Re: Inserting Background Image Problem [message #775795 is a reply to message #775511] |
Fri, 06 January 2012 17:26 |
You need to size the grid to fit the image. I modified your example to
put your grid in another grid and moved the script to onRender. Also
make sure the image is in the resource folder or in the same directory
as the report.
See attached.
You may also want to look over these posts:
http://birtworld.blogspot.com/2010/12/birt-backgroundwatermark-images.html
http://birtworld.blogspot.com/2010/09/birt-image-report-item.html
Jason
On 1/6/2012 1:06 AM, JB . wrote:
> I am trying to insert a background image using a script but cannot get it to work.
> I have a grid on which I have attached the following onCreate script:
> this.getParent().getStyle().backgroundImage = "DRAFT-Watermark.JPG";
> The image does not show and there is no error in the debug window. I also had the full path included and it did not make a difference.
> I am new to BIRT and especially new to the scripting part of the program so I may not be attaching this to the right area.
> I am using BIRT 3.7 in Eclipse and I view the report as PDF directly from the designer.
> The test report using the sample database and the image I am trying to insert is attached.
> Thank you for any assistance,
> JB
Attachment: draft.zip
(Size: 1.87KB, Downloaded 545 times)
Re: Inserting Background Image Problem [message #775830 is a reply to message #775820] |
Fri, 06 January 2012 18:38 |
Styles can only be changed in the beforeFactory, so that is probably to
early if you want to changed based on data. It is not to late if you
want to change based on parameter. To drop the image from the grid you
could always use this.getStyle().backgroundImage = ""; in the onRender
script.
Jason
On 1/6/2012 1:19 PM, JB wrote:
> Thank you Jason. I can get it to work for me now.
> I did not realize that I couldn't supply a path to the image.
> I also did not realize that BIRT will not resize the grid to accommodate
> the image.
> I originally had the image as a background in a style but could not figure
> out how to use a script to either add or remove the image from that style
> or to change styles. What scripts do you need for that?
> JB
>> as the report.
>> See attached.
> images.html
>> Jason
Re: Inserting Background Image Problem [message #775845 is a reply to message #775839] |
Fri, 06 January 2012 19:17 |
We have a small primer on scripting at:
http://www.eclipse.org/birt/phoenix/deploy/reportScripting.php
We need to expand this.
When you change styles in the before factory you are using the DE API
and we have a lot of examples and even a webinar on this api at
BIRT-exchange.org. Here is an example
//beforeFactory
importPackage(Packages.org.eclipse.birt.report.model.api);
importPackage(Packages.org.eclipse.birt.report.model.api.elements);
reportContext.getDesignHandle().findStyle("report").setProperty(StyleHandle.FONT_FAMILY_PROP,
"Arial");
StyleHandle.COLOR_PROP, "#009B9B" );
StyleHandle.FONT_WEIGHT_PROP, DesignChoiceConstants.FONT_WEIGHT_BOLD );
//background image
reportContext.getDesignHandle().findStyle("NewStyle").setBackgroundImage( ""
//or use
StyleHandle.BACKGROUND_IMAGE_TYPE_PROP, "" );
Jason
On 1/6/2012 2:01 PM, JB wrote:
> I am changing the background based on parameters so beforeFactory would
> actually work. Your solution of setting the backgroundImage to "" is a
> good fit for my report.
> One of the things that I am struggling with in learning the scripting side
> of things is the actual keywords and options for an object.
> For example, what would the code be to change a background in a style?
> I am spending hours every day just combing through websites and forums
> looking for the small snippet of code that will work for me every time I
> try to do something new. Overall though, I like the BIRT and am finding
> the support very helpful.
> JB
>> script.
>> Jason
FUDForum. Page generated in 0.03151 seconds
