Re: NullPointerException Platform.createFactoryObject [message #778411 is a reply to message #778328] |
Thu, 12 January 2012 16:12 |
Leave the Platform.startup. Are you setting a birt home? If so remove
it. 3.7.1 does not use this variable.
Jason
On 1/12/2012 7:05 AM, Michal Sz wrote:
> Eclipse Java EE IDE for Web Developers.
> Version: Indigo Service Release 1
> Build id: 20110916-0149
> Birt 3.7.1
> I've got java.lang.NullPointerException on:
> engine = factory.createReportEngine( config );
> //...and then second one at line:
> design =
> engine.openReportDesign("C:/Users/ms/Libs/BIRT/birt-runtime-3_7_1/ReportEngine/samples/hello_world.rptdesign");
> I believe it's connected with:
> IReportEngineFactory factory = (IReportEngineFactory) Platform
> .createFactoryObject(
> IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY ); //
> I've commented // Platform.startup( config );
> but it didn't help.
> any ideas, please?
Re: NullPointerException Platform.createFactoryObject [message #779653 is a reply to message #778411] |
Mon, 16 January 2012 09:02 |
Michal Sz Messages: 2 Registered: January 2012 |
but if I leave
I receive:
Quote:Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/core/runtime/CoreException
at org.eclipse.birt.core.framework.Platform.createPlatformLauncher(Platform.java:115)
at org.eclipse.birt.core.framework.Platform.startup(Platform.java:74)
at testBirtEngine.TestBirtEngine.executeReport(TestBirtEngine.java:41)
at testBirtEngine.TestBirtEngine.main(TestBirtEngine.java:124)
Caused by: java.lang.ClassNotFoundException: org.eclipse.core.runtime.CoreException
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
... 4 more
//sorry for delay in communication
Ok, I've found Your solution for that issue - I havent't linked all jars from Engine folder. I cannot give a link to that topic so I'll just said thanks a lot!
[Updated on: Mon, 16 January 2012 09:11] Report message to a moderator
Re: NullPointerException Platform.createFactoryObject [message #780379 is a reply to message #779653] |
Tue, 17 January 2012 17:32 |
Do you have all the libs from the reportengine/lib directory in your
classpath? How are you running this? As a simple Java app?
Jason
On 1/16/2012 4:02 AM, Michal Sz wrote:
> but if I leave Platform.startup( config );
> I receive:
> Quote:
>> at
>> at java.security.AccessController.doPrivileged(Native Method)
>> at java.lang.ClassLoader.loadClass(Unknown Source)
>> ... 4 more
Re: NullPointerException Platform.createFactoryObject [message #780609 is a reply to message #780501] |
Wed, 18 January 2012 18:34 |
With 3.7 do not set BIRT_HOME. Just add the jars to your classpath and
do a platform startup. In 3.7.2 we will most likely offer a POJO
runtime and an OSGi runtime to allow you to choose the way you want to
run BIRT.
Jason
On 1/18/2012 5:45 AM, Deepali Patil wrote:
> I also have same problem.
> I am using Linux-mint
> I have set BIRT_HOME=/home/developer/Birt/birt-runtime-3_7_0/ReportEngine
> public File generateReport(
> final Map<String, String> reportParameters,
> final int reportId, final String outputFormat) {
> IReportRunnable design = null;
> try {
> if(null!=dao) {
> design = reportEngine.openReportDesign(
> reportDesignFolderResolver.getFolder().getAbsolutePath()+
> File.separatorChar +
> dao.get((long)reportId).getName());
> } else {
> return null;
> }catch (Exception e) {
> logger.error(e.getMessage(),e);
> return new File(outputFile);
> I got this exception,
> at
> org.eclipse.birt.report.engine.api.ReportEngine.openReportDesign(ReportEngine.java:126)
> at
> com.sne.reportRunner.reportCreator.ReportGeneratorImpl.generateReport(ReportGeneratorImpl.java:51)
> at
> com.sne.reportRunner.reportCreator.ReportGeneratorImplTest.testThatReportInExcelFormatFileIsGenerated(ReportGeneratorImplTest.java:80)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:45)
> at
> org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
> at
> org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:42)
> at
> org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
> at
> org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
> at
> org.springframework.test.context.junit4.statements.RunBeforeTestMethodCallbacks.evaluate(RunBeforeTestMethodCallbacks.java:74)
> at
> org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:30)
> at
> org.springframework.test.context.junit4.statements.RunAfterTestMethodCallbacks.evaluate(RunAfterTestMethodCallbacks.java:82)
> at
> org.springframework.test.context.junit4.statements.SpringRepeat.evaluate(SpringRepeat.java:72)
> at
> org.springframework.test.context.junit4.SpringJUnit4ClassRunner.runChild(SpringJUnit4ClassRunner.java:231)
> at
> org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:47)
> at org.junit.runners.ParentRunner$3.run(ParentRunner.java:231)
> at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:60)
> at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:229)
> at org.junit.runners.ParentRunner.access$000(ParentRunner.java:50)
> at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:222)
> at
> org.springframework.test.context.junit4.statements.RunBeforeTestClassCallbacks.evaluate(RunBeforeTestClassCallbacks.java:61)
> at
> org.springframework.test.context.junit4.statements.RunAfterTestClassCallbacks.evaluate(RunAfterTestClassCallbacks.java:70)
> at org.junit.runners.ParentRunner.run(ParentRunner.java:300)
> at
> org.springframework.test.context.junit4.SpringJUnit4ClassRunner.run(SpringJUnit4ClassRunner.java:174)
> at
> org.apache.maven.surefire.junit4.JUnit4TestSet.execute(JUnit4TestSet.java:62)
> at
> org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.executeTestSet(AbstractDirectoryTestSuite.java:140)
> at
> org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.execute(AbstractDirectoryTestSuite.java:127)
> at org.apache.maven.surefire.Surefire.run(Surefire.java:177)
> at
> at
> at
> org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
Re: NullPointerException Platform.createFactoryObject [message #780879 is a reply to message #780693] |
Thu, 19 January 2012 18:58 |
I would not copy the birt jars to jvm/lib/ext. Also with 3.7 runtime
download do not set a birt home. Just add the jars from the
reportengine/lib directory to the classpath.
Jason
On 1/19/2012 12:23 AM, Deepali Patil wrote:
> Thanks for the quick reply. I still have a few more doubts.
> Please help me resolve them. I have been struggling with them for a
> while now.
> On Linux-I added all jars in jvm/lib/ext folder it works as expected in
> eclipse, but if I run this through maven it gives same error again. I
> have set CLASSPATH=BIRT_HOME\lib\*.jar
> and in windows-by adding jar's in classpath it neither works in eclipse
> nor in maven.
> on my machine (windows) without adding jars in classpath code is working
> in eclipse as well with maven, I have set
> BIRT_HOME=E:\Programs\birt-runtime-3_7_0\ReportEngine only.
> same I am trying on another windows machine gives same error.
> What is platform startup?
> Just a brief about how we installed BIRT.
> We installed BIRT from Eclipse -> Install new software from the url
> download.eclipse.org/releases/galileo
> then I downloaded the BIRT runtime 3.7.0 and copied this jar files in
> jvm/lib/ext
> Please help me resolve the issue.
FUDForum. Page generated in 0.04222 seconds
