Problem Opening Eclipse [message #771245] |
Mon, 26 December 2011 19:00 |
Ziad Akiki Messages: 2 Registered: December 2011 |
Hello, I unzipped Eclipse in "C:\eclipse" and Java was already installed so I reinstall the latest version (version 6 update 30). When I opened the eclipse.exe it shows a dialog box saying that I don't have Java in this directory (C:\Eclipse\jre\bin...) so I copied the java folder and rename it to suit the upper directory. After reopening, eclipse show the Splash Screen but says "Failed to Load the JNI shared library"
[Updated on: Mon, 26 December 2011 19:04] Report message to a moderator
Re: Problem Opening Eclipse [message #771926 is a reply to message #771245] |
Wed, 28 December 2011 14:51 |
On 2011.12.26 12:00, Ziad Akiki wrote:
> Hello, I unzipped Eclipse in C:\eclipse. When I opened the eclipse.exe
> suit the upper directory. After reopenig, eclipse show the Splash Screen
> Note: I updated Java to the latest version 6 update 30
Please see http://wiki.eclipse.org/Eclipse.ini
Re: Problem Opening Eclipse [message #772326 is a reply to message #771973] |
Thu, 29 December 2011 14:17 |
On 2011.12.28 10:20, Ziad Akiki wrote:
> I'm getting a new error: "Java was started but returned exit code = 13"
This may be that you're attempting to pair an Eclipse download and a
JDK/JRE of dissimilar bittedness. Ensure that you've got both a 32-bit
Eclipse and 32-bit JRE or a 64-bit Eclipse and 64-bit JRE.
FUDForum. Page generated in 0.08222 seconds
