Home » Eclipse Projects » GEF » Accessing the GraphicalViewer of a GraphicalEditor and vice-vera
Accessing the GraphicalViewer of a GraphicalEditor and vice-vera [message #88244] Thu, 24 July 2003 11:58 Go to next message
Originally posted by: bgrieder.nospam.thanks
I am creating a (GEF) ContentOutlinePage for an OutlineViewer and, for
clarity, wishes the class implementing the ContentOutlinePage not being
an inner class of the GraphicalEditor (in contrary to the logic example).
However, it seems that I have to pass BOTH the GraphicalEditor object
and its associated GraphicalViewer object to the ContentOutlinePage,
because I cannot access the GraphicalViewer from the GraphicalEditor.
Why is the getGraphicalViewer method on the GraphicalEditor protected?
Is there a better implementation than passing both objects?
Many Thanks
bruno
Re: Accessing the GraphicalViewer of a GraphicalEditor and vice-vera [message #88279 is a reply to message #88244] Thu, 24 July 2003 13:01 Go to previous messageGo to next message
You can call GraphicalEditor.getAdapter(GraphicalViewer.class) to get the
GraphicalViewer.
Bruno Grieder wrote:
> Many Thanks
> bruno
Re: Accessing the GraphicalViewer of a GraphicalEditor and vice-vera [message #88370 is a reply to message #88279] Fri, 25 July 2003 02:54 Go to previous messageGo to next message
Thanks Eric.
> the GraphicalViewer.
>> being an inner class of the GraphicalEditor (in contrary to the logic
>> example).
>> Many Thanks
>> bruno
Re: Accessing the GraphicalViewer of a GraphicalEditor and vice-vera [message #88460 is a reply to message #88244] Fri, 25 July 2003 08:17 Go to previous messageGo to next message
You can overwrite it in your editor and make it public :)
Cu, Gunnar
Re: Accessing the GraphicalViewer of a GraphicalEditor and vice-vera [message #88505 is a reply to message #88460] Fri, 25 July 2003 12:20 Go to previous message
Yes. That is what I initially did ;-) But honestly, it is not great from
a maintenance and clarity point of view. So, I implemented the solution
proposed by Eric, which works fine.
The Adapter(s) are quite tricky to get into but really powerful. I now
have a customized View which automatically displays information
depending on what is clicked or changed in the GraphicalEditor. Pretty
cool :-)
> Cu, Gunnar
Previous Topic:How do i Import a java project into Workspace by programming
Next Topic:how do you reveal an edit part when model object selected via outline
Current Time: Wed Oct 29 11:51:20 EDT 2025
Powered by FUDForum. Page generated in 0.03542 seconds
