p2 installer [message #779005] |
Sat, 14 January 2012 06:23  |
I am not able to find the download URL for the p2 Installer.
The wiki reads like the following,
Get the installer for your platform from the equinox download page. The installer zips are listed under the Provisioning section, once you select your version.
Unzip the installer anywhere on your local disk, eg., /opt/eclipse
Run the p2 installer executable, eg., /opt/eclipse/p2installer
But it ain't working. From where can i download p2 installer?
The wiki says, we can install eclipse via p2, then why the install guide of eclipse doesn't have it contained?
Aravind
Re: p2 installer [message #779379 is a reply to message #779005] |
Sun, 15 January 2012 10:04   |
The p2 installer with UI was considered to be an example. Not sure if it
is maintained and made available in later releases. It never received
much love, and was often broken...
It should be quite easy to write your own - basically UI for what the
director command line app does.
- henrik
On 2012-14-01 12:23, Aravindhan Annamalai wrote:
> Aravind
FUDForum. Page generated in 0.03273 seconds
