Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [ Teneo ] Comments as annotations?
Re: [ Teneo ] Comments as annotations? [message #89487 is a reply to message #89459] |
Thu, 12 July 2007 19:31 |
Hi Jason,
Also in the direct case Teneo will make use of the ecore model, only it is the runtime ecore model
which is build up by the generated EPackageImpl. So I think it should work in both cases.
You can check by getting the hbm by calling datastore.getMappingXML.
I have checked in many changes the last few days. Can you check if you are up-to-date with your changes?
gr. Martin
Jason Henriksen wrote:
> Hi all,
> So I've got my local build to put comments into the hbm file based on the
> <documentation> tags in the xsd/ecore. That's all working nicely and for my
> needs that's enough.
> However, in the default case you don't generate your hbm from ecore
> directly, you just let teneo generate hbm from the class files that are
> present. I haven't found a way to access the documentation in that
> scenario. The data is present in a <!-- begin-model-doc --> section of the
> comment holding the model documentation, but I don't think I there's any way
> to access that at runtime.
> It seems like <!-- begin-model-doc --> would be more useful as some kind of
> @model-doc annotation, though I can imagine that there would be all kinds of
> hassels for someone making that work.
> Am I off-base? Is there some way to access the model documentation at
> runtime when I the user doesn't have ecore handy? If not, then I'm going to
> call this done and package it up for submission. There will probably have
> to be some documentation saying that you must generate from ecore in order
> to get the comments.
> Jason Henriksen
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [ Teneo ] Comments as annotations? [message #89501 is a reply to message #89459] |
Thu, 12 July 2007 19:33 |
Jason,
In EMF 2.3 we added support for the GenModel property "Suppress GenModel
Annotations", which defaults to true. But if you set it to false, the
documentation annotations will be available on the runtime instance of
the Ecore metadata. I.e., you could use
EcoreUtil.getDocumentation(XyzPackage.Literals.MY_CLASS). I'm not sure
if that helps with your problem.
> Hi all,
> Jason Henriksen
Re: [ Teneo ] Comments as annotations? [message #89626 is a reply to message #89501] |
Thu, 12 July 2007 22:04 |
Jason Henriksen Messages: 231 Registered: July 2009 |
Gah!
You told me that before, and since I had set it once before I thought it
must not apply to this.
I had assumed it was an eclipse wide setting, not a per-genmodel property.
Sorry for the wasted time, but at least the comments work with a run-time
generation now!
Thanks for the help,
Jason
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:f75vlr$d26$1@build.eclipse.org...
> Jason,
> > Hi all,
the
for my
the
way
of
kinds of
going to
have
order
> > Thanks,
> > Jason Henriksen
Re: [ Teneo ] Comments as annotations? [message #608729 is a reply to message #89459] |
Hi Jason,
gr. Martin
> Hi all,
> Jason Henriksen
The Netherlands
Re: [ Teneo ] Comments as annotations? [message #608730 is a reply to message #89459] |
Ed Merks Messages: 33142 Registered: July 2009 |
Jason,
> Hi all,
> Jason Henriksen
Ed Merks
Re: [ Teneo ] Comments as annotations? [message #608738 is a reply to message #89501] |
Gah!
generation now!
Jason
> Jason,
> > Hi all,
the
for my
the
way
of
kinds of
going to
have
order
> > Thanks,
> > Jason Henriksen
Current Time: Fri Apr 26 08:26:47 GMT 2024
Powered by FUDForum. Page generated in 0.02481 seconds
