Re: Page numbering by master page [message #775768 is a reply to message #775333] |
Fri, 06 January 2012 16:42 |
When you deploy this report how will you be running it?
Jason
On 1/5/2012 2:43 PM, VinceG Mising name wrote:
> I apologize in advance if question has already been asked and resolved
> in past topics but I have not found anything.
> Here is my requirement for my BIRT 3.7 report (using run and output
> straight to PDF):
> MasterPageA (instead of having Page 1 of 2, I am getting Page 1 of 3)
> Page1
> MasterPageA
> Page2
> MasterPageB
> SummaryPage (always only one page)
> I am using auto-text in the header of masterPage. My question is how can
> I have access to the total-page variable, so I can display in my
> masterPageA something like (total-page) - 1 ?
> Any ideas are much appreciated.
> Thanks
Re: Page numbering by master page [message #775826 is a reply to message #775801] |
Fri, 06 January 2012 18:34 |
When you run the report in the Viewer, if you run to html using the
frameset mapping and then export to pdf does the report come out
correctly? Also try frameset mapping with &__format=pdf appended to the
url.
Jason
On 1/6/2012 12:36 PM, VinceG Mising name wrote:
> It will be running using WebViewer with straight output to PDF.
Re: Page numbering by master page [message #775869 is a reply to message #775853] |
Fri, 06 January 2012 20:43 |
Yes, frameset uses a run task then a render task. run mapping uses
runandrender task, which does not create a rptdocument.
Jason
On 1/6/2012 2:51 PM, VinceG Mising name wrote:
> I am using run mapping with &__format=pdf. Would frameset make a
> difference?
> Quote:
>> url.
>> Jason
FUDForum. Page generated in 0.03667 seconds
