Re: [EMF Compare] text compare instead of emf compare [message #87101 is a reply to message #86965] |
Fri, 22 June 2007 09:21 |
Originally posted by: user.domain.invalid
Bernd Kolb wrote:
> Hi!
> I just had a look to the new EMF-compare. I am using the latest I-Build
> (emft-compare-SDK-I200706191242).
> I tried to compare two files (default.itv, default2.itv) (see
> attachment) The files contain instances of a ecore-model (itv.ecore).
> But when comparing, I only get the text compare. Any idea? BTW: I can
> open both files with the reflective emf editor. So the ecore file was
> found.
> Thanks
> Bernd
You have to go to Preferences/General/Content Types , Click on "Model
File" & add *.itv" as a file association.
Adam
Re: [EMF Compare] text compare instead of emf compare [message #607033 is a reply to message #86965] |
Thu, 21 June 2007 11:56 |
Cedric Brun Messages: 431 Registered: July 2009 |
Hi Bernd !
The emf comparison will be launched if you add the "*.itv" extension in
the "Model File" content-type. You can do that with the preference pannel
in "General" then "Content types".
Do not hesitate to give feedback through this newsgroup.
Cédric
Bernd Kolb wrote:
> Hi!
> found.
> Thanks
> Bernd
http://cedric.brun.io news and articles on eclipse and eclipse modeling.
Re: [EMF Compare] text compare instead of emf compare [message #607038 is a reply to message #86965] |
Bernd Kolb wrote:
> Hi!
> found.
> Thanks
> Bernd
Adam
FUDForum. Page generated in 0.04672 seconds
