| JFrame not visible [message #89236] | Mon, 02 May 2005 16:27  |  |
| Eclipse User  |  |  |  |  | Originally posted by: schesvo.cs.ndsu.edu
 I am new to eclipse and the visual editor.  When I try and create a new
 java visual class, I select "Frame" from the style window, check
 "Inherited abstract methods" and then click "Finish" which generates the
 following code:
 * Created on May 2, 2005
 * TODO To change the template for this generated file go to
 * Window - Preferences - Java - Code Style - Code Templates
 package testPackage;
 import javax.swing.JFrame;
 * @author Doug Schesvold
 * TODO To change the template for this generated type comment go to
 public class TestGUI extends JFrame {
 private javax.swing.JPanel jContentPane = null;
 * This is the default constructor
 public TestGUI() {
 super();
 initialize();
 * This method initializes this
 * @return void
 private void initialize() {
 this.setSize(300,200);
 this.setContentPane(getJContentPane());
 this.setTitle("JFrame");
 * This method initializes jContentPane
 * @return javax.swing.JPanel
 private javax.swing.JPanel getJContentPane() {
 if(jContentPane == null) {
 jContentPane = new javax.swing.JPanel();
 jContentPane.setLayout(new java.awt.BorderLayout());
 return jContentPane;
 The problem is that nothing is displayed graphically as one would expect.
 As I understand it, I should see some visual feedback of the GUI I am
 creating.
 The version of Eclipse I am using is:
 3.0.2 Buildid: 200503110845
 The version of VE that I am using is 1.0.1.1
 Any help would be appreciated.
 Doug.
| Re: JFrame not visible [message #89970 is a reply to message #89926] | Fri, 06 May 2005 09:42  |  |
| Eclipse User  |  |  |  |  | Originally posted by: richkulp.us.NO_SPAM.ibm.com
 you put -clean on the command line as an option to the eclipse.exe command.
 If you use the Help->Manage configurations to do the revert, then that
 probably caused a clean under the covers.
 Rich Kulp
| Re: JFrame not visible [message #607300 is a reply to message #89236] | Mon, 02 May 2005 17:03  |  |
 Try stepping up to VE 1.0.2.1.
 1) Also, are there are any errors?
 2) Is there anything in the .log file?
 3) Do you get the Visual Editor up, but it is blank? Or does nothing
 come up?
 Rich Kulp
| Re: JFrame not visible [message #607341 is a reply to message #89251] | Wed, 04 May 2005 16:02  |  |
 > come up?
 > Rich Kulp
 The visual editor is up but it is blank after the code is generated.
 It gives the following error in the log file:
 Error May 04, 2005 14:39:28.218 Exception thrown.
 java.lang.ClassCastException: org.eclipse.emf.java.util.JavaResourceImpl
 org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.createJavaInstances(JavaSourceTranslator.java:705)
 org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.buildCompositionModel(JavaSourceTranslator.java:774)
 org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:881)
 org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:656)
 org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1444)
 at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
 I also tried installing VE 1.0.2.1 but then I got:
 "Setup Java Visual Editor (Error: An internal error occurred during
 "Setup Java Visual Editor")
 so I reverted back to the previous version.
 Doug.
| Re: JFrame not visible [message #607342 is a reply to message #89774] | Wed, 04 May 2005 18:58  |  |
 The classcast error is due to EMF Examples being installed and using VE
 1.0.1. We fixed it in VE 1.0.2.1 such that it will work with EMF
 Examples installed.
 You should be using 1.0.2.1, but you say you get an error, what is the
 stack trace from the .log when using 1.0.2.1?
 Rich Kulp
| Re: JFrame not visible [message #607351 is a reply to message #89789] | Thu, 05 May 2005 17:34  |  |
 > Examples installed.
 Just for the hell of it, I tried a "revert to previous configuration" to
 try
 VE 1.0.2.1 again.  Now it seems to work.  When I installed VE 1.0.2.1 the
 first
 time the documentation said to restart eclipse using the -clean option.  I
 wasn't sure how to do this so I just restarted normally.  Maybe when you do
 a "revert to previous configuration" it automatically restarts with the
 -clean option.  Anyway, it seems to be working now.  FYI the stack trace
 from
 when I tried the first time is as follows:
 Error May 04, 2005 14:23:19.765 An internal error occurred during: "Setup
 Java Visual Editor".
 java.lang.NoClassDefFoundError: org/eclipse/jem/internal/temp/VETimerTests
 org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1510)
 Thanks a lot for your help,
 Doug.
| Re: JFrame not visible [message #607354 is a reply to message #89926] | Fri, 06 May 2005 09:42  |  |
 Rich Kulp
FUDForum. Page generated in 0.05122 seconds
