| URGENT - Can't open editors after Update to 2.1.1 [message #89628] |
Sun, 06 July 2003 14:21  |
Originally posted by: rhino1.NOSPAM.sympatico.ca
I just tried upgrading Eclipse RC1 from March 2003 to 2.1.1 via Update
Manager. This is the error message that I get when I try to open one of my
source classes for editing:
Cannot open default editor on AdHocBookRequest.java. Unable to instantiate
editor: org.eclipse.jdt.ui.CompilationUnitEditor
java.lang.NoSuchMethodError:
org.eclipse.ui.texteditor.AbstractTextEditor.setKeyBindingSc opes([Ljava/lang
I did these updates via Update Manager. As far as I could tell, the update
processes all worked okay; there were no error messages as such. However,
when the update process ended, there was a warning that said something about
some sort of incompatibility - sorry, I'm afraid I didn't write it down and
don't recall what it said - and it offered me the chance to go ahead or
stop; I think I told it to go ahead. Aside from that, everything seemed to
go fine. I wish I could remember what that warning dialog said....
I can create new classes via the New Class dialog but all that happens is
that the new class is added to my project: the editor never displays it so
that I can add my new code. I've had a look at my source files for both new
and existing classes via the operating system and they seem fine in PFE
(Programmer's File Editor).
How do I get out of this mess? Do I have to run some kind of conversion
utility to reformat my old source files? If yes, where do I get it?
Can I back out this update and go back to 2.1RC? That was working fine; I
just thought I was due for an update so I tried Update Manager for the first
time.
I'm running on Windows XP with all critical service installed.
I would appreciate your help with how to resolve this problem.
Rhino
rhino1 AT sympatico DOT ca
"If you want the best seat in the house, you'll have to move the cat."
| Re: URGENT - Can't open editors after Update to 2.1.1 [message #89721 is a reply to message #89691] |
Sun, 06 July 2003 18:00  |
Saiyajin wrote:
> I've never use the update manager to upgrade eclipse. I just move my
> exesting C:\eclipse folder to my desktop & then unzip the new version to
> C:\eclipse. Then I just add my project into the new version once you run
> eclipse.exe.
Why don't you just use "eclipse -data <path-to-workspace>"?
Stein
FUDForum. Page generated in 0.03679 seconds
