Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Child objects in DB have multiple references to parent.
Re: [Teneo] Child objects in DB have multiple references to parent. [message #86743 is a reply to message #86667] |
Mon, 18 June 2007 21:03 |
Hi Duncan,
For containment relations it is required that an extra column is used to store the econtainer
relation. This extra column is required to determine the container when the item is read from the db
indepedently from the parent. Although in your example the parent could also be read from the
itemscheme_item_urn this information is not necessarily present at hibernate (object) level of the
item (only the parent knows who its children are). Also it is possible to model the containment
association in a separate table of which the item does not 'officially' know that it is there.
If you don't read the items independently from the parent or are not interested in the containment
columns then there is an option to disable them.
The other thing you note, that the item is not removed is not how it should be, the relation has
delete-orphan which signals hibernate to remove the de-referenced items. Hibernate sees that the
item is not part anymore of the association as it nullifies the foreign-key to the parent. Can you
show me the update code?
gr. Martin
Duncan ALexander wrote:
> I noticed that Teneo generates multiple columns for references
> between a child and parent in a one-to-many relationship. I can
> understand what each of them represents but wonder why they both must
> exist independently and I think it is causing my orphan objects to not
> be deleted.
> For example, I have an object called ItemScheme which contains Items in
> a list.
> The mapping looks like:
> <subclass entity-name="base.ItemScheme" abstract="true" lazy="false"
> extends="base.Maintainable" discriminator-value="base.ItemScheme">
> <meta attribute="eclassName">ItemScheme</meta>
> <meta
> attribute="epackage">http://www.sdmx.org/resources/infomodel/1.0/base.xmi</meta>
> <list name="Item" lazy="true" cascade="all,delete-orphan">
> <key update="true">
> <column name="`itemscheme_item_urn`" not-null="false"
> unique="false"/>
> </key>
> <list-index column="`itemscheme_item_idx`"/>
> <one-to-many entity-name="base.Item"/>
> </list>
> </subclass>
> And when I look at the generated columns in the DB for Items I see the
> itemscheme_item_urn column which points to the parent but also an
> eContainer column which references the same parent.
> The problem I have is that if I update my ItemScheme from a dettached
> object with a different set of Items then I can correctly see my new
> items in the database with refernce to the ItemScheme parent.
> But I can see that the old Items which are no longer referenced still
> exist in the database with their itemscheme_item_urn field set to null,
> but the eContainer field still referencing the ItemScheme. I would
> expect the Item to be removed completely under these circumstances.
> duncan
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Child objects in DB have multiple references to parent. [message #86765 is a reply to message #86743] |
Tue, 19 June 2007 09:47 |
Duncan Alexander Messages: 90 Registered: July 2009 |
Member |
Hi Martin,
here is an example.
- I have seeded the database with a sublass of ItemScheme and Item called ConceptScheme and Concept
as follows, unique ids are shown in brackets :
conceptSchemeOne (urn:sdmx:org.sdmx.infomodel.conceptscheme.ConceptScheme=SDM X:conceptScheme1)
- concept1 (urn:sdmx:org.sdmx.infomodel.conceptscheme.Concept=SDMX:conc eptScheme1.concept1)
- concept2 (urn:sdmx:org.sdmx.infomodel.conceptscheme.Concept=SDMX:conc eptScheme1.concept3)
My database is dropped and recreated before each test to ensure a known start state. I then manually
create some 'detached' objects as follows (I am co-opting the unused URI field on the objects to add
some updated info which I can test against):
// Load the initial database values including those shown above then clear and close the session.
loadBaseRegistry();
// Create a detached version of the concept scheme
ConceptScheme conceptSchemeOne = ConceptSchemeFactory.eINSTANCE.createConceptScheme();
conceptSchemeOne.setUrn(" urn:sdmx:org.sdmx.infomodel.conceptscheme.ConceptScheme=SDMX :conceptScheme1 ");
conceptSchemeOne.setUri("UPDATED CONCEPT SCHEME");
// Create a detached version of concept one
Concept conceptOne = ConceptSchemeFactory.eINSTANCE.createConcept();
conceptOne.setUrn(" urn:sdmx:org.sdmx.infomodel.conceptscheme.Concept=SDMX:conce ptScheme1.concept1 ");
conceptOne.setUri("UPDATED CONCEPT ONE");
// Create a new concept
Concept conceptThree = ConceptSchemeFactory.eINSTANCE.createConcept();
conceptThree.setUrn(" urn:sdmx:org.sdmx.infomodel.conceptscheme.Concept=SDMX:conce ptScheme1.concept3 ");
conceptThree.setUri("NEW CONCEPT THREE");
// Add the concepts to the concept scheme
conceptSchemeOne.getItem().add(conceptOne);
conceptSchemeOne.getItem().add(conceptThree);
// open a session
Session session = teneoSession.getSession();
Transaction transaction = session.getTransaction();
transaction.begin();
session.update(conceptSchemeOne);
session.flush();
transaction.commit();
session.close();
If I then load conceptSchemeOne through Hibernate and check the Items it contains, this is correctly
shown as conceptOne and coneptThree but if I look in the DB I can still see conceptTwo exists.
The conceptTwo row no longer has a reference to its parent through the 'itemscheme_item_urn' column,
this is now set to null, but its eContainer column does still reference conceptSchemeOne.
I have traced the SQL which hibernate is producing for the above update, and it looks like this :
20:11:47,531 DEBUG LogPreparedStatement:83 - executing PreparedStatement: 'select concept_.`urn`,
concept_.`id` as id3_0_, concept_.`uri` as uri4_0_, concept_.`internationalstring_name_e_id` as
internat5_0_, concept_.`internationalstring_description_e_id` as internat6_0_,
concept_.econtainer_class as econtainer64_0_, concept_.e_container as e65_0_,
concept_.e_container_featureid as e66_0_, concept_.`version` as version7_0_, concept_.`startdate` as
startdate8_0_, concept_.`enddate` as enddate9_0_, concept_.`type_type_e_id` as type19_0_,
concept_.`representation_representation_e_id` as represe20_0_ from `base_identifiable` concept_
where concept_.`urn`=?' with bind parameters:
{1=urn:sdmx:org.sdmx.infomodel.conceptscheme.Concept=SDMX:co nceptScheme1.concept1}
20:11:47,640 DEBUG LogPreparedStatement:83 - executing PreparedStatement: 'select concept_.`urn`,
{1=urn:sdmx:org.sdmx.infomodel.conceptscheme.Concept=SDMX:co nceptScheme1.concept3}
20:11:53,625 DEBUG LogPreparedStatement:83 - executing PreparedStatement: 'insert into
`base_identifiable` (`id`, `uri`, `internationalstring_name_e_id`,
`internationalstring_description_e_id`, econtainer_class, e_container, e_container_featureid,
`version`, `startdate`, `enddate`, `type_type_e_id`, `representation_representation_e_id`, `dtype`,
`urn`) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, 'cs.Concept', ?)' with bind parameters:
{1=concept3, 2=NEW_CONCEPT, 3=663, 4=664, 5=cs.ConceptScheme,
6=urn:sdmx:org.sdmx.infomodel.conceptscheme.ConceptScheme=SD MX:conceptScheme1, 7=-12, 8=null,
9=null, 10=null, 11=null, 12=null,
13=urn:sdmx:org.sdmx.infomodel.conceptscheme.Concept=SDMX:co nceptScheme1.concept3}
20:11:53,640 DEBUG LogPreparedStatement:83 - executing PreparedStatement: 'update
`base_identifiable` set `id`=?, `uri`=?, `internationalstring_name_e_id`=?,
`internationalstring_description_e_id`=?, econtainer_class=?, e_container=?,
e_container_featureid=?, `version`=?, `startdate`=?, `enddate`=? where `urn`=?' with bind
parameters: {1=SDMX, 2=UPDATED_AGENCY, 3=657, 4=658, 5=base.SDMXContainer, 6=SDMXContainer, 7=-2,
8=null, 9=null, 10=null, 11=urn:sdmx:org.sdmx.infomodel.base.Agency=SDMX}
20:11:53,656 DEBUG LogPreparedStatement:83 - executing PreparedStatement: 'update
e_container_featureid=?, `version`=?, `startdate`=?, `enddate`=?, `agency_agency_urn`=? where
`urn`=?' with bind parameters: {1=conceptScheme1, 2=SUBMITTED CONCEPT SCHEME, 3=659, 4=660,
5=base.SDMXContainer, 6=SDMXContainer, 7=-2, 8=null, 9=null, 10=null,
11=urn:sdmx:org.sdmx.infomodel.base.Agency=SDMX,
12=urn:sdmx:org.sdmx.infomodel.conceptscheme.ConceptScheme=S DMX:conceptScheme1}
20:11:53,671 DEBUG LogPreparedStatement:83 - executing PreparedStatement: 'update
e_container_featureid=?, `version`=?, `startdate`=?, `enddate`=?, `type_type_e_id`=?,
`representation_representation_e_id`=? where `urn`=?' with bind parameters: {1=concept1,
2=UPDATED_CONCEPT, 3=661, 4=662, 5=cs.ConceptScheme,
13=urn:sdmx:org.sdmx.infomodel.conceptscheme.Concept=SDMX:co nceptScheme1.concept1}
20:11:53,734 DEBUG LogPreparedStatement:83 - executing PreparedStatement: 'update
`base_identifiable` set `item_item_urn`=null, `item_item_idx`=null where `item_item_urn`=?' with
bind parameters: {1=urn:sdmx:org.sdmx.infomodel.base.Agency=SDMX}
***###*** 20:11:53,765 DEBUG LogPreparedStatement:83 - executing PreparedStatement: 'update
`base_identifiable` set `itemscheme_item_urn`=null, `itemscheme_item_idx`=null where
`itemscheme_item_urn`=?' with bind parameters:
{1=urn:sdmx:org.sdmx.infomodel.conceptscheme.ConceptScheme=S DMX:conceptScheme1} ***###***
20:11:53,812 DEBUG LogPreparedStatement:83 - executing PreparedStatement: 'update
bind parameters: {1=urn:sdmx:org.sdmx.infomodel.conceptscheme.Concept=SDMX:co nceptScheme1.concept1}
20:11:53,906 DEBUG LogPreparedStatement:83 - executing PreparedStatement: 'update
`base_identifiable` set `itemscheme_item_urn`=?, `itemscheme_item_idx`=? where `urn`=?' with bind
parameters: {1=urn:sdmx:org.sdmx.infomodel.conceptscheme.ConceptScheme=S DMX:conceptScheme1, 2=0,
3=urn:sdmx:org.sdmx.infomodel.conceptscheme.Concept=SDMX:con ceptScheme1.concept1}
parameters: {1=urn:sdmx:org.sdmx.infomodel.conceptscheme.ConceptScheme=S DMX:conceptScheme1, 2=1,
3=urn:sdmx:org.sdmx.infomodel.conceptscheme.Concept=SDMX:con ceptScheme1.concept3}
It seems that Hibernate is setting the parent of all Items to be null one by one then setting the
parent of the items from the update to point to the correct concept scheme. See ***###***
I have tried to perform this equivalent update by loading the concept scheme from hibernate, closing
the session, removing the concept2, adding concept3 then reattaching and updating the conceptScheme
and this seems to work. i.e. It seems to remember that concept2 existed and therefore needs to
deleted. But this is not the way it will work in the real application, detached objects will always
be loaded from remote clients in a way similiar to above.
Duncan
Martin Taal wrote:
> Hi Duncan,
> store the econtainer relation. This extra column is required to
> determine the container when the item is read from the db indepedently
> from the itemscheme_item_urn this information is not necessarily present
> at hibernate (object) level of the item (only the parent knows who its
> children are). Also it is possible to model the containment association
> is there.
> interested in the containment columns then there is an option to disable
> them.
> should be, the relation has delete-orphan which signals hibernate to
> remove the de-referenced items. Hibernate sees that the item is not part
> parent. Can you show me the update code?
> gr. Martin
>> Hi,
>> be deleted.
>> in a list.
>> <meta
>> <key update="true">
>> unique="false"/>
>> </key>
>> </list> </subclass>
>> null, but the eContainer field still referencing the ItemScheme. I
>> would expect the Item to be removed completely under these circumstances.
>> duncan
Re: [Teneo] Child objects in DB have multiple references to parent. [message #86774 is a reply to message #86765] |
Tue, 19 June 2007 21:53 |
Hi Duncan,
I tested this same case and with session.update I got the same results as you (an orphanned child),
I then did session.merge and this worked (the orphaned child was removed).
See this part of the hibernate manual for some more info on the difference between save, update and
merge: 10.7. Automatic state detection
gr. Martin
> Hi Martin,
> here is an example.
> called ConceptScheme and Concept as follows, unique ids are shown in
> brackets :
> conceptSchemeOne
> - concept1
> - concept2
> start state. I then manually create some 'detached' objects as follows
> (I am co-opting the unused URI field on the objects to add some updated
> loadBaseRegistry();
> // open a session
> session.flush();
> session.close();
> contains, this is correctly shown as conceptOne and coneptThree but if I
> 'itemscheme_item_urn' column, this is now set to null, but its
> PreparedStatement: 'select concept_.`urn`, concept_.`id` as id3_0_,
> internat6_0_, concept_.econtainer_class as econtainer64_0_,
> concept_.e_container as e65_0_, concept_.e_container_featureid as
> `base_identifiable` concept_ where concept_.`urn`=?' with bind
> parameters:
> parameters:
> PreparedStatement: 'insert into `base_identifiable` (`id`, `uri`,
> `internationalstring_name_e_id`, `internationalstring_description_e_id`,
> econtainer_class, e_container, e_container_featureid, `version`,
> `representation_representation_e_id`, `dtype`, `urn`) values (?, ?, ?,
> 7=-12, 8=null, 9=null, 10=null, 11=null, 12=null,
> PreparedStatement: 'update `base_identifiable` set `id`=?, `uri`=?,
> e_container=?, e_container_featureid=?, `version`=?, `startdate`=?,
> `enddate`=? where `urn`=?' with bind parameters: {1=SDMX,
> `enddate`=?, `agency_agency_urn`=? where `urn`=?' with bind parameters:
> `enddate`=?, `type_type_e_id`=?, `representation_representation_e_id`=?
> where `urn`=?' with bind parameters: {1=concept1, 2=UPDATED_CONCEPT,
> PreparedStatement: 'update `base_identifiable` set `item_item_urn`=null,
> `item_item_idx`=null where `item_item_urn`=?' with bind parameters:
> bind parameters:
> 2=0,
> bind parameters:
> 2=1,
> one by one then setting the parent of the items from the update to point
> scheme from hibernate, closing the session, removing the concept2,
> adding concept3 then reattaching and updating the conceptScheme and this
> therefore needs to deleted. But this is not the way it will work in the
> real application, detached objects will always be loaded from remote
> Duncan
> Martin Taal wrote:
>> Hi Duncan,
>> to store the econtainer relation. This extra column is required to
>> read from the itemscheme_item_urn this information is not necessarily
>> present at hibernate (object) level of the item (only the parent knows
>> disable them.
>> gr. Martin
>>> Hi,
>>> not be deleted.
>>> in a list.
>>> <meta
>>> <key update="true">
>>> unique="false"/>
>>> </key>
>>> </list> </subclass>
>>> the itemscheme_item_urn column which points to the parent but also an
>>> circumstances.
>>> duncan
The Netherlands
Re: [Teneo] Child objects in DB have multiple references to parent. [message #86838 is a reply to message #86774] |
Wed, 20 June 2007 10:10 |
Member |
Hi Martin,
aha...yes, that works. I hadnt tried this again since solving issues with the version flag when I
had discounted its use. That seems to delete the orphan. Excellent, thanks for that.
It has thrown up a slight issue with our object design whereby trying to merge detached objects
which have related objects in tables with synthetic IDs are making the related objects appear as
transient and the merge baulks at this. BUT, this is solvable by moving to composite IDs for these
tables, I think. So, another step (leap) forward!
Many thanks
Duncan
Martin Taal wrote:
> Hi Duncan,
> as you (an orphanned child), I then did session.merge and this worked
> difference between save, update and merge: 10.7. Automatic state detection
> gr. Martin
>> Hi Martin,
>> here is an example.
>> brackets :
>> conceptSchemeOne
>> - concept1
>> - concept2
>> known start state. I then manually create some 'detached' objects as
>> loadBaseRegistry();
>> // open a session
>> session.flush();
>> session.close();
>> it contains, this is correctly shown as conceptOne and coneptThree but
>> parameters:
>> parameters:
>> e_container_featureid, `version`, `startdate`, `enddate`,
>> with bind parameters: {1=concept3, 2=NEW_CONCEPT, 3=663, 4=664,
>> 5=cs.ConceptScheme,
>> 4=660, 5=base.SDMXContainer, 6=SDMXContainer, 7=-2, 8=null, 9=null,
>> 10=null, 11=urn:sdmx:org.sdmx.infomodel.base.Agency=SDMX,
>> parameters: {1=concept1, 2=UPDATED_CONCEPT, 3=661, 4=662,
>> 5=cs.ConceptScheme,
>> with bind parameters: {1=urn:sdmx:org.sdmx.infomodel.base.Agency=SDMX}
>> bind parameters:
>> 2=0,
>> bind parameters:
>> 2=1,
>> and therefore needs to deleted. But this is not the way it will work
>> in the real application, detached objects will always be loaded from
>> Duncan
>> Martin Taal wrote:
>>> Hi Duncan,
>>> could also be read from the itemscheme_item_urn this information is
>>> not necessarily present at hibernate (object) level of the item (only
>>> the containment association in a separate table of which the item
>>> disable them.
>>> the parent. Can you show me the update code?
>>> gr. Martin
>>>> Hi,
>>>> must exist independently and I think it is causing my orphan objects
>>>> to not be deleted.
>>>> in a list.
>>>> <meta
>>>> <key update="true">
>>>> not-null="false" unique="false"/>
>>>> </key>
>>>> </list> </subclass>
>>>> an eContainer column which references the same parent.
>>>> dettached object with a different set of Items then I can correctly
>>>> see my new items in the database with refernce to the ItemScheme
>>>> parent.
>>>> still exist in the database with their itemscheme_item_urn field set
>>>> to null, but the eContainer field still referencing the ItemScheme.
>>>> I would expect the Item to be removed completely under these
>>>> circumstances.
>>>> duncan
Re: [Teneo] Child objects in DB have multiple references to parent. [message #607011 is a reply to message #86667] |
Hi Duncan,
gr. Martin
> be deleted.
> a list.
> <meta
> <key update="true">
> unique="false"/>
> </key>
> </list>
> </subclass>
> duncan
The Netherlands
Re: [Teneo] Child objects in DB have multiple references to parent. [message #607014 is a reply to message #86743] |
Member |
Hi Martin,
here is an example.
loadBaseRegistry();
// open a session
session.flush();
session.close();
Duncan
Martin Taal wrote:
> Hi Duncan,
> is there.
> them.
> gr. Martin
>> Hi,
>> be deleted.
>> in a list.
>> <meta
>> <key update="true">
>> unique="false"/>
>> </key>
>> </list> </subclass>
>> duncan
Re: [Teneo] Child objects in DB have multiple references to parent. [message #607017 is a reply to message #86765] |
Hi Duncan,
gr. Martin
> Hi Martin,
> here is an example.
> brackets :
> conceptSchemeOne
> - concept1
> - concept2
> loadBaseRegistry();
> // open a session
> session.flush();
> session.close();
> parameters:
> parameters:
> bind parameters:
> 2=0,
> bind parameters:
> 2=1,
> Duncan
> Martin Taal wrote:
>> Hi Duncan,
>> disable them.
>> gr. Martin
>>> Hi,
>>> not be deleted.
>>> in a list.
>>> <meta
>>> <key update="true">
>>> unique="false"/>
>>> </key>
>>> </list> </subclass>
>>> circumstances.
>>> duncan
The Netherlands
Re: [Teneo] Child objects in DB have multiple references to parent. [message #607020 is a reply to message #86774] |
Member |
Hi Martin,
Many thanks
Duncan
Martin Taal wrote:
> Hi Duncan,
> gr. Martin
>> Hi Martin,
>> here is an example.
>> brackets :
>> conceptSchemeOne
>> - concept1
>> - concept2
>> loadBaseRegistry();
>> // open a session
>> session.flush();
>> session.close();
>> parameters:
>> parameters:
>> 5=cs.ConceptScheme,
>> 5=cs.ConceptScheme,
>> bind parameters:
>> 2=0,
>> bind parameters:
>> 2=1,
>> Duncan
>> Martin Taal wrote:
>>> Hi Duncan,
>>> disable them.
>>> gr. Martin
>>>> Hi,
>>>> to not be deleted.
>>>> in a list.
>>>> <meta
>>>> <key update="true">
>>>> </key>
>>>> </list> </subclass>
>>>> parent.
>>>> circumstances.
>>>> duncan
Current Time: Fri Apr 26 06:07:57 GMT 2024
Powered by FUDForum. Page generated in 0.04530 seconds
