Home » Eclipse Projects » Remote Application Platform (RAP) » High CPU load in Safari and Chrome browsers
High CPU load in Safari and Chrome browsers [message #778070] |
Wed, 11 January 2012 06:24  |
I manage a single sourcing product for my company (RCP version worked
prefectly), but in
Environment:
RAP - Nightly build,
(Safari - 5.1.2 (7534.52.7) Mac OS X 10.7.2 or
Google Chrome - 18.0.1003.1 dev-m )
only!!!, lead to high cpu load.
Debugging in shows me that function
_initAutoFlush : function( phase ) {
if( qx.ui.core.Widget._autoFlushTimeout == null ) {
// RAP: Fix for bug 303162
if( !qx.ui.core.Widget._inFlushGlobalQueues
|| phase < qx.ui.core.Widget._flushGlobalQueuesPhase ) {
= window.setTimeout( qx.ui.core.Widget._autoFlushHelper, 0);
called from _autoFlushHelper!, and always sets the timer again and again.
Because parameter phase is _FLUSH_PHASE_JOB(4) < _flushGlobalQueuesPhase
is _FLUSH_PHASE_LAYOUT(5)
_flushGlobalQueuesPhase is set from
flushGlobalLayoutQueue : function() {
qx.ui.core.Widget._flushGlobalQueuesPhase =
qx.ui.core.Widget._FLUSH_PHASE_LAYOUT;
How to break this circle?
PS: Other browsers IE9, and older Chrome worked fine, that is very
strange but is totaly unusable!
Andrew Nesheret
InfiNet Wireless Ltd.
Re: High CPU load in Safari and Chrome browsers [message #778144 is a reply to message #778070] |
Wed, 11 January 2012 08:21   |
Andrew,
I can't reproduce it with Safari 5.1.2 (7534.52.7) and Chrome
17.0.963.26 on Windows (Controls Demo). Did you try it with the same
browsers, but on Windows? Is this high CPU load reproducible with
Controls/Workbench Demo or it is specific to your application?
Best,
Ivan
On 1/11/2012 1:24 PM, Andrew Nesheret wrote:
> prefectly), but in
> Environment:
> _flushGlobalQueuesPhase is _FLUSH_PHASE_LAYOUT(5)
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: High CPU load in Safari and Chrome browsers [message #778430 is a reply to message #778070] |
Wed, 11 January 2012 12:11   |
Hi Andrew.
A stack trace (created with the chrome dev tools in the "debug" variant
of the client library) would really help here.
Greetings,
Tim
Am 11.01.2012 12:24, schrieb Andrew Nesheret:
> prefectly), but in
> Environment:
Re: High CPU load in Safari and Chrome browsers [message #778431 is a reply to message #778144] |
Thu, 12 January 2012 01:02   |
11.01.2012 19:21, Ivan Furnadjiev пишет:
> Andrew,
Yes, this reproducible on Windows too, more over (i wrote before) on
*ANY* browsers i have, but older browser (not load CPU) only follow same
'cyclic' "Set timer pattern"
No, (Controls Demo) worked fine, this only specific to my application.
i'm mean, this began only after my application (one of widget) try to
relayout its parent.
Code like this
org.eclipse.swt.widgets.
Link.setText(<a href=\"dummy\">file.txt</a>);
Link.getParent().getParent().layout( true, true );
or/and my application have some IAction.AS_DROP_DOWN_MENU in toolbar manager
org.eclipse.jface.action.Action.setText( true );
org.eclipse.jface.action.Action.setEnabled( true );
org.eclipse.jface.action.ToolBarManager.update( true );
Andrew Nesheret
Re: High CPU load in Safari and Chrome browsers [message #778433 is a reply to message #778144] |
Thu, 12 January 2012 03:46   |
> Andrew,
> Best,
> Ivan
I'm create a Snipped to reproduce this bug, attached.
Key value to bug is Trailing <space> in Action text.
Run snipped and Press Do It Button to run 'set Timer' circle.
Andrew Nesheret
package ru.infinet;
import org.eclipse.jface.action.Action;
import org.eclipse.jface.action.IAction;
import org.eclipse.jface.action.ToolBarManager;
import org.eclipse.rwt.lifecycle.IEntryPoint;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Group;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.ToolBar;
public class Simple implements IEntryPoint
private ToolBarManager manager;
Action action;
* @wbp.parser.entryPoint
@SuppressWarnings( "serial" )
public int createUI()
Display display = new Display();
Shell shell = new Shell( display );
shell.setSize( 449, 472 );
shell.setLayout( new GridLayout( 1, false ) );
final Composite composite = new Composite( shell, SWT.NONE );
composite.setLayoutData( new GridData( SWT.FILL, SWT.FILL, true, true, 1, 1 ) );
composite.setLayout( new GridLayout( 1, false ) );
final Group leftGroup = new Group(composite, SWT.NONE);
leftGroup.setLayoutData(new GridData(SWT.FILL, SWT.CENTER, true, false, 1, 1));
leftGroup.setText("Left");
leftGroup.setLayout(new GridLayout(2, false));
final Button doItButton = new Button(leftGroup, SWT.NONE);
doItButton.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
action.setText( "None " ); // Trailing <SPACE> is very important to reproduce a bag!!!
manager.update( true );
doItButton.setText("Do It");
final ToolBar toolBar = new ToolBar(leftGroup, SWT.FLAT | SWT.RIGHT);
toolBar.setLayoutData(new GridData(SWT.RIGHT, SWT.CENTER, true, false, 1, 1));
manager = new ToolBarManager( toolBar );
action = new Action("None", IAction.AS_DROP_DOWN_MENU ) {};
manager.add( action );
shell.open();
while ( !shell.isDisposed() )
if ( !display.readAndDispatch() ) display.sleep();
display.dispose();
return 0;
Attachment: Simple.java
(Size: 2.49KB, Downloaded 295 times)
Current Time: Wed Jun 18 11:55:36 EDT 2025
Powered by FUDForum. Page generated in 0.03804 seconds
