Re: XML URL - no authentication - no User/Password promt ? [message #778412 is a reply to message #778350] |
Thu, 12 January 2012 16:14 |
The xml data source does not handle authentication (Unless you are using
custom code) so this must be coming from the browser?
Jason
On 1/12/2012 9:14 AM, Ralph Soika wrote:
> I have a strange problem with a BIRT Report. The report uses a XML
> DataSource URL from a web server which needs a user basic authentication.
> In the past when I created such a new XML DataSource and click on the
> button 'Test Connection' eclipse prompted me with a username/password
> dialog. Also when I start my report with the menu action 'Run->view
> Report->in Web Viewer'.
> But suddenly this is no longer working. Now I always got an HTTP Error
> 401 (Unauthorized response) and I got no chance to type in my
> username/password?
> Did anybody know about that problem? I don't think that I have changed
> anything in my Eclipse or Server environment. And I have still designed
> different reports. So I know that this worked in the past.
> Thanks for any help
> Ralph
Re: XML URL - no authentication - no User/Password promt ? [message #780416 is a reply to message #780410] |
Tue, 17 January 2012 18:44 |
Have you logged a bug for this yet?
Jason
On 1/17/2012 1:35 PM, Ralph Soika wrote:
> In the meantime I am absolutely sure that the EGit Plugin is responsible
> for that problem. Also my own Plugin (Imixs Workflow Modeler) is
> affected from the EGit behavior. I am now activating/deactivating the
> Egit plugin several times a day :(
FUDForum. Page generated in 0.03580 seconds
