Home » Language IDEs » PHP Development Tools (PDT) » phptools
phptools [message #773724] Mon, 02 January 2012 06:36 Go to next message
I ave installed phptools for eclipse pdt...
But when i want to execute a test, I have got this error :
An internal error occurred during: "PHPUnit".
The same error applies as well for code sniffer, pdepend,...
Here is the log output :
at org.phpsrc.eclipse.pti.tools.phpunit.core.PHPUnit.runTestCase(PHPUnit.java:256)
at org.phpsrc.eclipse.pti.tools.phpunit.validator.PHPUnitValidator.validateTestCase(PHPUnitValidator.java:59)
at org.phpsrc.eclipse.pti.tools.phpunit.validator.PHPUnitValidator.validateTestCase(PHPUnitValidator.java:45)
at org.phpsrc.eclipse.pti.tools.phpunit.ui.actions.RunTestCaseAction$1.run(RunTestCaseAction.java:50)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Anyone have an idea?
thx
[Updated on: Mon, 02 January 2012 07:56] by Moderator
Re: phptools [message #773766 is a reply to message #773724] Mon, 02 January 2012 08:31 Go to previous messageGo to next message
How You execute those commands? as external tools?
More detailed stack trace?
/dmc
Re: phptools [message #773808 is a reply to message #773766] Mon, 02 January 2012 10:43 Go to previous messageGo to next message
New icons have appeared in my toolbar...
When I am in a test file, I click on these icons (file with a blue triangle... if it helps)...
I do not have a more detailled stack trace...
Re: phptools [message #773846 is a reply to message #773808] Mon, 02 January 2012 12:51 Go to previous messageGo to next message
> if it helps)...
It's bit hard to know everything by it's icon inevery theme, any screenshoot or
title under mouse pointer?
Take a look under error log tab (if You don't have it then first show this in
window menu, show view..).
/dmc
Re: phptools [message #774095 is a reply to message #773846] Tue, 03 January 2012 03:51 Go to previous messageGo to next message
I have copied source files of phpunit test project.... and it works...
I have another probleme with my personnal project...
I use rse polugin because files are on our dev server...
Is there a way to run phpunit tests in my eclipse with remote files ?
Re: phptools [message #774231 is a reply to message #774095] Tue, 03 January 2012 09:58 Go to previous messageGo to next message
RSE is great for temporary changes and quick fixes that will be later pushed to
versioning control, but it's not very usable in day to day work, having remote
project everything is very slow, using RSE is not build.
Rather use remote sync than this. That allows to have project locally and push
changes to remote server using builder.
Yes, setup ssh connection without password (using certs) and then just invoke
needed command, You will see all output in Eclipse. You can even set up such
thing when some files are saved or changed or at commit.
/dmc
Re: phptools [message #774243 is a reply to message #774231] Tue, 03 January 2012 10:22 Go to previous messageGo to next message
Thx for your answer...
I will try to find how to set up ssh connection without password...
Re: phptools [message #776899 is a reply to message #774243] Mon, 09 January 2012 08:34 Go to previous message
cygwin + ssh + cert will work as You want,
ssh allows to invoke remote command, just place it after username
and that's all what You need now :)
/dmc
Previous Topic:Eclipse 2.x or 3.x?
Next Topic:PDT 3.0.2 Eclipse Update Site ?
Current Time: Mon Sep 22 23:55:36 EDT 2025
Powered by FUDForum. Page generated in 0.04772 seconds
