Home » Newcomers » Newcomers » Error: could not find Java SE Runtime Environment
Error: could not find Java SE Runtime Environment [message #774507] Tue, 03 January 2012 22:53 Go to next message
I had Eclipse for quite some time until I installed Andriod ADT (I think it is called that) to it..then it would not open. It gave me some error so I deleted Eclipse (deleted..not uninstalled because I cannot find an option for that anywhere). I tried to reinstall it but get the same error:
Then when I click okay, it gives me a bigger window with a lot of errors or what not.
Help please? Thanks.
Re: Error: could not find Java SE Runtime Environment [message #774743 is a reply to message #774507] Wed, 04 January 2012 09:03 Go to previous messageGo to next message
> or what not.
Do you mean that when you launch your newly installed Eclipse, you get
this error?
Follow the advice from http://wiki.eclipse.org/Eclipse.ini .
Re: Error: could not find Java SE Runtime Environment [message #774964 is a reply to message #774743] Wed, 04 January 2012 21:14 Go to previous messageGo to next message
No I haven't even installed installed it yet.
Re: Error: could not find Java SE Runtime Environment [message #774974 is a reply to message #774964] Wed, 04 January 2012 22:02 Go to previous messageGo to next message
It's when I open up Eclipse after I download it and click Eclipse.exe
Re: Error: could not find Java SE Runtime Environment [message #775215 is a reply to message #774974] Thu, 05 January 2012 10:15 Go to previous message
Yup, follow what I said in my reply.
Previous Topic:short cut key to navigate to the starting of the loop or an if-else condition.
Next Topic:trouble sorting with joint data sets
Current Time: Fri Oct 31 03:01:31 EDT 2025
Powered by FUDForum. Page generated in 0.11912 seconds
