Home » Language IDEs » Java Development Tools (JDT) » Configuring Oracle OCI JDBC driver
Configuring Oracle OCI JDBC driver [message #88162] Fri, 22 August 2003 06:50 Go to next message
Originally posted by: joonas.reynders.merideasoftware.com
Has anyone succeeded in configuring the JDT to work with Oracle 9 OCI JDBC
driver? If I just try using the oci library with jdbc I get an error stating
that the ocijdbc9.dll is not in java.library.path, if I add the directory
(oracle_home/bin) in the run-time workbench settings I get this:
Failed to execute runnable (java.lang.UnsatisfiedLinkError:
C:\oracle\ora9\bin\ocijdbc9.dll: Can't find dependent libraries)
All help is appreciated,
Joonas
Re: Configuring Oracle OCI JDBC driver [message #88178 is a reply to message #88162] Fri, 22 August 2003 06:56 Go to previous messageGo to next message
Please check the following:
ORACLE_HOME must point to your oracle client and the PATH environment
must include the /bin directory of your Oracle client.
HTH,
Frank
Re: Configuring Oracle OCI JDBC driver [message #88406 is a reply to message #88162] Fri, 22 August 2003 15:35 Go to previous messageGo to next message
Joonas, is there a reason you don't want to use the type 4 drivers? I've found
that the Oracle JDBC Thin drivers work exceptionally well. These would elminate
you need to setup any Oracle client libraries on development system. The only
two reasons that I know of not using Thin Driver is that you must use something
other than TCP/IP for you network layer or you are supporting an Oracle database
earlier than 7.2.
Jeff Duska
> Hi
> Joonas
Re: Configuring Oracle OCI JDBC driver [message #88449 is a reply to message #88406] Fri, 22 August 2003 18:41 Go to previous messageGo to next message
Performance reason is first and only for oci driver
regards
Haris Peco
> found that the Oracle JDBC Thin drivers work exceptionally well. These
> would elminate you need to setup any Oracle client libraries on
> development system. The only two reasons that I know of not using Thin
> Driver is that you must use something other than TCP/IP for you network
> layer or you are supporting an Oracle database earlier than 7.2.
> Jeff Duska
>> Hi
>> JDBC driver? If I just try using the oci library with jdbc I get an error
>> stating that the ocijdbc9.dll is not in java.library.path, if I add the
>> directory (oracle_home/bin) in the run-time workbench settings I get
>> this:
>> Joonas
Re: Configuring Oracle OCI JDBC driver [message #88478 is a reply to message #88449] Fri, 22 August 2003 17:34 Go to previous messageGo to next message
Originally posted by: ifedorenko.rogers.com
You need OCI driver to access BLOB/CLOB.
> regards
> Haris Peco
>>Regards,
>>Jeff Duska
>>>Hi
>>>this:
>>>Joonas
Re: Configuring Oracle OCI JDBC driver [message #88528 is a reply to message #88478] Sat, 23 August 2003 09:45 Go to previous messageGo to next message
It isn't true for jdbc driver >= 9.0.2 (ojdbc14.jar)
regards
Haris Peco
>> regards
>> Haris Peco
>>>Regards,
>>>Jeff Duska
>>>>Hi
>>>>error stating that the ocijdbc9.dll is not in java.library.path, if I
>>>>add the directory (oracle_home/bin) in the run-time workbench settings I
>>>>get this:
>>>>Joonas
Re: Configuring Oracle OCI JDBC driver [message #88716 is a reply to message #88528] Sun, 24 August 2003 03:49 Go to previous message
From the Oracle 9.2.0 JDBC readme.txt
What Is New In This Release Since 9.0.2 ?
Direct support for LOBs in the Thin driver.
The Thin driver now provides direct support for BFILEs, BLOBs, and
CLOBs. Prior to this release it supported them via calls to PL/SQL
routines.
but:
* There is a limitation regarding the use of stream input for LOB
types. Stream input for LOB types can only be used for 8.1.7 or
later JDBC OCI driver connecting to an 8.1.7 or later Oracle
server. The use of stream input for LOB types in all other
configurations may result in data corruption. PreparedStatement
stream input APIs include: setBinaryStream(), setAsciiStream(),
setUnicodeStream(), setCharacterStream() and setObject().
To best of my understanding this means that if I use binary streams with
LOBs (I do), I must use OCI drivers
Joonas
"snpe" <snpe@snpe.co.yu> wrote in message news:bi7jvs$3gm$1@eclipse.org...
> regards
> Haris Peco
> >> regards
> >> Haris Peco
I've
> >>>Regards,
> >>>Jeff Duska
> >>>>Hi
I
> >>>>get this:
> >>>>Joonas
Previous Topic:Upgraded from 2.1 to 3.0, now can't view console, cvs console
Next Topic:Can files of same package be in different jars!
Current Time: Mon Nov 03 15:56:52 EST 2025
Powered by FUDForum. Page generated in 0.04727 seconds
