Re: new version does not support older version [message #774357 is a reply to message #774239] |
Tue, 03 January 2012 19:03 |
Birt is backwards compatible but older versions of the runtime will not
run reports designer with newer versions of the designer. Can you not
upgrade your runtime?
Jason
On 1/3/2012 10:16 AM, srikanth Mising name wrote:
> Hello Everyone,
> I updated the Birt when i downloaded the eclipse indigo.I am tryin to
> generate a report from a rpt design of version 3.2.22 using tocat
> server.I am getting an exception..
> Error.DesignFileException.INVALID_XML - 1 errors found! 1.) ( line = 0,
> tag = null) org.eclipse.birt.report.model.parser.DesignParserException
> (code = Error.DesignParserException.UNSUPPORTED_VERSION, message : The
> report file of version "3.2.22" is invalid for it is greater than the
> latest supported one.)
> The complete exception log is as follows
> file:/C:/ApacheSoftwareFoundation/Tomcat5.5/webapps/printdocs/resources/Map_Template.rptdesign
> has error and can not be run.
> at
> org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.getReportDesignHandle(ReportEngineHelper.java:260)
> at
> org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:274)
> at
> org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:196)
> at
> org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:130)
> at
> org.eclipse.birt.report.engine.api.impl.ReportEngine.openReportDesign(ReportEngine.java:304)
> at
> org.eclipse.birt.report.engine.api.ReportEngine.openReportDesign(ReportEngine.java:126)
> at src.beans.ReportBuilder.run(Unknown Source)
> at servlet.PrintDocsServlet.doGet(Unknown Source)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
> at
> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252)
> at
> org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173)
> at
> org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
> at
> org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
> at
> org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
> at
> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105)
> at
> org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107)
> at
> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
> at
> org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:868)
> at
> org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:663)
> at
> org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527)
> at
> org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:80)
> at
> org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684)
> at java.lang.Thread.run(Unknown Source)
> Caused by: Error.DesignFileException.INVALID_XML - 1 errors found! 1.) (
> line = 0, tag = null)
> org.eclipse.birt.report.model.parser.DesignParserException (code =
> Error.DesignParserException.UNSUPPORTED_VERSION, message : The report
> file of version "3.2.22" is invalid for it is greater than the latest
> supported one.)
> at
> org.eclipse.birt.report.model.parser.ModuleReader.readModule(ModuleReader.java:116)
> at
> org.eclipse.birt.report.model.parser.DesignReader.read(DesignReader.java:88)
> at
> org.eclipse.birt.report.model.core.DesignSessionImpl.openDesign(DesignSessionImpl.java:314)
> at
> org.eclipse.birt.report.model.api.SessionHandleImpl.openDesign(SessionHandleImpl.java:294)
> at
> org.eclipse.birt.report.engine.parser.ReportParser.getDesignHandle(ReportParser.java:158)
> at
> org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.getReportDesignHandle(ReportEngineHelper.java:255)
> ... 23 more
> Caused by: org.eclipse.birt.report.model.parser.DesignParserException:
> The report file of version "3.2.22" is invalid for it is greater than
> the latest supported one.
> at
> org.eclipse.birt.report.model.parser.ModuleState.parseAttrs(ModuleState.java:112)
> at
> org.eclipse.birt.report.model.parser.ModuleParserHandler.startElement(ModuleParserHandler.java:257)
> at
> com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator.startElement(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$ContentDriver.scanRootElementHook(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown
> Source)
> at
> Source)
> at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown
> Source)
> at javax.xml.parsers.SAXParser.parse(Unknown Source)
> at
> org.eclipse.birt.report.model.parser.ModuleReader.readModule(ModuleReader.java:94)
> ... 28 more
> at
> org.eclipse.birt.report.model.parser.ModuleState.parseAttrs(ModuleState.java:109)
> ... 44 more
> Any suggestion will be really helpful
> Regards,
> Srikanth
Re: new version does not support older version [message #775233 is a reply to message #774357] |
Thu, 05 January 2012 15:56 |
srikanth Mising name Messages: 38 Registered: July 2010 |
Member |
Thnk you Jason I downloaded the latest runtime engine.. now have a different exception. I am suspecting this is because of the missing folders in the new downloaded version
org.eclipse.core.runtime,
org.eclipse.equinox.app,
org.eclipse.osgi,
org.eclipse.update
Am I missing something else..
The exception is below
org.eclipse.birt.core.exception.BirtException: Can not startup the OSGI framework
at org.eclipse.birt.core.framework.Platform.startup(Platform.java:91)
at src.beans.BIRTEngineFactory.createEngineInstance(Unknown Source)
at src.beans.BIRTEngineFactory.getReportEngine(Unknown Source)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:868)
at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:663)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527)
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:80)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684)
Caused by: org.eclipse.birt.core.exception.CoreException
at org.eclipse.birt.core.framework.osgi.OSGILauncher.startup(OSGILauncher.java:90)
at org.eclipse.birt.core.framework.Platform.startup(Platform.java:79)
... 20 more
[Updated on: Thu, 05 January 2012 15:57] Report message to a moderator
Re: new version does not support older version [message #775286 is a reply to message #775233] |
Thu, 05 January 2012 18:05 |
If you downloaded the 3.7.1 runtime you should not be setting birt home
anymore. How are you running the new runtime? Starting with 3.7 BIRT
now uses a pojo based runtime.
http://www.eclipse.org/birt/phoenix/project/notable3.7.php#jump_2
Jason
> different exception. I am suspecting this is because of the folders in
> the new downloaded
> versionorg.eclipse.core.runtime,org.eclipse.equinox.app,org.eclipse.osgi,org.eclipse.update
> framework
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 20 more
Re: new version does not support older version [message #775799 is a reply to message #775787] |
Fri, 06 January 2012 17:32 |
That is because your table is bound to a data set that does not return
any rows.
Jason
On 1/6/2012 12:12 PM, srikanth Mising name wrote:
> Hi Jason,
> I was able to print th ereport sucessfully... But the content put in the
> table doesn print.. Below is the Xml of the rpt design..
> <report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.22"
> id="1">
> <property name="createdBy">Eclipse BIRT Designer Version 3.7.0.v20110602
> Build <3.7.0.v20110607-1526></property>
> <property name="units">in</property>
> <property name="iconFile">/templates/blank_report.gif</property>
> <property name="bidiLayoutOrientation">ltr</property>
> <property name="imageDPI">96</property>
> <data-sources>
> <script-data-source name="DataSource" id="2400"/>
> </data-sources>
> <data-sets>
> <script-data-set name="DataSet" id="2401">
> <structure name="cachedMetaData"/>
> <property name="dataSource">DataSource</property>
> </script-data-set>
> </data-sets>
> <styles>
> <style name="report" id="4">
> <property name="fontFamily">sans-serif</property>
> <property name="fontSize">10pt</property>
> </style>
> <style name="crosstab-cell" id="5">
> <property name="borderBottomColor">#CCCCCC</property>
> <property name="borderBottomStyle">solid</property>
> <property name="borderBottomWidth">1pt</property>
> <property name="borderLeftColor">#CCCCCC</property>
> <property name="borderLeftStyle">solid</property>
> <property name="borderLeftWidth">1pt</property>
> <property name="borderRightColor">#CCCCCC</property>
> <property name="borderRightStyle">solid</property>
> <property name="borderRightWidth">1pt</property>
> <property name="borderTopColor">#CCCCCC</property>
> <property name="borderTopStyle">solid</property>
> <property name="borderTopWidth">1pt</property>
> </style>
> <style name="crosstab" id="6">
> </style>
> </styles>
> <page-setup>
> <simple-master-page name="Simple MasterPage" id="2">
> <page-footer>
> <text id="3">
> <property name="contentType">html</property>
> <text-property name="content"><![CDATA[<value-of>new
> Date()</value-of>]]></text-property>
> </text>
> </page-footer>
> </simple-master-page>
> </page-setup>
> <body>
> <table id="2391">
> <property name="dataSet">DataSet</property>
> <column id="2398"/>
> <detail>
> <row id="2394">
> <cell id="2395">
> <text-data id="2399">
> <expression name="valueExpr">"helooo"</expression>
> </text-data>
> </cell>
> </row>
> </detail>
> </table>
> <text-data id="2402">
> <expression name="valueExpr">"hi111111+++1111"</expression>
> </text-data>
> <grid id="2403">
> <column id="2404"/>
> <row id="2405">
> <cell id="2406">
> <text-data id="2407">
> <expression name="valueExpr">"222222++22222222"</expression>
> </text-data>
> </cell>
> </row>
> </grid>
> </body>
> </report>
Re: new version does not support older version [message #775811 is a reply to message #775799] |
Fri, 06 January 2012 18:01 |
Member |
Thanks Jason.. I have a report which was working perfectly before i upgraded BIRT.. Now the contents in the table are not printing..
below is the xml for the report..
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.22" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 3.7.0.v20110602 Build <3.7.0.v20110607-1526></property>
<property name="layoutPreference">fixed layout</property>
<data-sources>
<script-data-source name="DataSource" id="7"/>
</data-sources>
<data-sets>
<script-data-set name="MainDataSet" id="8">
<list-property name="resultSetHints">
<structure>
<property name="position">1</property>
<property name="name">tableHeaderField1</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">tableHeaderField1Value</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">tableHeaderField2</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">tableHeaderField2Value</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">tableField1</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">tableField2</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">tableField3</property>
</structure>
<structure>
<property name="position">8</property>
<property name="name">tableField4</property>
</structure>
<structure>
<property name="position">9</property>
<property name="name">tableField5</property>
</structure>
<structure>
<property name="position">10</property>
<property name="name">tableField6</property>
</structure>
<structure>
<property name="position">11</property>
<property name="name">tableField7</property>
</structure>
<structure>
<property name="position">12</property>
<property name="name">tableField8</property>
</structure>
<structure>
<property name="position">13</property>
<property name="name">tableField9</property>
</structure>
<structure>
<property name="position">14</property>
<property name="name">tableField10</property>
</structure>
<structure>
<property name="position">15</property>
<property name="name">tableField11</property>
</structure>
<structure>
<property name="position">16</property>
<property name="name">tableField12</property>
</structure>
<structure>
<property name="position">17</property>
<property name="name">tableField13</property>
</structure>
<structure>
<property name="position">18</property>
<property name="name">tableField14</property>
</structure>
<structure>
<property name="position">19</property>
<property name="name">tableField1Value</property>
</structure>
<structure>
<property name="position">20</property>
<property name="name">tableField2Value</property>
</structure>
<structure>
<property name="position">21</property>
<property name="name">tableField3Value</property>
</structure>
<structure>
<property name="position">22</property>
<property name="name">tableField4Value</property>
</structure>
<structure>
<property name="position">23</property>
<property name="name">tableField5Value</property>
</structure>
<structure>
<property name="position">24</property>
<property name="name">tableField6Value</property>
</structure>
<structure>
<property name="position">25</property>
<property name="name">tableField7Value</property>
</structure>
<structure>
<property name="position">26</property>
<property name="name">tableField8Value</property>
</structure>
<structure>
<property name="position">27</property>
<property name="name">tableField9Value</property>
</structure>
<structure>
<property name="position">28</property>
<property name="name">tableField10Value</property>
</structure>
<structure>
<property name="position">29</property>
<property name="name">tableField11Value</property>
</structure>
<structure>
<property name="position">30</property>
<property name="name">tableField12Value</property>
</structure>
<structure>
<property name="position">31</property>
<property name="name">tableField13Value</property>
</structure>
<structure>
<property name="position">32</property>
<property name="name">tableField14Value</property>
</structure>
<structure>
<property name="position">33</property>
<property name="name">title</property>
</structure>
<structure>
<property name="position">34</property>
<property name="name">titleValue</property>
</structure>
<structure>
<property name="position">35</property>
<property name="name">document</property>
</structure>
<structure>
<property name="position">36</property>
<property name="name">documentValue</property>
</structure>
<structure>
<property name="position">37</property>
<property name="name">location</property>
</structure>
<structure>
<property name="position">38</property>
<property name="name">locationValue</property>
</structure>
<structure>
<property name="position">39</property>
<property name="name">authors</property>
</structure>
<structure>
<property name="position">40</property>
<property name="name">authorsValue</property>
</structure>
<structure>
<property name="position">41</property>
<property name="name">grades</property>
</structure>
<structure>
<property name="position">42</property>
<property name="name">gradesValue</property>
</structure>
<structure>
<property name="position">43</property>
<property name="name">subjects</property>
</structure>
<structure>
<property name="position">44</property>
<property name="name">subjectsValue</property>
</structure>
<structure>
<property name="position">45</property>
<property name="name">courses</property>
</structure>
<structure>
<property name="position">46</property>
<property name="name">coursesValue</property>
</structure>
<structure>
<property name="position">47</property>
<property name="name">type</property>
</structure>
<structure>
<property name="position">48</property>
<property name="name">typeValue</property>
</structure>
<structure>
<property name="position">49</property>
<property name="name">dateModifiedValue</property>
</structure>
<structure>
<property name="position">50</property>
<property name="name">headerTitle</property>
</structure>
<structure>
<property name="position">51</property>
<property name="name">headerAuthor</property>
</structure>
<structure>
<property name="position">52</property>
<property name="name">formattedAuthorsValue</property>
</structure>
<structure>
<property name="position">53</property>
<property name="name">attachment</property>
</structure>
<structure>
<property name="position">54</property>
<property name="name">attachmentValue</property>
</structure>
<structure>
<property name="position">55</property>
<property name="name">formattedAuthors</property>
</structure>
<structure>
<property name="position">56</property>
<property name="name">notes</property>
</structure>
<structure>
<property name="position">57</property>
<property name="name">notesValue</property>
</structure>
<structure>
<property name="position">58</property>
<property name="name">docField1</property>
</structure>
<structure>
<property name="position">59</property>
<property name="name">docField1Value</property>
</structure>
<structure>
<property name="position">60</property>
<property name="name">docField2</property>
</structure>
<structure>
<property name="position">61</property>
<property name="name">docField2Value</property>
</structure>
<structure>
<property name="position">62</property>
<property name="name">docField3</property>
</structure>
<structure>
<property name="position">63</property>
<property name="name">docField3Value</property>
</structure>
<structure>
<property name="position">64</property>
<property name="name">lastmodifiedValue</property>
</structure>
<structure>
<property name="position">65</property>
<property name="name">type_in_header</property>
</structure>
<structure>
<property name="position">66</property>
<property name="name">type_in_headerValue</property>
</structure>
<structure>
<property name="position">67</property>
<property name="name">titleHeader</property>
</structure>
<structure>
<property name="position">68</property>
<property name="name">titleHeaderValue</property>
</structure>
<structure>
<property name="position">69</property>
<property name="name">month1</property>
</structure>
<structure>
<property name="position">70</property>
<property name="name">month2</property>
</structure>
<structure>
<property name="position">71</property>
<property name="name">month3</property>
</structure>
<structure>
<property name="position">72</property>
<property name="name">month4</property>
</structure>
<structure>
<property name="position">73</property>
<property name="name">month5</property>
</structure>
<structure>
<property name="position">74</property>
<property name="name">month6</property>
</structure>
<structure>
<property name="position">75</property>
<property name="name">month7</property>
</structure>
<structure>
<property name="position">76</property>
<property name="name">month8</property>
</structure>
<structure>
<property name="position">77</property>
<property name="name">month9</property>
</structure>
<structure>
<property name="position">78</property>
<property name="name">month10</property>
</structure>
<structure>
<property name="position">79</property>
<property name="name">calendarMonth</property>
</structure>
</list-property>
<list-property name="columnHints">
<structure>
<property name="columnName">tableHeaderField1</property>
<text-property name="displayName">tableHeaderField1</text-property>
</structure>
<structure>
<property name="columnName">tableHeaderField1Value</property>
<text-property name="displayName">tableHeaderField1Value</text-property>
</structure>
<structure>
<property name="columnName">tableHeaderField2</property>
<text-property name="displayName">tableHeaderField2</text-property>
</structure>
<structure>
<property name="columnName">tableHeaderField2Value</property>
<text-property name="displayName">tableHeaderField2Value</text-property>
</structure>
<structure>
<property name="columnName">tableField1</property>
<text-property name="displayName">tableField1</text-property>
</structure>
<structure>
<property name="columnName">tableField2</property>
<text-property name="displayName">tableField2</text-property>
</structure>
<structure>
<property name="columnName">tableField3</property>
<text-property name="displayName">tableField3</text-property>
</structure>
<structure>
<property name="columnName">tableField4</property>
<text-property name="displayName">tableField4</text-property>
</structure>
<structure>
<property name="columnName">tableField5</property>
<text-property name="displayName">tableField5</text-property>
</structure>
<structure>
<property name="columnName">tableField6</property>
<text-property name="displayName">tableField6</text-property>
</structure>
<structure>
<property name="columnName">tableField7</property>
<text-property name="displayName">tableField7</text-property>
</structure>
<structure>
<property name="columnName">tableField8</property>
<text-property name="displayName">tableField8</text-property>
</structure>
<structure>
<property name="columnName">tableField9</property>
<text-property name="displayName">tableField9</text-property>
</structure>
<structure>
<property name="columnName">tableField10</property>
<text-property name="displayName">tableField10</text-property>
</structure>
<structure>
<property name="columnName">tableField11</property>
<text-property name="displayName">tableField11</text-property>
</structure>
<structure>
<property name="columnName">tableField12</property>
<text-property name="displayName">tableField12</text-property>
</structure>
<structure>
<property name="columnName">tableField13</property>
<text-property name="displayName">tableField13</text-property>
</structure>
<structure>
<property name="columnName">tableField14</property>
<text-property name="displayName">tableField14</text-property>
</structure>
<structure>
<property name="columnName">tableField1Value</property>
<text-property name="displayName">tableField1Value</text-property>
</structure>
<structure>
<property name="columnName">tableField2Value</property>
<text-property name="displayName">tableField2Value</text-property>
</structure>
<structure>
<property name="columnName">tableField3Value</property>
<text-property name="displayName">tableField3Value</text-property>
</structure>
<structure>
<property name="columnName">tableField4Value</property>
<text-property name="displayName">tableField4Value</text-property>
</structure>
<structure>
<property name="columnName">tableField5Value</property>
<text-property name="displayName">tableField5Value</text-property>
</structure>
<structure>
<property name="columnName">tableField6Value</property>
<text-property name="displayName">tableField6Value</text-property>
</structure>
<structure>
<property name="columnName">tableField7Value</property>
<text-property name="displayName">tableField7Value</text-property>
</structure>
<structure>
<property name="columnName">tableField8Value</property>
<text-property name="displayName">tableField8Value</text-property>
</structure>
<structure>
<property name="columnName">tableField9Value</property>
<text-property name="displayName">tableField9Value</text-property>
</structure>
<structure>
<property name="columnName">tableField10Value</property>
<text-property name="displayName">tableField10Value</text-property>
</structure>
<structure>
<property name="columnName">tableField11Value</property>
<text-property name="displayName">tableField11Value</text-property>
</structure>
<structure>
<property name="columnName">tableField12Value</property>
<text-property name="displayName">tableField12Value</text-property>
</structure>
<structure>
<property name="columnName">tableField13Value</property>
<text-property name="displayName">tableField13Value</text-property>
</structure>
<structure>
<property name="columnName">tableField14Value</property>
<text-property name="displayName">tableField14Value</text-property>
</structure>
<structure>
<property name="columnName">title</property>
<text-property name="displayName">title</text-property>
</structure>
<structure>
<property name="columnName">titleValue</property>
<text-property name="displayName">titleValue</text-property>
</structure>
<structure>
<property name="columnName">document</property>
<text-property name="displayName">document</text-property>
</structure>
<structure>
<property name="columnName">documentValue</property>
<text-property name="displayName">documentValue</text-property>
</structure>
<structure>
<property name="columnName">location</property>
<text-property name="displayName">location</text-property>
</structure>
<structure>
<property name="columnName">locationValue</property>
<text-property name="displayName">locationValue</text-property>
</structure>
<structure>
<property name="columnName">authors</property>
<text-property name="displayName">authors</text-property>
</structure>
<structure>
<property name="columnName">authorsValue</property>
<text-property name="displayName">authorsValue</text-property>
</structure>
<structure>
<property name="columnName">grades</property>
<text-property name="displayName">grades</text-property>
</structure>
<structure>
<property name="columnName">gradesValue</property>
<text-property name="displayName">gradesValue</text-property>
</structure>
<structure>
<property name="columnName">subjects</property>
<text-property name="displayName">subjects</text-property>
</structure>
<structure>
<property name="columnName">subjectsValue</property>
<text-property name="displayName">subjectsValue</text-property>
</structure>
<structure>
<property name="columnName">courses</property>
<text-property name="displayName">courses</text-property>
</structure>
<structure>
<property name="columnName">coursesValue</property>
<text-property name="displayName">coursesValue</text-property>
</structure>
<structure>
<property name="columnName">type</property>
<text-property name="displayName">type</text-property>
</structure>
<structure>
<property name="columnName">typeValue</property>
<text-property name="displayName">typeValue</text-property>
</structure>
<structure>
<property name="columnName">dateModifiedValue</property>
<text-property name="displayName">dateModifiedValue</text-property>
</structure>
<structure>
<property name="columnName">headerTitle</property>
<text-property name="displayName">headerTitle</text-property>
</structure>
<structure>
<property name="columnName">headerAuthor</property>
<text-property name="displayName">headerAuthor</text-property>
</structure>
<structure>
<property name="columnName">formattedAuthorsValue</property>
<text-property name="displayName">formattedAuthorsValue</text-property>
</structure>
<structure>
<property name="columnName">attachment</property>
<text-property name="displayName">attachment</text-property>
</structure>
<structure>
<property name="columnName">attachmentValue</property>
<text-property name="displayName">attachmentValue</text-property>
</structure>
<structure>
<property name="columnName">formattedAuthors</property>
<text-property name="displayName">formattedAuthors</text-property>
</structure>
<structure>
<property name="columnName">notes</property>
<text-property name="displayName">notes</text-property>
</structure>
<structure>
<property name="columnName">notesValue</property>
<text-property name="displayName">notesValue</text-property>
</structure>
<structure>
<property name="columnName">docField1</property>
<text-property name="displayName">docField1</text-property>
</structure>
<structure>
<property name="columnName">docField1Value</property>
<text-property name="displayName">docField1Value</text-property>
</structure>
<structure>
<property name="columnName">docField2</property>
<text-property name="displayName">docField2</text-property>
</structure>
<structure>
<property name="columnName">docField2Value</property>
<text-property name="displayName">docField2Value</text-property>
</structure>
<structure>
<property name="columnName">docField3</property>
<text-property name="displayName">docField3</text-property>
</structure>
<structure>
<property name="columnName">docField3Value</property>
<text-property name="displayName">docField3Value</text-property>
</structure>
<structure>
<property name="columnName">lastmodifiedValue</property>
<text-property name="displayName">lastmodifiedValue</text-property>
</structure>
<structure>
<property name="columnName">type_in_header</property>
<text-property name="displayName">type_in_header</text-property>
</structure>
<structure>
<property name="columnName">type_in_headerValue</property>
<text-property name="displayName">type_in_headerValue</text-property>
</structure>
<structure>
<property name="columnName">titleHeader</property>
<text-property name="displayName">titleHeader</text-property>
</structure>
<structure>
<property name="columnName">titleHeaderValue</property>
<text-property name="displayName">titleHeaderValue</text-property>
</structure>
<structure>
<property name="columnName">month1</property>
<text-property name="displayName">month1</text-property>
</structure>
<structure>
<property name="columnName">month2</property>
<text-property name="displayName">month2</text-property>
</structure>
<structure>
<property name="columnName">month3</property>
<text-property name="displayName">month3</text-property>
</structure>
<structure>
<property name="columnName">month4</property>
<text-property name="displayName">month4</text-property>
</structure>
<structure>
<property name="columnName">month5</property>
<text-property name="displayName">month5</text-property>
</structure>
<structure>
<property name="columnName">month6</property>
<text-property name="displayName">month6</text-property>
</structure>
<structure>
<property name="columnName">month7</property>
<text-property name="displayName">month7</text-property>
</structure>
<structure>
<property name="columnName">month8</property>
<text-property name="displayName">month8</text-property>
</structure>
<structure>
<property name="columnName">month9</property>
<text-property name="displayName">month9</text-property>
</structure>
<structure>
<property name="columnName">month10</property>
<text-property name="displayName">month10</text-property>
</structure>
<structure>
<property name="columnName">calendarMonth</property>
<text-property name="displayName">calendarMonth</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
<property name=&quo
[Updated on: Fri, 06 January 2012 19:50] Report message to a moderator
FUDForum. Page generated in 0.04373 seconds
