Home » Language IDEs » PHP Development Tools (PDT) » Open Declaration in Classes PDT 2RC2
Open Declaration in Classes PDT 2RC2 [message #87127] Fri, 19 December 2008 05:02 Go to next message
Originally posted by: lpiernik.gmail.com
I have may classes and in PDT 1 when I pressed ctrl over name of the
method ex. $Article->read(); I could jump to read declaration.
In PDT 2 I can't
Within a class ex $this->read(); open declaration works fine...
I'm using clean allinone package.
Help
Luke
Re: Open Declaration in Classes PDT 2RC2 [message #87157 is a reply to message #87127] Fri, 19 December 2008 05:27 Go to previous messageGo to next message
Originally posted by: michael.zend.com
Can you give us some code example?
How $Article variable was declared?
Thanks!
"Piernik" <lpiernik@gmail.com> wrote in message
news:gifrg4$oel$1@build.eclipse.org...
> Hi
> In PDT 2 I can't
> Help
> Luke
Re: Open Declaration in Classes PDT 2RC2 [message #87170 is a reply to message #87157] Fri, 19 December 2008 05:46 Go to previous messageGo to next message
It's a big project
here is a part:
artykuly.php file:
require('common.php');
$Artykuly->pobierz_dane_artykulu($tytul_znaki);
$Statystyki->dodaj_odslone($Artykuly->artykul['id_artykulu'], 'art');
Hover on $Artykuly works
on ->pobierz_dane_artykulu doesn't
Hover on $Statystyki works
on ->dodaj_odslone doesn't
no compltions available (ctrl+spacebar) for $Artykuly,
pobierz_dane_artykulu, $Statystyki, dodaj_odslone...
common.php file
require_once('namiary.php');
require_once('config.php');
require_once('funkcje/statystyki.class.php');
require_once('funkcje/artykuly_relacje.class.php');
$Statystyki=new Statystyki(); //hover works
$Artykuly = new Artykuly_relacje(); //hover works
funkcje/artykuly_relacje.class.php file
class Artykuly_relacje {
public $artykuly;
public function __construct() {
global $Statystyki; //hover doesn't work
$this->artykul=$row; //hover works
$Statystyki->dodaj_odslone(); //hover doesn't work
public function pobierz_dane_artykulu($id) {
//code
funkcje/statystyki.class.php file is build in the same way.
Hope it will help.
Michael Spector pisze:
> Thanks!
>> Hi
>> In PDT 2 I can't
>> Help
>> Luke
Re: Open Declaration in Classes PDT 2RC2 [message #87188 is a reply to message #87170] Fri, 19 December 2008 05:56 Go to previous messageGo to next message
I can't re-create this with PDT 2.0.0 RC2.
Can you check the following:
1. Create new project, and test it there?
2. If (1) doesn't work for you, can you switch to another (new) workspace,
and test it there?
Thanks for your help!
news:gifu1q$5eh$1@build.eclipse.org...
> It's a big project
> here is a part:
> artykuly.php file:
> common.php file
> public $artykuly;
> //code
> Hope it will help.
>> Thanks!
>>> Hi
>>> In PDT 2 I can't
>>> Help
>>> Luke
Re: Open Declaration in Classes PDT 2RC2 [message #87202 is a reply to message #87188] Fri, 19 December 2008 06:21 Go to previous messageGo to next message
I've loaded a smaller project and it works in a part:
global $Galeria; // no completion
$Galeria->wgraj_obrazek(); //Galeria - no completion but wgraj_obrazek
completion and hover works.
So I think it dosen't work in the big projects.
I have Vista.
As I said before - works great in PDT 1 and I'm useing clear PDT 2 RC2
allinone copy - no changes in preferences and I'm creating project
adding new folders linked to file system
Cheers
> and test it there?
>> It's a big project
>> here is a part:
>> artykuly.php file:
>> common.php file
>> public $artykuly;
>> //code
>> Hope it will help.
>>> Thanks!
>>>> Hi
>>>> In PDT 2 I can't
>>>> Help
>>>> Luke
Re: Open Declaration in Classes PDT 2RC2 [message #87217 is a reply to message #87202] Fri, 19 December 2008 06:25 Go to previous messageGo to next message
And saying big project I mean 766 php files and 28000 different files
(ex photos which are also in project in a subfolder)
Piernik pisze:
> wgraj_obrazek completion and hover works.
> I have Vista.
> Cheers
>> workspace, and test it there?
>>> It's a big project
>>> here is a part:
>>> artykuly.php file:
>>> common.php file
>>> public $artykuly;
>>> //code
>>> Hope it will help.
>>>> Thanks!
>>>>> Hi
>>>>> In PDT 2 I can't
>>>>> Help
>>>>> Luke
Re: Open Declaration in Classes PDT 2RC2 [message #87310 is a reply to message #87217] Sat, 20 December 2008 03:09 Go to previous messageGo to next message
Are there any exceptions thrown?
There should be no difference either you use a small or a big project.
news:gig0bh$ko8$2@build.eclipse.org...
> And saying big project I mean 766 php files and 28000 different files (ex
> Piernik pisze:
>> I have Vista.
>> allinone copy - no changes in preferences and I'm creating project adding
>> Cheers
>>>> It's a big project
>>>> here is a part:
>>>> artykuly.php file:
>>>> common.php file
>>>> public $artykuly;
>>>> //code
>>>> Hope it will help.
>>>>> Thanks!
>>>>>> Hi
>>>>>> In PDT 2 I can't
>>>>>> Help
>>>>>> Luke
Re: Open Declaration in Classes PDT 2RC2 [message #87369 is a reply to message #87310] Sat, 20 December 2008 11:10 Go to previous messageGo to next message
No - no exceptions.
I've created new perspective - added this project - no exceptions -
default settings. Added linked folder and somehow - few classes worked
correctlly (completion and so on) - but only 2 of 10...
Those classes are build in the same way as others and works in pdt 1
Any ideas ?:)
>> Piernik pisze:
>>> I have Vista.
>>> Cheers
>>>>> It's a big project
>>>>> here is a part:
>>>>> artykuly.php file:
>>>>> common.php file
>>>>> public $artykuly;
>>>>> //code
>>>>> Hope it will help.
>>>>>> Thanks!
>>>>>>> Hi
>>>>>>> In PDT 2 I can't
>>>>>>> Help
>>>>>>> Luke
Re: Open Declaration in Classes PDT 2RC2 [message #87384 is a reply to message #87369] Sat, 20 December 2008 11:23 Go to previous messageGo to next message
All classes are listed in PHP Project Outline.
I don't know weather this is important:
I have 600 errors - mainlly in imported libraries like
- fckeditor
- pear
- phpmailer
- sitemapgenerator
Can I somehow exclude them from project? Build path->exclude doesn't
effect errors:/
Piernik pisze:
> No - no exceptions.
> Any ideas ?:)
>>> Piernik pisze:
>>>> I have Vista.
>>>> RC2 allinone copy - no changes in preferences and I'm creating
>>>> project adding new folders linked to file system
>>>> Cheers
>>>>>> It's a big project
>>>>>> here is a part:
>>>>>> artykuly.php file:
>>>>>> common.php file
>>>>>> public $artykuly;
>>>>>> //code
>>>>>> Hope it will help.
>>>>>>> Thanks!
>>>>>>>> Hi
>>>>>>>> the
>>>>>>>> In PDT 2 I can't
>>>>>>>> Help
>>>>>>>> Luke
Re: Open Declaration in Classes PDT 2RC2 [message #87428 is a reply to message #87384] Sun, 21 December 2008 02:30 Go to previous messageGo to next message
If you exclude something from buildpath, you won't see it in code assist.
Please show some code examples that can be used for reproduction of the
issue.
Thanks!
news:gij65g$lgr$1@build.eclipse.org...
> - fckeditor
> - pear
> - phpmailer
> - sitemapgenerator
> effect errors:/
> Piernik pisze:
>> No - no exceptions.
>> Any ideas ?:)
>>>> Piernik pisze:
>>>>> I have Vista.
>>>>> Cheers
>>>>>>> It's a big project
>>>>>>> here is a part:
>>>>>>> artykuly.php file:
>>>>>>> 'art');
>>>>>>> common.php file
>>>>>>> public $artykuly;
>>>>>>> //code
>>>>>>> Hope it will help.
>>>>>>>> Thanks!
>>>>>>>>> Hi
>>>>>>>>> the
>>>>>>>>> In PDT 2 I can't
>>>>>>>>> Help
>>>>>>>>> Luke
Re: Open Declaration in Classes PDT 2RC2 [message #87472 is a reply to message #87428] Mon, 22 December 2008 05:14 Go to previous messageGo to next message
Errors aren't important. Most important are completions and definitions.
Is there a way to fix it??
> issue.
> Thanks!
>> - fckeditor
>> - pear
>> - phpmailer
>> - sitemapgenerator
>> effect errors:/
>> Piernik pisze:
>>> No - no exceptions.
>>> Any ideas ?:)
>>>>> Piernik pisze:
>>>>>> I have Vista.
>>>>>> Cheers
>>>>>>>> It's a big project
>>>>>>>> here is a part:
>>>>>>>> artykuly.php file:
>>>>>>>> 'art');
>>>>>>>> common.php file
>>>>>>>> public $artykuly;
>>>>>>>> //code
>>>>>>>> Hope it will help.
>>>>>>>>> Thanks!
>>>>>>>>>> Hi
>>>>>>>>>> the
>>>>>>>>>> In PDT 2 I can't
>>>>>>>>>> Help
>>>>>>>>>> Luke
Re: Open Declaration in Classes PDT 2RC2 [message #87577 is a reply to message #87472] Tue, 23 December 2008 09:21 Go to previous messageGo to next message
Michael asked you to show code. He can't guess what's going wrong. I
suggest that either
- you send (a portion of) your project to Michael, together with an
example of what goes wrong. So he can check wether the problem is
reproducable, and if so, try to fix it.
- you try to isolate the problem yourselves.
It could of course be that errors hinders parsing thus breaking code
completion.
Hope this helps you both.
Re: Open Declaration in Classes PDT 2RC2 [message #88131 is a reply to message #87428] Fri, 02 January 2009 06:22 Go to previous message
I really Can't get to it what is wrong - even in new official 2.0 PDT.
I'll send to You in a private message - normal email - link to my
project. Hope You'll manage to fix it...
> issue.
> Thanks!
>> - fckeditor
>> - pear
>> - phpmailer
>> - sitemapgenerator
>> effect errors:/
>> Piernik pisze:
>>> No - no exceptions.
>>> Any ideas ?:)
>>>>> Piernik pisze:
>>>>>> I have Vista.
>>>>>> Cheers
>>>>>>>> It's a big project
>>>>>>>> here is a part:
>>>>>>>> artykuly.php file:
>>>>>>>> 'art');
>>>>>>>> common.php file
>>>>>>>> public $artykuly;
>>>>>>>> //code
>>>>>>>> Hope it will help.
>>>>>>>>> Thanks!
>>>>>>>>>> Hi
>>>>>>>>>> the
>>>>>>>>>> In PDT 2 I can't
>>>>>>>>>> Help
>>>>>>>>>> Luke
Previous Topic:New Projects
Next Topic:pdo_mysql driver
Current Time: Mon Nov 10 05:01:14 EST 2025
Powered by FUDForum. Page generated in 0.07154 seconds
