Home » Archived » EGL Development Tools » Delete(Problem when file has two keyfields)
Delete [message #778298] Thu, 12 January 2012 03:13 Go to next message
I have a problem when I try to delete a record in a file with two keys.
---------error----------
[SQL0104] Token G8C5NB was not valid. Valid tokens: OR USE SKIP WAIT WITH.: [sqlstate:42601][sqlcode:-104]
---------record---------
Record G8
{@table{name = "SESQL.SNG8CPP"}}
G8JWNB decimal(6){@ID};
G8C5NB decimal(5){@ID};
G8AUNA string;
end
--------EGL service----------
function deleteG8(delG8 g8 in)
delete delG8 from ds;
end
--------generated Java----------
String stmtStr = "DELETE FROM SESQL.SNG8CPP WHERE G8JWNB = ?G8C5NB = ?";
When I correct the generated Java to:
String stmtStr = "DELETE FROM SESQL.SNG8CPP WHERE G8JWNB = ? AND G8C5NB = ?";
it works fine. I guess this is due to an error in EDT that will be fixed for later releases?
Re: Delete [message #778331 is a reply to message #778298] Thu, 12 January 2012 07:15 Go to previous message
Yes that is a defect. Please open a bugzilla defect for this so it gets fixed and tested. htps://bugs.eclipse.org/bugs/ Please include a link to your forum post, set the component to JavaGen, and put SQL in the summary so the defect gets routed to the correct person.
thanks,
Joe
Previous Topic:EDT 0.8.0 Planning
Next Topic:New blog post - Creating EGL projects
Current Time: Fri Oct 24 09:55:33 EDT 2025
Powered by FUDForum. Page generated in 0.07032 seconds
