Home » Newcomers » Newcomers » Eclipse Package Installation Errors(Missing packages)
Eclipse Package Installation Errors [message #776260] |
Sun, 08 January 2012 01:02 |
James Murdock Messages: 3 Registered: January 2012 |
CentOS 6
Linux 2.6.32-131.0.15.el6.x86_64 #1 SMP
Repo: download.eclipse.org/releases/helios
Eclipse Platform Version: 3.6.1
Build id: M20100909-0800
I am trying to install WDT and I get the following error no matter what I do:
An error occurred while collecting items to be installed
session context was:(profile=PlatformProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.eclipse.cvs.source,1.0.500.v20100414
No repository found containing: org.eclipse.update.feature,org.eclipse.cvs.source,1.2.0.v20100427-7B77FKt90GE5h0NCO35T7A01911
No repository found containing: osgi.bundle,org.eclipse.ecf.filetransfer.source,4.0.0.201110251336
No repository found containing: osgi.bundle,org.eclipse.ecf.identity.source,3.1.0.201110251336
No repository found containing: osgi.bundle,org.eclipse.ecf.provider.filetransfer.httpclient.source,4.0.0.201110251336
No repository found containing: osgi.bundle,org.eclipse.ecf.provider.filetransfer.httpclient.ssl.source,1.0.0.201110251336
No repository found containing: osgi.bundle,org.eclipse.ecf.provider.filetransfer.source,3.1.0.201110251336
No repository found containing: osgi.bundle,org.eclipse.ecf.provider.filetransfer.ssl.source,1.0.0.201110251336
No repository found containing: osgi.bundle,org.eclipse.ecf.source,3.1.0.201110251336
No repository found containing: osgi.bundle,org.eclipse.ecf.ssl.source,1.0.100.201110251336
No repository found containing: org.eclipse.update.feature,org.eclipse.equinox.p2.user.ui.source,2.0.1.r361_v20100903-897HF_oFSRe_8pL9GBQDCs7
No repository found containing: osgi.bundle,org.eclipse.help.base.source,3.5.2.r36_r20100816
No repository found containing: org.eclipse.update.feature,org.eclipse.help.source,1.2.0.v20100427-7e7jESFCsz-mFu_PfwL1ht5
No repository found containing: osgi.bundle,org.eclipse.jdt,3.6.1.r361_v20100714-0800
No repository found containing: org.eclipse.update.feature,org.eclipse.jdt,3.6.1.r361_v20100714-0800-7z8XFUSFLBmsgvVz0z-3vjz095IX
No repository found containing: osgi.bundle,org.eclipse.jdt.source,3.6.1.r361_v20100714-0800
No repository found containing: org.eclipse.update.feature,org.eclipse.jdt.source,3.6.1.r361_v20100714-0800-7z8XFUSFLBmsgvVz0z-3vjz095IX
No repository found containing: osgi.bundle,org.eclipse.pde,3.6.1.v20100625_r361
No repository found containing: org.eclipse.update.feature,org.eclipse.pde,3.6.1.r361_v20100727-7b7mFL-FDX-bf3Q-g1cCcoM
No repository found containing: osgi.bundle,org.eclipse.pde.source,3.6.1.v20100625_r361
No repository found containing: org.eclipse.update.feature,org.eclipse.pde.source,3.6.1.r361_v20100727-7b7mFL-FDX-bf3Q-g1cCcoM
No repository found containing: osgi.bundle,org.eclipse.platform.source,3.6.1.r361_v20100714-0800
No repository found containing: org.eclipse.update.feature,org.eclipse.platform.source,3.6.1.r361_v20100909-9pF78H4oFrRqnz-rr2sGKT6TX5Jjk3z0UdMaW
No repository found containing: osgi.bundle,org.eclipse.rcp.source,3.6.0.v20100527-0800
No repository found containing: org.eclipse.update.feature,org.eclipse.rcp.source,3.6.1.r361_v20100827-9oBYFOtFkzKz-AxIz-fgWr5_V
No repository found containing: osgi.bundle,org.eclipse.sdk,3.6.1.r361_v20100714-0800
No repository found containing: org.eclipse.update.feature,org.eclipse.sdk,3.6.1.r361_v20100714-0800-7Q7m6D9kQffjB-G1z-jfKYkc-vqs8r_Xuk3eIYZU8_cvU
No repository found containing: osgi.bundle,org.objectweb.asm,3.2.0
Re: Eclipse Package Installation Errors [message #776499 is a reply to message #776260] |
Sun, 08 January 2012 15:58 |
You're going to have to give more information than that. What's WDT? From what Update Site were you getting it from? Were you letting Eclipse check all of its known update sites? Why are you starting from Helios (and not even the latest Helios) instead of Indigo SR1?
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Eclipse Package Installation Errors [message #776941 is a reply to message #776683] |
Mon, 09 January 2012 15:15 |
On 08-Jan-12 21:14, James Murdock wrote:
> [snip]
> because that is what gets installed when I perform: yum install
> eclipse-platform
> I still don't see how this matters at all... please explain. What if I
> knew what I was doing and wanted to use this version? Should that matter
> whatsoever? I wouldn't think so. (again, eclipse newb here)
Ah, there's the rub! Never, never, never install Eclipse from any Linux
distro package manager. Always download it from eclipse.org unless your
platform is just too weird and needs special treatment.
Current Time: Fri Apr 26 08:30:47 GMT 2024
Powered by FUDForum. Page generated in 0.12281 seconds
