Home » Archived » BIRT » embedded BMP not showing up
embedded BMP not showing up [message #87876] Fri, 04 November 2005 16:16 Go to next message
Originally posted by: mlorenz.nc.rr.com
I used an embedded image in my report. It shows up in the viewer, but
when I run it in my runtime, the image doesn't show up. How do I package
artwork with my app when using BIRT?
Thx, Mark
Re: embedded BMP not showing up [message #88225 is a reply to message #87876] Mon, 07 November 2005 10:38 Go to previous messageGo to next message
Changed it to a BMP referenced via a URL and put the file in my runtime
directory. Now it shows up fine, but I always get an error too:
There are errors on the report page:
- There are error(s) in Image:null
Error0 : Failed to evaluate CMBP.bmp(1 time)detail: Failed to evaluate
CMBP.bmpReferenceError: "CMBP" is not defined. (#1)
But the file *is* found, so I don't know what the problem is.
Anyone else getting this error? If not, how are you setting up your
artwork?
Thanks, Mark
Re: embedded BMP not showing up [message #89977 is a reply to message #88225] Thu, 10 November 2005 19:14 Go to previous message
Mark
I think .bmp images are not well suited for web pages.
Try this:
Build a report with several common image types (jpg, gif, png, ico, etc).
Check how they are displayed in HTML viewer and PDF viewer.
Stick to those that are displayed with the best quality.
This is because not all types of images display correctly in both viewers.
Previous Topic:Has anyone gotten images to work?
Next Topic:What version of Birt started supporting Total.percent?
Current Time: Thu Sep 25 09:21:45 EDT 2025
Powered by FUDForum. Page generated in 0.03278 seconds
