"><FONT face=3DArial =
size=3D2>Hello=20
Subversive Community,</FONT></P>
<P class=3DMsoNormal style=3D"MARGIN: 0cm 0cm 0pt"><?xml:namespace =
prefix =3D o ns =3D=20
"urn:schemas-microsoft-com:office:office" /><o:p><FONT face=3DArial=20
size=3D2> </FONT></o:p></P>
size=3D2>We are=20
1.1.3. Main=20
target of 1.1.3 version is compatibility with Eclipse 3.3 and=20
client.=20
This change caused by licensing topics and future project transfer to =
the=20
eclipse.org: previous default client JavaSVN/SVNKit doesn’t have a =
license,=20
which allows defining it as default client, distributed from the=20
eclipse.org.</FONT></P>
<P class=3DMsoNormal style=3D"MARGIN: 0cm 0cm 0pt"><o:p><FONT =
face=3DArial=20
<P class=3DMsoNormal style=3D"MARGIN: 0cm 0cm 0pt"><FONT face=3DArial=20
size=3D2><STRONG>Important</STRONG>: Subversive is prepackaged only by =
JavaHL=20
binaries for Windows. If you work under Linux, MacOS or other operation =
systems=20
you should build/install required JavaHL binaries by yourself. JavaHL is =
a part=20
of official Subversion source distribution available at </FONT><A=20
title= 3Dblocked::http://subversion.tigris.org/project_packages.htm l=20
href=3D"http://subversion.tigris.org/project_packages.html"><FONT =
face=3DArial=20
size=3D2>http://subversion.tigris.org/project_packages.html</FONT></A><FO=
NT=20
face=3DArial size=3D2>. </FONT></P>
size=3D2>Alternatively you can install and use optional pure Java SVNKit =
client.=20
the dialog=20
Window > Preferences… > Team > SVN > SVN =
Client.</FONT></P>
face=3DArial=20
size=3D2>If you=20
use FastTrack, the free tracker plugin for Eclipse, please note that =
FastTrack=20
1.1.0 is compatible with Subversive 1.1.3. So you can just update =
Subversive if=20
you use FastTrack 1.1.0.</FONT></P>
face=3DArial=20
size=3D2>Change=20
log:</FONT></P>
face=3DArial=20
size=3D2>Version=20
1.1.3 [13 July 2007]</FONT></P>
face=3DArial=20
size=3D2>Features:</FONT></P>
<P class=3DMsoNormal style=3D"MARGIN: 0cm 0cm 0pt"><FONT =
face=3DArial><FONT=20
size=3D2><SPAN style=3D"mso-spacerun: yes"> </SPAN>* Add SVN menu =
and toolbar=20
button (SBV-2501)</FONT></FONT></P>
size=3D2> + special thanks to contributor Rene =
Link</FONT></P>
size=3D2> + special thanks to Marcel Schulte, Daniel =
Winterstein,=20
Bjorn Schorre</FONT></P>
face=3DArial=20
size=3D2><SPAN style=3D"mso-spacerun: yes"> </SPAN>* Add global =
shortcut keys=20
for SVN actions (SBV-3494)</FONT></FONT></P>
Link</FONT></P>
size=3D2> + special thanks to Thomas Bayen, Stig=20
Kleppe-Jorgensen</FONT></P>
face=3DArial=20
size=3D2><SPAN style=3D"mso-spacerun: yes"> </SPAN>* Support Mylar =
to Mylyn=20
project name change (SBV-4971)</FONT></FONT></P>
size=3D2> + special thanks to Jim Lombardo, Omry Yadan, =
Nikola=20
Milutinovic, Kevin Baughman, Antonel Pazargic</FONT></P>
face=3DArial=20
size=3D2><SPAN style=3D"mso-spacerun: yes"> </SPAN>* Check =
compatibility with=20
Eclipse 3.3.RC3 IDE (SBV-4973)</FONT></FONT></P>
size=3D2><SPAN style=3D"mso-spacerun: yes"> </SPAN>* Use latest =
Subversion=20
binaries (SBV-5045)</FONT></FONT></P>
size=3D2><SPAN style=3D"mso-spacerun: yes"> </SPAN>* Use SVN Kit =
1.1.2 binaries=20
(SBV-5035)</FONT></FONT></P>
size=3D2><SPAN style=3D"mso-spacerun: yes"> </SPAN>* Use =
open-source JavaMail=20
version (1.4) (SBV-4986)</FONT></FONT></P>
size=3D2><SPAN style=3D"mso-spacerun: yes"> </SPAN>* Add option to =
switch off=20
console pattern matcher (SBV-4761)</FONT></FONT></P>
face=3DArial=20
size=3D2>Fixes:</FONT></P>
size=3D2><SPAN style=3D"mso-spacerun: yes"> </SPAN>* Usage of =
disposed font in=20
the History View (SBV-5048) </FONT></FONT></P>
size=3D2> + special thanks to Jorg von =
Frantzius</FONT></P>
size=3D2> </FONT></P>
size=3D2> *=20
Workaround for the deadlock bug in the Eclipse IDE console (194456) =
</FONT></P>
size=3D2> + special thanks to Rafael Chaves</FONT></P>
size=3D2> *=20
Remove the annoying dialog of resource history (Eclipse.org, Bug=20
#188311)</FONT></P>
size=3D2> + special thanks to Marko Schulz</FONT></P>
face=3DArial=20
size=3D2><SPAN style=3D"mso-spacerun: yes"> </SPAN>* NPE in =
SaveProjectMeta=20
operation (SBV-4871)</FONT></FONT></P>
size=3D2> + special thanks to Karl Godel</FONT></P>
face=3DArial=20
size=3D2><SPAN style=3D"mso-spacerun: yes"> </SPAN>* Zend =
Technologies patch:=20
fixes deadlock problem in SVNTeamPlugin activation =
(SBV-4589)</FONT></FONT></P>
size=3D2> + special thanks to Zend Technologies</FONT></P>
<P class=3DMsoNormal style=3D"MARGIN: 0cm 0cm 0pt"><SPAN=20
style=3D"mso-spacerun: yes"><FONT face=3DArial =
size=3D2></FONT></SPAN> </P>
size=3D2> *=20
NPE in SVN Properties when view is disconnected in background thread=20
(SBV-4869)</FONT></P>
size=3D2><SPAN style=3D"mso-spacerun: yes"> </SPAN>* Negative =
revision number=20
in Show Annotation operation (SBV-4179)</FONT></FONT></P>
size=3D2><SPAN style=3D"mso-spacerun: yes"> </SPAN>* =
BadLocationException in=20
"Add hyperlink to console" operation (SBV-4421)</FONT></FONT></P>
size=3D2><SPAN style=3D"mso-spacerun: yes"> </SPAN>* NPE in "Get =
File Content"=20
operation on files without extensions (SBV-5094)</FONT></FONT></P>
size=3D2> *=20
platforms=20
(SBV-5100)</FONT></P>
face=3DArial=20
size=3D2>Best=20
regards,</FONT></P>
size=3D2>Igor=20
Vinnykov</FONT></P>
size=3D2>Subversive Team</FONT></P></DIV></BODY></HTML>
------=_NextPart_000_0016_01C7C7A3.85852280--
Re: Announcement: Subversive 1.1.3 release [message #8189 is a reply to message #8096] |
Mon, 16 July 2007 14:46 |
Originally posted by: hansm.science.uva.nlDELETE
In article <f7fd6k$kq5$1@build.eclipse.org>,
"Igor Vinnykov" <igor.vinnykov@polarion.org> wrote:
> We are pleased to announce a new release in the 1.1.x stream: version 1.1.3.
> Main target of 1.1.3 version is compatibility with Eclipse 3.3 and Mylyn.
> Starting from this version JavaHL becomes the default SVN client. This change
> caused by licensing topics and future project transfer to the eclipse.org:
> previous default client JavaSVN/SVNKit doesn't have a license, which allows
> defining it as default client, distributed from the eclipse.org.
> Important: Subversive is prepackaged only by JavaHL binaries for Windows. If
> you work under Linux, MacOS or other operation systems you should
> build/install required JavaHL binaries by yourself. JavaHL is a part of
I am sorry but this leaves me in the dark. On the site mentioned above I cannot
find something like a download for javaHL (on MacOSX especially).
Although I did install subversion 1.4.4 from the source distribution I do not
seem to have a javaHL binary. How further?
Hans van der Meer
Re: Announcement: Subversive 1.1.3 release [message #8253 is a reply to message #8189] |
Mon, 16 July 2007 19:10 |
check subversion-1.4.4/INSTALL and
subversion-1.4.4/subversion/bindings/java/README in your source
distribution.
> Hans van der Meer
This space was intended to be left blank.
FUDForum. Page generated in 0.03441 seconds
