Home » Archived » Test and Performance Tools Platform (TPTP) » [AGR] NoClassDefFoundError while running test
[AGR] NoClassDefFoundError while running test [message #86981] |
Mon, 13 November 2006 17:46 |
--------------060409090700020206000108
We are upgrading from Eclipse 3.1 to 3.2 and TPTP 4.2.0 to 4.2.1. In the
old environment all of our tests executed fine. Now we are experiencing
class loading failures in the Axis library. The odd thing is that the
class that can not be found by name is in the same jar as the class that
is trying to load it, axis.jar. There are two other axis.jar in the
plugins, one is in the axis 1.3 plugin and the other is in one of the
BIRT plugins. In trying to isolate he problem I temporarily removed both
of these; this made no difference. The stacktrace is included below.
Any ideas appreciated.
Joel
!MESSAGE Message: Problem loading class:
org.apache.axis.attachments.AttachmentsImpl
java.lang.NoClassDefFoundError
at
org.apache.axis.handlers.BasicHandler.<clinit>(BasicHandler.java:43)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:242)
at org.apache.axis.utils.ClassUtils$2.run(ClassUtils.java:177)
at org.apache.axis.utils.ClassUtils.loadClass(ClassUtils.java:1 60)
at org.apache.axis.utils.ClassUtils.forName(ClassUtils.java:100 )
at
org.apache.axis.deployment.wsdd.WSDDTargetedChain.makeNewIns tance(WSDDTargetedChain.java:157)
at
org.apache.axis.deployment.wsdd.WSDDDeployableItem.getNewIns tance(WSDDDeployableItem.java:274)
at
org.apache.axis.deployment.wsdd.WSDDDeployableItem.getInstan ce(WSDDDeployableItem.java:260)
at
org.apache.axis.deployment.wsdd.WSDDDeployment.getTransport( WSDDDeployment.java:410)
at
org.apache.axis.configuration.FileProvider.getTransport(File Provider.java:257)
at org.apache.axis.AxisEngine.getTransport(AxisEngine.java:332)
at org.apache.axis.client.AxisClient.invoke(AxisClient.java:163 )
at org.apache.axis.client.Call.invokeEngine(Call.java:2784)
at org.apache.axis.client.Call.invoke(Call.java:2767)
at org.apache.axis.client.Call.invoke(Call.java:2443)
at org.apache.axis.client.Call.invoke(Call.java:2366)
at org.apache.axis.client.Call.invoke(Call.java:1812)
at
com.etish.useme.est.webservices.ServerWSSoapBindingStub.auth enticate(ServerWSSoapBindingStub.java:342)
at
com.etish.useme.client.base.core.services.ServerDelegate.val idate(ServerDelegate.java:859)
at
com.etish.useme.client.base.core.services.ServerLiaison.addS erverLocation(ServerLiaison.java:121)
at
com.etish.useme.client.editor.ui.wizards.serverlocation.Serv erLocationWizard.addLocation(ServerLocationWizard.java:90)
at
com.etish.useme.client.editor.ui.wizards.serverlocation.Serv erLocationWizard.performFinish(ServerLocationWizard.java:177 )
at
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:680)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:355)
at org.eclipse.jface.dialogs.Dialog$3.widgetSelected(Dialog.jav a:660)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:952)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:937)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:7 09)
at
org.eclipse.tptp.test.auto.gui.internal.commands.BooleanSele ctionCommand.doClick(BooleanSelectionCommand.java:490)
at
org.eclipse.tptp.test.auto.gui.internal.commands.BooleanSele ctionCommand.playback(BooleanSelectionCommand.java:294)
at
org.eclipse.tptp.test.auto.gui.internal.commands.MacroComman dShell$4.run(MacroCommandShell.java:1160)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3325)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at
org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:181)
at
org.eclipse.ui.actions.NewWizardDropDownAction.run(NewWizard DropDownAction.java:174)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:441)
at
at
at
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
<title></title>
</head>
<font face="Helvetica, Arial, sans-serif">Hi,<br>
<br>
the old environment all of our tests executed fine. Now we are
experiencing class loading failures in the Axis library. The odd thing
is that the class that can not be found by name is in the same jar as
the class that is trying to load it, axis.jar. There are two other
axis.jar in the plugins, one is in the axis 1.3 plugin and the other is
in one of the BIRT plugins. In trying to isolate he problem I
temporarily removed both of these; this made no difference. The
stacktrace is included below.<br>
<br>
Any ideas appreciated.<br>
<br>
Thanks,<br>
Joel<br>
</font>
<blockquote><font face="Helvetica, Arial, sans-serif"><font
face="Courier New, Courier, monospace">!MESSAGE Message: Problem
loading class: org.apache.axis.attachments.AttachmentsImpl</font></font><br >
face="Courier New, Courier, monospace">java.lang.NoClassDefFoundError</font></font><br >
face="Courier New, Courier, monospace"> at
org.apache.axis.handlers.BasicHandler.<clinit> (BasicHandler.java:43) </font></font><br>
java.lang.Class.forName0(Native Method)</font></font><br>
java.lang.Class.forName(Class.java:242)</font></font><br>
org.apache.axis.utils.ClassUtils$2.run(ClassUtils.java:177)</font ></font><br>
java.security.AccessController.doPrivileged(Native Method)</font></font><br>
org.apache.axis.utils.ClassUtils.loadClass(ClassUtils.java:1 60) </font></font><br>
org.apache.axis.utils.ClassUtils.forName(ClassUtils.java:100 ) </font></font><br>
org.apache.axis.deployment.wsdd.WSDDTargetedChain.makeNewIns tance(WSDDTargetedChain.java:157) </font></font><br>
org.apache.axis.deployment.wsdd.WSDDDeployableItem.getNewIns tance(WSDDDeployableItem.java:274) </font></font><br>
org.apache.axis.deployment.wsdd.WSDDDeployableItem.getInstan ce(WSDDDeployableItem.java:260) </font></font><br>
org.apache.axis.deployment.wsdd.WSDDDeployment.getTransport( WSDDDeployment.java:410) </font></font><br>
org.apache.axis.configuration.FileProvider.getTransport(File Provider.java:257) </font></font><br>
org.apache.axis.AxisEngine.getTransport(AxisEngine.java:332) </font></font><br>
org.apache.axis.client.AxisClient.invoke(AxisClient.java:163 ) </font></font><br>
org.apache.axis.client.Call.invokeEngine(Call.java:2784)</font ></font><br>
org.apache.axis.client.Call.invoke(Call.java:2767)</font></font ><br>
org.apache.axis.client.Call.invoke(Call.java:2443)</font></font ><br>
org.apache.axis.client.Call.invoke(Call.java:2366)</font></font ><br>
org.apache.axis.client.Call.invoke(Call.java:1812)</font></font ><br>
com.etish.useme.est.webservices.ServerWSSoapBindingStub.auth enticate(ServerWSSoapBindingStub.java:342) </font></font><br>
com.etish.useme.client.base.core.services.ServerDelegate.val idate(ServerDelegate.java:859) </font></font><br>
com.etish.useme.client.base.core.services.ServerLiaison.addS erverLocation(ServerLiaison.java:121) </font></font><br>
com.etish.useme.client.editor.ui.wizards.serverlocation.Serv erLocationWizard.addLocation(ServerLocationWizard.java:90) </font></font><br>
com.etish.useme.client.editor.ui.wizards.serverlocation.Serv erLocationWizard.performFinish(ServerLocationWizard.java:177 ) </font></font><br>
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:680) </font></font><br>
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:355) </font></font><br>
org.eclipse.jface.dialogs.Dialog$3.widgetSelected(Dialog.jav a:660) </font></font><br>
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90) </font></font><br>
org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66) </font></font><br>
org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)</font ></font><br>
org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:952)</font ></font><br>
org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:937)</font ></font><br>
org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:7 09) </font></font><br>
org.eclipse.tptp.test.auto.gui.internal.commands.BooleanSele ctionCommand.doClick(BooleanSelectionCommand.java:490) </font></font><br>
org.eclipse.tptp.test.auto.gui.internal.commands.BooleanSele ctionCommand.playback(BooleanSelectionCommand.java:294) </font></font><br>
org.eclipse.tptp.test.auto.gui.internal.commands.MacroComman dShell$4.run(MacroCommandShell.java:1160) </font></font><br>
org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5) </font></font><br>
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123) </font></font><br>
org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3325) </font></font><br>
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971) </font></font><br>
org.eclipse.jface.window.Window.runEventLoop(Window.java:820 ) </font></font><br>
org.eclipse.jface.window.Window.open(Window.java:796)</font ></font><br>
org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:181) </font></font><br>
org.eclipse.ui.actions.NewWizardDropDownAction.run(NewWizard DropDownAction.java:174) </font></font><br>
org.eclipse.jface.action.Action.runWithEvent(Action.java:499 ) </font></font><br>
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539) </font></font><br>
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488) </font></font><br>
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:441) </font></font><br>
</blockquote>
<font face="Helvetica, Arial, sans-serif"><br>
<br>
</font>
</body>
</html>
--------------060409090700020206000108--
Re: [AGR] NoClassDefFoundError while running test [message #87000 is a reply to message #86981] |
Mon, 13 November 2006 18:01 |
--------------040503070504040602090301
I guess I should have mentioned that the recording of the this test runs
fine without any exceptions and that I can run our plugin on its own
from the deployed plugins without a problem. The only time we experience
failure is when we are running the test case under AGR.
Joel
Joel Rosi-Schwartz wrote:
> is in one of the BIRT plugins. In trying to isolate he problem I
> Joel
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
<html>
<head>
</head>
<font face="Helvetica, Arial, sans-serif">I guess I should have
mentioned that the recording of the this test runs fine without any
exceptions and that I can run our plugin on its own from the deployed
plugins without a problem. The only time we experience failure is when
we are running the test case under AGR.<br>
<br>
Joel<br>
</font><br>
<blockquote cite="midejab22$2qc$1@utils.eclipse.org" type="cite">
<title></title>
<br>
<br>
<br>
Thanks,<br>
Joel<br>
</font>
</blockquote>
<br>
</font>
</blockquote>
</body>
</html>
--------------040503070504040602090301--
Re: [AGR] NoClassDefFoundError while running test [message #87044 is a reply to message #87000] |
Tue, 14 November 2006 08:12 |
Originally posted by: ffr.softwareag.com
I had a similar problem a few month ago. What I found out was that the
classpath settings (i.e. the content of environment variable CLASSPATH) that
were in effect while running an AGR test suite confused the eclipse class
loader somehow. After making sure that the CLASSPATH is really empty while
an AGR test executes the problem disappeared. I never had the class loading
problem when acting as a real user. The problem only occurred in context of
AGR execution. Maybe worth a try for you to do the same.
"Joel Rosi-Schwartz" <Joel.Rosi-Schwartz@Etish.org> wrote in message
news:ejabtq$h5h$1@utils.eclipse.org...
> Joel
>> Hi,
>> Thanks,
>> Joel
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: [AGR] NoClassDefFoundError while running test [message #87154 is a reply to message #87044] |
Tue, 14 November 2006 19:52 |
--------------090502020508000902010304
Thanks once again for assistance, but unfortunately this time it was not
the solution. I do not have the CLASSPATH set in the environment; it is
something that I learned very early on with Java was to always set the
classpath explicitly for every program I am launching IFF it needs one.
Joel
>> Joel
>>> Hi,
>>> Thanks,
>>> Joel
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
<html>
<head>
<title></title>
</head>
<font face="Helvetica, Arial, sans-serif">Thanks once again for
assistance, but unfortunately this time it was not the solution. I do
not have the CLASSPATH set in the environment; it is something that I
learned very early on with Java was to always set the classpath
explicitly for every program I am launching IFF it needs one. <br>
<br>
Cheers,<br>
Joel<br>
</font><br>
<blockquote cite="midejbtpr$5d4$1@utils.eclipse.org" type="cite">
<pre wrap="">I had a similar problem a few month ago. What I found out was that the
"Joel Rosi-Schwartz" <a class="moz-txt-link-rfc2396E" href="mailto:Joel.Rosi-Schwartz@Etish.org"><Joel.Rosi-Schwartz@Etish.org></a> wrote in message
<a class="moz-txt-link-freetext" href="news:ejabtq$h5h$1@utils.eclipse.org">news:ejabtq$h5h$1@utils.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">I guess I should have mentioned that the recording of the this test runs
Joel
</pre>
<pre wrap="">Hi,
Joel
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------090502020508000902010304--
Re: [AGR] NoClassDefFoundError while running test [message #87220 is a reply to message #87154] |
Wed, 15 November 2006 08:33 |
O.k., for me it was envvar CLASSPATH at that time. But there is another
thing: AGR builds up a complex class path for the JVM of the eclipse
instance in which an AGR test is executed. You really shoud check what's in
sysprop "java.class.path" while your test is executed (you can use a VH
method to do so). Due to my bad experience with envvar CLASSPATH, I now
always deliberately add '-classpath
"pathToEclipseRoot\startup.jar;pathToMyVHBinDirectory"' to the vmArguments
of the deployment in use. Only these two class path entries are necessary
for test execution as far as I understand. Anyway, after I switched to this
technique all of my mysterious class loading problems disappeared. Maybe
worth another try for you.
news:455A1E7B.6000508@Etish.org...
> Cheers,
> Joel
>> that
>> while
>> loading
>> of
>>> Joel
>>>> Hi,
>>>> Thanks,
>>>> Joel
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
Re: [AGR] NoClassDefFoundError while running test [message #87505 is a reply to message #87220] |
Wed, 15 November 2006 21:37 |
--------------020107040507060209090601
Could you please enlighten me on what VH is?
I would like to give this a go, but I am at a loss for how to set the
classpath explicitly for the AGR execution when I am starting it via the
Run menu in Eclipse. Are you inferring that I need to set up a test
harness outside of the workspace?
Joel
>> Cheers,
>> Joel
>>> that
>>> while
>>> loading
>>> of
>>>> Joel
>>>>> Hi,
>>>>> Thanks,
>>>>> Joel
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
<html>
<head>
</head>
<font face="Helvetica, Arial, sans-serif">Could you please enlighten me
on what VH is?<br>
<br>
the Run menu in Eclipse. Are you inferring that I need to set up a test
harness outside of the workspace? <br>
<br>
Thanks,<br>
Joel<br>
</font><br>
<blockquote cite="midejejdh$ker$1@utils.eclipse.org" type="cite">
<pre wrap="">O.k., for me it was envvar CLASSPATH at that time. But there is another
<a class="moz-txt-link-freetext" href="news:455A1E7B.6000508@Etish.org">news:455A1E7B.6000508@Etish.org</a>...
</pre>
<pre wrap="">Thanks once again for assistance, but unfortunately this time it was not
Joel
</pre>
that
while
loading
of
</pre>
Joel
</pre>
<pre wrap="">Hi,
Joel
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
</pre>
</blockquote>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
</body>
</html>
--------------020107040507060209090601--
Re: [AGR] NoClassDefFoundError while running test [message #87582 is a reply to message #87505] |
Thu, 16 November 2006 07:53 |
1. VH = verification hook
2. As far as I know you are using v4.2.1 (right?). Depending on this and
additionally depending on the assumption that you are using local_deployment
when using "Run", the only thing you would have to do is filling the field
labeled with "JVM Arguments:" on the Overview page of your test suite with
for example '-classpath
" absolutePathOfEclipseRoot\startup.jar;absolutePathOfMyVHBinD irectory " -Xms128m
-Xmx256m'.
Just to be very clear, here is the content of the field mentioned above of
one of my test suites:
-classpath
" D:\Temp\ffr\ecl-3.2.1\eclipse\startup.jar;D:\Temp\ffr\ecl-3. 2.1\workspaces\xxx-tests\XCIV22AutoGUITestContainer\bin "
-Xms128m -Xmx256m
If you are not using local_deployment, things are different. You need to set
variable vmArguments in your deployment then. The value for this variable
would be the same as you would enter into the input field mentioned above. I
didn't try out this way for v4.2.1 by now. With v4.1.0.1 it works as
described.
news:ejg1bq$oqc$1@utils.eclipse.org...
> Joel
>> in
>> vmArguments
>> this
>>> Cheers,
>>> Joel
>>>> that
>>>> class
>>>> while
>>>> loading
>>>> context
>>>> of
>>>>> runs
>>>>> experience
>>>>> Joel
>>>>>> Hi,
>>>>>> thing
>>>>>> Thanks,
>>>>>> Joel
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
Re: [AGR] NoClassDefFoundError while running test [message #87659 is a reply to message #86981] |
Thu, 16 November 2006 16:18 |
No real name Messages: 404 Registered: July 2009 |
------=_NextPart_000_005F_01C70970.EC2D08F0
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Hi Joel,
Is Axis.jar in a plug-in that you have declared a dependency on in your =
test plug-in (via the manifest file)?
Or is Axis.jar a standalone jar file that you've added as part of the =
build path (via the properties dialog of the project)?
At what point does the class not found error occur (during the execution =
of a verification hook or while executing macro commands)?
If you have a context defined under the overview page of the test suite, =
then you'll need to make sure that the context contains the correct =
plug-in.
Ali Mehregani
"Joel Rosi-Schwartz" <Joel.Rosi-Schwartz@Etish.org> wrote in message =
news:ejab22$2qc$1@utils.eclipse.org...
We are upgrading from Eclipse 3.1 to 3.2 and TPTP 4.2.0 to 4.2.1. In =
the old environment all of our tests executed fine. Now we are =
experiencing class loading failures in the Axis library. The odd thing =
is that the class that can not be found by name is in the same jar as =
the class that is trying to load it, axis.jar. There are two other =
axis.jar in the plugins, one is in the axis 1.3 plugin and the other is =
in one of the BIRT plugins. In trying to isolate he problem I =
temporarily removed both of these; this made no difference. The =
Joel
!MESSAGE Message: Problem loading class: =
at =
at =
org.apache.axis.deployment.wsdd.WSDDTargetedChain.makeNewIns tance(WSDDTar=
at =
org.apache.axis.deployment.wsdd.WSDDDeployableItem.getNewIns tance(WSDDDep=
at =
org.apache.axis.deployment.wsdd.WSDDDeployableItem.getInstan ce(WSDDDeploy=
ableItem.java:260)
at =
org.apache.axis.deployment.wsdd.WSDDDeployment.getTransport( WSDDDeploymen=
t.java:410)
at =
org.apache.axis.configuration.FileProvider.getTransport(File Provider.java=
:257)
at =
com.etish.useme.est.webservices.ServerWSSoapBindingStub.auth enticate(Serv=
at =
com.etish.useme.client.base.core.services.ServerDelegate.val idate(ServerD=
elegate.java:859)
at =
com.etish.useme.client.base.core.services.ServerLiaison.addS erverLocation=
at =
com.etish.useme.client.editor.ui.wizards.serverlocation.Serv erLocationWiz=
at =
ard.performFinish(ServerLocationWizard.java:177)
at =
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:680=
at =
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:355=
at =
at =
at =
at =
org.eclipse.tptp.test.auto.gui.internal.commands.BooleanSele ctionCommand.=
at =
at =
org.eclipse.tptp.test.auto.gui.internal.commands.MacroComman dShell$4.run(=
at =
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:1=
23)
at =
at =
at =
at =
org.eclipse.ui.actions.NewWizardDropDownAction.run(NewWizard DropDownActio=
n.java:174)
at =
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Act=
at =
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributi=
onItem.java:488)
at =
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContr=
at =
at =
at =
at =
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD><TITLE></TITLE>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.2900.2963" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Hi Joel,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Is Axis.jar in a plug-in that you have =
declared a=20
dependency on in your test plug-in (via the manifest =
file)?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Or is Axis.jar a standalone jar file =
that you've=20
added as part of the build path (via the properties dialog of the=20
project)?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>At what point does the class not found =
error occur=20
(during the execution of a verification hook or while executing macro=20
commands)?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>If you have a context defined under the =
overview=20
page of the test suite, then you'll need to make sure that the context =
contains=20
the correct plug-in.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Ali Mehregani</FONT></DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Joel Rosi-Schwartz" <<A=20
href=3D"mailto:Joel.Rosi-Schwartz@Etish.org">Joel.Rosi-Schwartz@Etish.org=
</A>>=20
wrote in message <A=20
href=3D"news:ejab22$2qc$1@utils.eclipse.org">news:ejab22$2qc$1@utils.ecli=
pse.org</A>...</DIV><FONT=20
face=3D"Helvetica, Arial, sans-serif">Hi,<BR><BR>We are upgrading from =
Eclipse=20
3.1 to 3.2 and TPTP 4.2.0 to 4.2.1. In the old environment all of our =
tests=20
executed fine. Now we are experiencing class loading failures in the =
Axis=20
library. The odd thing is that the class that can not be found by name =
is in=20
the same jar as the class that is trying to load it, axis.jar. There =
are two=20
other axis.jar in the plugins, one is in the axis 1.3 plugin and the =
other is=20
temporarily=20
removed both of these; this made no difference. The stacktrace is =
included=20
below.<BR><BR>Any ideas appreciated.<BR><BR>Thanks,<BR>Joel<BR></FONT>
<BLOCKQUOTE><FONT face=3D"Helvetica, Arial, sans-serif"><FONT=20
face=3D"Courier New, Courier, monospace">!MESSAGE Message: Problem =
loading=20
class: =
org.apache.axis.attachments.AttachmentsImpl</FONT></FONT><BR ><FONT=20
face=3D"Courier New, Courier, =
monospace">java.lang.NoClassDefFoundError</FONT></FONT><BR ><FONT=20
face=3D"Courier New, Courier, monospace"> at=20
org.apache.axis.handlers.BasicHandler.<clinit> (BasicHandler.java:43=
)</FONT></FONT><BR><FONT=20
java.lang.Class.forName0(Native Method)</FONT></FONT><BR><FONT=20
java.lang.Class.forName(Class.java:242)</FONT></FONT><BR> <FONT=20
org.apache.axis.utils.ClassUtils$2.run(ClassUtils.java:177)</FONT ></FONT>=
<BR><FONT=20
java.security.AccessController.doPrivileged(Native=20
Method)</FONT></FONT><BR><FONT face=3D"Helvetica, Arial, =
org.apache.axis.utils.ClassUtils.loadClass(ClassUtils.java:1 60) </FONT></F=
ONT><BR><FONT=20
org.apache.axis.utils.ClassUtils.forName(ClassUtils.java:100 ) </FONT></FON=
T><BR><FONT=20
getedChain.java:157)</FONT></FONT><BR><FONT=20
loyableItem.java:274)</FONT></FONT><BR><FONT=20
ableItem.java:260)</FONT></FONT><BR><FONT=20
t.java:410)</FONT></FONT><BR><FONT=20
:257)</FONT></FONT><BR><FONT=20
org.apache.axis.AxisEngine.getTransport(AxisEngine.java:332) </FONT></FONT=
><BR><FONT=20
org.apache.axis.client.AxisClient.invoke(AxisClient.java:163 ) </FONT></FON=
T><BR><FONT=20
org.apache.axis.client.Call.invokeEngine(Call.java:2784)</FONT ></FONT><BR=
><FONT=20
org.apache.axis.client.Call.invoke(Call.java:2767)</FONT></FONT ><BR><FONT=
=20
org.apache.axis.client.Call.invoke(Call.java:2443)</FONT></FONT ><BR><FONT=
=20
org.apache.axis.client.Call.invoke(Call.java:2366)</FONT></FONT ><BR><FONT=
=20
org.apache.axis.client.Call.invoke(Call.java:1812)</FONT></FONT ><BR><FONT=
=20
erWSSoapBindingStub.java:342)</FONT></FONT><BR><FONT=20
elegate.java:859)</FONT></FONT><BR><FONT=20
(ServerLiaison.java:121)</FONT></FONT><BR><FONT=20
ard.addLocation(ServerLocationWizard.java:90)</FONT></FONT ><BR><FONT=20
ard.performFinish(ServerLocationWizard.java:177)</FONT></FONT ><BR><FONT=20
org.eclipse.jface.dialogs.Dialog$3.widgetSelected(Dialog.jav a:660) </FONT>=
</FONT><BR><FONT=20
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90) <=
org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66) </FONT></=
FONT><BR><FONT=20
org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)</FONT ></FONT><B=
R><FONT=20
org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:952)</FONT ></FONT><B=
R><FONT=20
org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:937)</FONT ></FONT><B=
R><FONT=20
org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:7 09) </FONT></F=
ONT><BR><FONT=20
doClick(BooleanSelectionCommand.java:490)</FONT></FONT><BR ><FONT=20
playback(BooleanSelectionCommand.java:294)</FONT></FONT><BR ><FONT=20
MacroCommandShell.java:1160)</FONT></FONT><BR><FONT=20
org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5) </FONT></FO=
NT><BR><FONT=20
23)</FONT></FONT><BR><FONT=20
org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3325) </FONT=
></FONT><BR><FONT=20
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971) </FONT>=
</FONT><BR><FONT=20
org.eclipse.jface.window.Window.runEventLoop(Window.java:820 ) </FONT></FON=
T><BR><FONT=20
org.eclipse.jface.window.Window.open(Window.java:796)</FONT ></FONT><BR><F=
ONT=20
org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:181) </FON=
n.java:174)</FONT></FONT><BR><FONT=20
org.eclipse.jface.action.Action.runWithEvent(Action.java:499 ) </FONT></FON=
T><BR><FONT=20
ionContributionItem.java:539)</FONT></FONT><BR><FONT=20
onItem.java:488)</FONT></FONT><BR><FONT=20
ibutionItem.java:441)</FONT></FONT><BR><FONT=20
FONT><BR><FONT=20
R><FONT=20
R><FONT=20
R><FONT=20
ONT><BR><FONT=20
MacroCommandShell.java:1160)</FONT></FONT><BR></BLOCKQUOTE ><FONT=20
sans-serif"><BR><BR></BLOCKQUOTE></FONT></BODY></HTML>
------=_NextPart_000_005F_01C70970.EC2D08F0--
Re: [AGR] NoClassDefFoundError while running test [message #87918 is a reply to message #87659] |
Sat, 18 November 2006 15:20 |
--------------080803000707010109050700
Hi Ali,
As you may have seen already Frank's recommendation in this thread has
resolved the issue. :-) If you would still would find it useful to have
your questions below answered, please let me know I will be happy to
reply to the specifics.
What I wonder now, though, is whether or not this behavior is a bug that
should be reported. Why is this not a widely observed experience of
TPTP/AGR users? Are we doing something aberrant or have we simply
managed to uncover an infrequently exercised issue? Your opinion would
be appreciated.
Please let us know what we can do assist to resolve this in general.
Joel
Ali Mehregani wrote:
> Hi Joel,
> your test plug-in (via the manifest file)?
> execution of a verification hook or while executing macro commands)?
> suite, then you'll need to make sure that the context contains the
> correct plug-in.
> Ali Mehregani
> <mailto:Joel.Rosi-Schwartz@Etish.org>> wrote in message
> In the old environment all of our tests executed fine. Now we are
> thing is that the class that can not be found by name is in the
> are two other axis.jar in the plugins, one is in the axis 1.3
> plugin and the other is in one of the BIRT plugins. In trying to
> isolate he problem I temporarily removed both of these; this made
> Joel
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
<html>
<head>
</head>
<font face="Helvetica, Arial, sans-serif">Hi Ali,<br>
<br>
have your questions below answered, please let me know I will be happy
to reply to the specifics.<br>
<br>
that should be reported. Why is this not a widely observed experience
of TPTP/AGR users? Are we doing something aberrant or have we simply
be appreciated.<br>
<br>
Please let us know what we can do assist to resolve this in general.<br>
<br>
Thanks,<br>
Joel <br>
</font><br>
<blockquote cite="mideji30p$7mg$1@utils.eclipse.org" type="cite">
<title></title>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.2900.2963" name="GENERATOR">
<style></style>
<div><font face="Arial" size="2">Hi Joel,</font></div>
<div> </div>
<div><font face="Arial" size="2">Is Axis.jar in a plug-in that you
have declared a dependency on in your test plug-in (via the manifest
file)?</font></div>
<div><font face="Arial" size="2">Or is Axis.jar a standalone jar file
that you've added as part of the build path (via the properties dialog
of the project)?</font></div>
<div> </div>
<div><font face="Arial" size="2">At what point does the class not
found error occur (during the execution of a verification hook or while
executing macro commands)?</font></div>
<div><font face="Arial" size="2">If you have a context defined under
the overview page of the test suite, then you'll need to make sure that
the context contains the correct plug-in.</font></div>
<div> </div>
<div><font face="Arial" size="2">Thanks,</font></div>
<div><font face="Arial" size="2">Ali Mehregani</font></div>
<blockquote
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Joel Rosi-Schwartz" <<a
href="mailto:Joel.Rosi-Schwartz@Etish.org">Joel.Rosi-Schwartz@Etish.org</a>>
wrote in message <a href="news:ejab22$2qc$1@utils.eclipse.org">news:ejab22$2qc$1@utils.eclipse.org</a>...</div>
<br>
<br>
<br>
Thanks,<br>
Joel<br>
</font>
</blockquote>
<br>
</font></blockquote>
</blockquote>
</body>
</html>
--------------080803000707010109050700--
Re: [AGR] NoClassDefFoundError while running test [message #88235 is a reply to message #87918] |
Tue, 21 November 2006 17:14 |
------=_NextPart_000_0027_01C70D66.A257D940
Hi Joel,
I'm also interested to know why a test suite that runs fine in a =
TPTP4.1.0 environment is failing under TPTP4.2.0. I wonder if there is =
anything specific in your project structure that is causing this =
behavior. If you can provide me with a set of steps for reproducing =
this problem, then please open a defect. =20
If your test plug-in contains non-confidential material, then please =
attach it as part of the defect.
Ali Mehregani
news:ejn8ch$rr8$1@utils.eclipse.org...
Hi Ali,
As you may have seen already Frank's recommendation in this thread has =
resolved the issue. :-) If you would still would find it useful to have =
your questions below answered, please let me know I will be happy to =
What I wonder now, though, is whether or not this behavior is a bug =
that should be reported. Why is this not a widely observed experience of =
TPTP/AGR users? Are we doing something aberrant or have we simply =
managed to uncover an infrequently exercised issue? Your opinion would =
be appreciated.
Joel =20
Ali Mehregani wrote:=20
Hi Joel,
Is Axis.jar in a plug-in that you have declared a dependency on in =
Or is Axis.jar a standalone jar file that you've added as part of =
the build path (via the properties dialog of the project)?
At what point does the class not found error occur (during the =
If you have a context defined under the overview page of the test =
suite, then you'll need to make sure that the context contains the =
correct plug-in.
Ali Mehregani
"Joel Rosi-Schwartz" <Joel.Rosi-Schwartz@Etish.org> wrote in =
message news:ejab22$2qc$1@utils.eclipse.org...
We are upgrading from Eclipse 3.1 to 3.2 and TPTP 4.2.0 to 4.2.1. =
In the old environment all of our tests executed fine. Now we are =
Joel
at =
at =
at =
at =
at =
at =
ableItem.java:260)
at =
t.java:410)
at =
:257)
at =
at =
at =
at =
elegate.java:859)
at =
at =
at =
at =
at =
at =
at =
at =
at =
at =
at =
at =
at =
at =
23)
at =
at =
at =
at =
at =
n.java:174)
at =
at =
at =
onItem.java:488)
at =
at =
at =
at =
at =
at =
<META content=3D"MSHTML 6.00.2900.2963" name=3DGENERATOR></HEAD>
<DIV><FONT face=3DArial size=3D2>I'm also interested to know why a test =
suite that=20
runs fine in a TPTP4.1.0 environment is failing under TPTP4.2.0. I =
wonder=20
if there is anything specific in your project structure that is causing =
this=20
behavior. If you can provide me with a set of steps for =
reproducing this=20
problem, then please open a defect. </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>If your test plug-in contains =
non-confidential=20
material, then please attach it as part of the defect.</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
</A>>=20
href=3D"news:ejn8ch$rr8$1@utils.eclipse.org">news:ejn8ch$rr8$1@utils.ecli=
face=3D"Helvetica, Arial, sans-serif">Hi Ali,<BR><BR>As you may have =
seen=20
already Frank's recommendation in this thread has resolved the issue.=20
:-) If you would still would find it useful to have your =
questions below=20
answered, please let me know I will be happy to reply to the=20
specifics.<BR><BR>What I wonder now, though, is whether or not this =
behavior=20
is a bug that should be reported. Why is this not a widely observed =
experience=20
of TPTP/AGR users? Are we doing something aberrant or have we simply =
managed=20
to uncover an infrequently exercised issue? Your opinion would be=20
appreciated.<BR><BR>Please let us know what we can do assist to =
resolve this=20
in general.<BR><BR>Thanks,<BR>Joel <BR></FONT><BR>Ali Mehregani =
wrote:=20
<BLOCKQUOTE cite=3Dmideji30p$7mg$1@utils.eclipse.org type=3D"cite">
<STYLE></STYLE>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Is Axis.jar in a plug-in that you =
have declared=20
a dependency on in your test plug-in (via the manifest=20
file)?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Or is Axis.jar a standalone jar =
file that=20
you've added as part of the build path (via the properties dialog of =
the=20
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>At what point does the class not =
found error=20
occur (during the execution of a verification hook or while =
executing macro=20
<DIV><FONT face=3DArial size=3D2>If you have a context defined under =
the=20
overview page of the test suite, then you'll need to make sure that =
the=20
context contains the correct plug-in.</FONT></DIV>
<DIV> </DIV>
<BLOCKQUOTE=20
BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
</A>>=20
face=3D"Helvetica, Arial, sans-serif">Hi,<BR><BR>We are upgrading =
from=20
Eclipse 3.1 to 3.2 and TPTP 4.2.0 to 4.2.1. In the old environment =
all of=20
our tests executed fine. Now we are experiencing class loading =
failures in=20
the Axis library. The odd thing is that the class that can not be =
found by=20
name is in the same jar as the class that is trying to load it, =
axis.jar.=20
There are two other axis.jar in the plugins, one is in the axis =
1.3 plugin=20
and the other is in one of the BIRT plugins. In trying to isolate =
he=20
problem I temporarily removed both of these; this made no =
difference. The=20
stacktrace is included below.<BR><BR>Any ideas=20
face=3D"Courier New, Courier, monospace">!MESSAGE Message: =
Problem loading=20
class:=20
<BR><FONT=20
ONT><BR><FONT=20
T><BR><FONT=20
><BR><FONT=20
T><BR><FONT=20
><FONT=20
=20
=20
=20
=20
</FONT><BR><FONT=20
FONT><BR><FONT=20
R><FONT=20
R><FONT=20
R><FONT=20
ONT><BR><FONT=20
NT><BR><FONT=20
></FONT><BR><FONT=20
</FONT><BR><FONT=20
T><BR><FONT=20
ONT=20
T><BR><FONT=20
FONT><BR><FONT=20
R><FONT=20
R><FONT=20
R><FONT=20
ONT><BR><FONT=20
sans-serif"><BR><BR></FONT></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE ></BODY>=
</HTML>
------=_NextPart_000_0027_01C70D66.A257D940--
Current Time: Sat Apr 27 05:15:55 GMT 2024
Powered by FUDForum. Page generated in 0.03780 seconds
