Inject multiple XML records [message #776878] |
Mon, 09 January 2012 12:56 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Sangeeta Tripathy![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=tripathy%40techmahindra.com) Messages: 16 Registered: December 2011 |
Can an XML injection accept multiple XML documents as input? My problem is to correlate multiple XML input documents (based on same metamodel) into lesser number of output XML documents based on some parameters in the input. For this I need to input multiple XML files that need to be correlated to the ATL transformation. How can I do this?
[Updated on: Mon, 09 January 2012 13:20] Report message to a moderator
Re: Inject multiple XML records [message #778262 is a reply to message #778213] |
Thu, 12 January 2012 02:57 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thanks Sylvain,
does that mean that I use Java code to extract the individual XML documents after this step:
4. Target XMI Documents -> Target XML Ecore Documents
Java: Extract individual XML Ecore Documents
5. Iterate: One XML Ecore Document -> One Target XML
When I go throuhg code of the XML Extractor, there is a similiar piece of code in the "extract" function which seems to be doing the same thing (pasted below). Or I am mistaken? I dont mind using Java to extract, but I want to be sure there is no API already existing :
Extract:
public void extract(IModel sourceModel, OutputStream target, Map<String, Object> options)
throws ATLCoreException {
PrintStream outStream = new PrintStream(new BufferedOutputStream(target));
outStream.println("<?xml version = '1.0' encoding = 'ISO-8859-1' ?>");
EMFModel xmlModel = (EMFModel) sourceModel;
EClass rootClass = (EClass) xmlModel.getReferenceModel().getMetaElementByName("Root");
Set<EObject> rootElements = xmlModel.getElementsByType(rootClass);
serializeContent(
rootElements.iterator().next(),
xmlModel, outStream, "");
outStream.close();
Re: Inject multiple XML records [message #778272 is a reply to message #778262] |
Thu, 12 January 2012 05:21 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
It turns out there is a bug in the XMLExtractor code, which I fixed by changing the code as below:
Extract:
//Inserted code
Object eArray = rootElements.toArray();
for (int i=0;i<rootElements.size();i++){
//serializeContent(
//rootElements.iterator().next(),
//xmlModel, outStream, "");
serializeContent( (EObject)eArray[i],xmlModel,outStream,"");
outStream.close();
[Updated on: Thu, 12 January 2012 05:22] Report message to a moderator
FUDForum. Page generated in 0.05204 seconds
