Re: Call XLS Tribix Emitter from Php Java Bridge [message #777487 is a reply to message #777251] |
Tue, 10 January 2012 15:30   |
Karvesh,
Could you try
$taskOptions->setOption("emitterID","org.uguess.birt.report.engine.emitter.xls");
Jason
On 1/10/2012 1:13 AM, karvesh Mising name wrote:
> Dear Jason,
> I have had a look at the documentation of how to call the Tribix emitter
> from the Report API.
> I have followed the steps of placing the jar files in their respective
> locations.
> I came across the code:
> EXCELRenderOption options = new EXCELRenderOption();
> options.setOutputFormat("xls");
> options.setOutputFileName("output/resample/ps.xls");
> options.setOption(IRenderOption.EMITTER_ID,
> "org.eclipse.birt.report.engine.emitter.prototype.excel");
> IRenderTask task = engine.createRenderTask(document);
> task.setRenderOption(options);
> or
> I am wondering how to call if from my php javabridge?
> For the moment I have the following code:
> $taskOptions = new java("org.eclipse.birt.report.engine.api.RenderOption");
> $outputStream = new java("java.io.ByteArrayOutputStream");
> $taskOptions->setOutputStream($outputStream);
> $taskOptions->setOutputFormat("xls");
> $task->setRenderOption( $taskOptions );
> $task->run();
> $task->close();
> Could you please inform me how pass these parameters from php?
> Thanks in advance
> Karvesh
Re: Call XLS Tribix Emitter from Php Java Bridge [message #778402 is a reply to message #777940] |
Wed, 11 January 2012 17:39   |
This is the proper approach. Where do yu have the tribix emitter
installed? What version of BIRT are you using?
Jason
On 1/11/2012 2:34 AM, karvesh Mising name wrote:
> Dear Jason
> I tried it and i get the following error:
> [o:Exception]:"java.lang.Exception: Invoke failed:
> [[o:RunAndRenderTask]]->run. Cause:
> org.eclipse.birt.report.engine.api.EngineException: EmitterID
> org.uguess.birt.report.engine.emitter.xls for render option is invalid.
> VM: 1.6.0_29@http://java.sun.com/" at:
> Any clue why? Thanks
> Karvesh
Re: Call XLS Tribix Emitter from Php Java Bridge [message #893793 is a reply to message #893341] |
Thu, 05 July 2012 14:02   |
Probably the quotes around IRenderOption.EMITTER_ID is the issue.
replace that with "emitterID", with quotes and give it a test.
Jason
On 7/3/2012 11:45 AM, karvesh Mising name wrote:
> Dear Jason,
> I am using BIRT 3.7
> I have tried it again and again but to no avail.. It just does not want
> to work out. Here are my steps (from:
> http://birtworld.blogspot.com/2011/07/replacing-default-birt-xls-emitter.html):
> 1. Download tribix emitters
> org.uguess.birt.report.engine.emitter.xls_2.5.2.201107181644.jar
> and
> org.uguess.birt.report.engine.common_2.5.2.201107181644.jar
> from sourceforge
> 2. Extract the xls emitter file and cut from the folder the files:
> xls-emitter.jar
> lib\commons-jexl-1.1.jar
> lib\commons-logging-1.1.1.jar
> lib\poi-3.7-20101029.jar
> 4. Paste the four files above into WEB-INF\lib together with
> 5. Zip the folder
> org.uguess.birt.report.engine.emitter.xls_2.5.2.201107181644 without the
> cut files into a jar file and copy the modified jar file into WEB-INF\lib
> 6. Finally call the emitter using the API from php:
> $taskOptions->setOption("IRenderOption.EMITTER_ID","org.uguess.birt.report.engine.emitter.xls");
> $task->run();
> $task->close();
> Yet when i export the report to excel, all the data come up fine but no
> images still :(
> I am quite desperate about it now..
> Any clue what i did wrong?
> I really need some kind help here...
> Regards,
> Karvesh
Re: Call XLS Tribix Emitter from Php Java Bridge [message #986871 is a reply to message #893793] |
Thu, 22 November 2012 08:03  |
Kelly Wang Messages: 5 Registered: October 2012 |
Hi, I am trying to do this also. After following the steps mentioned above. Even without set :
The chart image is included in the excel. I guess the engine use the 1st emitter found which happens to be Tribix. (mentioned in the blog post)
Besides this, there is a problem of formatting, the table formatting is not accurate comparing to the default xls emitter.
Anyone has any clue about this?
[Updated on: Thu, 22 November 2012 08:04] Report message to a moderator
FUDForum. Page generated in 0.02268 seconds
