Home » Modeling » EMF » [CDO] Hibernate store mapping issue
Re: [CDO] Hibernate store mapping issue [message #768185 is a reply to message #768162] |
Mon, 19 December 2011 17:57 |
Yes just one side of a bi-directional association is represented in the database. Teneo uses a specific mechanism to
decide on which side of the bi-directional association the fk should be. It uses alphabetical ordering. This is needed
because Teneo needs to make the same choice consistently. I guess that is the reason that the 2 associations are mapped
in different directions.
But this does not explain the null value you get when retrieving the object. It seems that the database is not filled
with the correct values, can you check the content of the table and see if the OperationOutput column to InvokeOperation
has a value?
Can you post the relevant part of the hbm?
http://wiki.eclipse.org/CDO/Hibernate_Store/Model_Relational_Mapping#Generating_the_mapping.2C_manually_changing_it_and_then_use_the_manual_mapping
http://wiki.eclipse.org/CDO/Hibernate_Store/Configuration_and_Setup#How_to_enable_Hibernate_logging
gr. Martin
On 12/19/2011 06:22 PM, Dan Pollitt wrote:
> Hi all (Martin..),
> I'm seeing an issue in the OR mapping that has occurred where two references of a class are being handled quite
> differently.
> Extract of model I'm using:
> <eClassifiers xsi:type="ecore:EClass" name="InvokeOperation" eSuperTypes="#//Action">
> <eStructuralFeatures xsi:type="ecore:EReference" name="input" eType="#//OperationInput"
> containment="true" eOpposite="#//OperationInput/invokeOperation"/>
> <eStructuralFeatures xsi:type="ecore:EReference" name="output" eType="#//OperationOutput"
> containment="true" eOpposite="#//OperationOutput/invokeOperation"/>
> </eClassifiers>
> <eClassifiers xsi:type="ecore:EClass" name="OperationOutput">
> <eStructuralFeatures xsi:type="ecore:EReference" name="invokeOperation" eType="#//InvokeOperation"
> eOpposite="#//InvokeOperation/output"/>
> </eClassifiers>
> <eClassifiers xsi:type="ecore:EClass" name="OperationInput">
> eOpposite="#//InvokeOperation/input"/>
> </eClassifiers>
> The issue I'm seeing is that the input and output references of InvokeOperation are being mapped quite differently,
> input is a foreign key column in an InvokeOperation table but output is not, the OperationOutput table has a foreign key
> back to InvokeOperation but the OperationInput table does not. A guess is just one side of the bidirectional
> relationship is represented in the database?
> In my application code I create instances of the OperationInput and OperationOutput and set them on the InvokeOperation.
> This is fine for the duration of the CDO Server being up but if I restart the server and then retrieve my
> InvokeOperation instance then the InvokeOperation#getOutput() returns null.
> Is there som mapping help I should be providing here to ensure consistency or perhaps something peculiar to it being a
> bidirectional reference?
> Dan
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [CDO] Hibernate store mapping issue [message #768499 is a reply to message #768185] |
Tue, 20 December 2011 09:03 |
Dan Pollitt Messages: 55 Registered: August 2010 |
Member |
Hi Martin,
Yes I checked in the DB and the invokeOperation column of the
operationoutput table contains a null value.
I generated the hibernate mapping as you referenced and the sections of
the result relating to InvokeOperation, OperationInput and
OperationOutput are below:
== generated_hbm.xml ==
<class entity-name="OperationOutput" abstract="false" lazy="true"
table="`operationoutput`">
<meta attribute="eclassName" inherit="false">OperationOutput</meta>
<meta attribute="epackage"
inherit="false">http://www.example.com/2011/11/tester</meta>
<tuplizer entity-mode="pojo"
class="org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDORevisionTuplizer"
<tuplizer entity-mode="dynamic-map"
<id type="long" name="idcol" column="idcol"
access="org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDOSyntheticIdPropertyHandler">
<meta attribute="syntheticId" inherit="false">true</meta>
<generator class="native" />
</id>
<property name="resourceID"
type="org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDOIDUserType">
<column name="resource_id" />
</property>
<property name="containerID" type="string">
<column name="container_id" />
</property>
<property name="version" type="java.lang.Integer">
<meta attribute="version">true</meta>
<column name="version" />
</property>
<many-to-one name="invokeOperation" entity-name="InvokeOperation"
cascade="merge,persist,save-update,lock" not-null="false" lazy="false"
insert="true" update="true" />
<many-to-one name="assertions" entity-name="HasAssertions"
lazy="false" cascade="all" foreign-key="operationoutput_assertions"
insert="true" update="true" not-null="false">
<column not-null="false" unique="false"
name="`hasassertions_assertions_e_id`"
index="OperationOutput_assertions" />
</many-to-one>
<many-to-one name="storeRules" entity-name="HasStoreRules"
lazy="false" cascade="all" foreign-key="operationoutput_storerules"
name="`hasstorerules_storerules_e_id`"
index="OperationOutput_storeRules" />
</many-to-one>
</class>
<class entity-name="OperationInput" abstract="false" lazy="true"
table="`operationinput`">
<meta attribute="eclassName" inherit="false">OperationInput</meta>
</id>
</property>
</property>
</property>
<one-to-one name="invokeOperation" entity-name="InvokeOperation"
cascade="merge,persist,save-update,lock" lazy="false"
property-ref="input" />
<many-to-one name="values" entity-name="HasValues" lazy="false"
cascade="all" foreign-key="operationinput_values" insert="true"
<column not-null="false" unique="false" name="`hasvalues_values_e_id`"
index="OperationInput_values" />
</many-to-one>
lazy="false" cascade="all" foreign-key="operationinput_storerules"
index="OperationInput_storeRules" />
</many-to-one>
</class>
<joined-subclass entity-name="InvokeOperation"
abstract="false" lazy="true" extends="Action" table="`invokeoperation`">
<meta attribute="eclassName" inherit="false">InvokeOperation</meta>
<key>
<column name="`action_e_id`" />
</key>
<many-to-one name="operation" entity-name="Operation"
lazy="false" cascade="merge,persist,save-update,lock"
foreign-key="invokeoperation_operation"
<column not-null="false" unique="false" name="`operation_operation_e_id`"
index="InvokeOperation_operation" />
</many-to-one>
<many-to-one name="input" entity-name="OperationInput"
cascade="all" not-null="false" lazy="false" insert="true"
update="true" />
<one-to-one name="output" entity-name="OperationOutput"
cascade="all" lazy="false" property-ref="invokeOperation" />
</joined-subclass>
I'm not sure if that gives us any pointers?
Dan
> database. Teneo uses a specific mechanism to decide on which side of the
> ordering. This is needed because Teneo needs to make the same choice
> mapped in different directions.
> object. It seems that the database is not filled with the correct
> OperationOutput column to InvokeOperation has a value?
> gr. Martin
>> Hi all (Martin..),
>> differently.
>> </eClassifiers>
>> </eClassifiers>
>> </eClassifiers>
>> null.
>> Thanks,
>> Dan
Re: [CDO] Hibernate store mapping issue [message #768502 is a reply to message #768499] |
Tue, 20 December 2011 09:11 |
Member |
I've just checked and it doesn't matter which side of the bidirectional
relationship I set in client code, the invokeOperation column in the
OperationOutput table remains null.
Dan
On 20/12/2011 09:03, Dan Pollitt wrote:
> Hi Martin,
> </id>
> </property>
> </property>
> </property>
> </many-to-one>
> </many-to-one>
> </class>
> </id>
> </property>
> </property>
> </property>
> </many-to-one>
> name="`hasstorerules_storerules_e_id`" index="OperationInput_storeRules" />
> </many-to-one>
> </class>
> <key>
> </key>
> </many-to-one>
> cascade="all" not-null="false" lazy="false" insert="true" update="true" />
> </joined-subclass>
> Dan
>> gr. Martin
>>> Hi all (Martin..),
>>> differently.
>>> </eClassifiers>
>>> </eClassifiers>
>>> </eClassifiers>
>>> null.
>>> Thanks,
>>> Dan
Re: [CDO] Hibernate store mapping issue [message #768525 is a reply to message #768502] |
Tue, 20 December 2011 10:07 |
Hmm, I checked the mappings/model but I have no idea what happens here, can you enter a bugzilla for this (mapping of 2
bidirectional containment associations is done differently)? I am not sure if your model is very large or if I can use
it as an example in the testcases. I can try to replicate the issue in a small model, afaics it should be doable.
gr. Martin
On 12/20/2011 10:11 AM, Dan Pollitt wrote:
> I've just checked and it doesn't matter which side of the bidirectional relationship I set in client code, the
> invokeOperation column in the OperationOutput table remains null.
> Dan
>> Hi Martin,
>> </id>
>> </property>
>> </property>
>> </property>
>> </many-to-one>
>> </many-to-one>
>> </class>
>> </id>
>> </property>
>> </property>
>> </property>
>> </many-to-one>
>> </many-to-one>
>> </class>
>> <key>
>> </key>
>> </many-to-one>
>> </joined-subclass>
>> Thanks,
>> Dan
>>> gr. Martin
>>>> Hi all (Martin..),
>>>> differently.
>>>> </eClassifiers>
>>>> </eClassifiers>
>>>> </eClassifiers>
>>>> null.
>>>> Thanks,
>>>> Dan
The Netherlands
Re: [CDO] Hibernate store mapping issue [message #768538 is a reply to message #768525] |
Tue, 20 December 2011 10:32 |
Member |
Hi Martin,
I tried switching to the DBStore implementation for the repository (with
the same model) and it looks to work ok so that would suggest it isn't
an issue with my .ecore model.
I'll certainly raise a bugzilla - I'll need to replicate the issue in a
different model so that I can share it as an example. Once I've done
that, I'll post back here.
Dan
> can you enter a bugzilla for this (mapping of 2 bidirectional
> model is very large or if I can use it as an example in the testcases. I
> doable.
> gr. Martin
>> Dan
>>> Hi Martin,
>>> </id>
>>> </property>
>>> </property>
>>> </property>
>>> </many-to-one>
>>> </many-to-one>
>>> </class>
>>> </id>
>>> </property>
>>> </property>
>>> </property>
>>> </many-to-one>
>>> </many-to-one>
>>> </class>
>>> <key>
>>> </key>
>>> </many-to-one>
>>> update="true" />
>>> </joined-subclass>
>>> Thanks,
>>> Dan
>>>> the
>>>> gr. Martin
>>>>> Hi all (Martin..),
>>>>> differently.
>>>>> </eClassifiers>
>>>>> </eClassifiers>
>>>>> </eClassifiers>
>>>>> null.
>>>>> Thanks,
>>>>> Dan
Current Time: Fri Apr 26 13:25:56 GMT 2024
Powered by FUDForum. Page generated in 0.03688 seconds
