Home » Archived » BIRT » java.lang.IllegalStateException: getOutputStream() has already been called for this response(java.lang.IllegalStateException: getOutputStream() has already been called for this response)
java.lang.IllegalStateException: getOutputStream() has already been called for this response [message #766845] Fri, 16 December 2011 09:32 Go to next message
I am using Birt in struts application with tiles.
When I tried execute code, i got following exception.
at org.apache.catalina.connector.Response.getWriter(Response.java:611)
at org.apache.catalina.connector.ResponseFacade.getWriter(ResponseFacade.java:198)
at org.apache.jasper.runtime.JspWriterImpl.initOut(JspWriterImpl.java:125)
at org.apache.jasper.runtime.JspWriterImpl.flushBuffer(JspWriterImpl.java:118)
at org.apache.jasper.runtime.JspWriterImpl.flush(JspWriterImpl.java:173)
at org.apache.struts.taglib.tiles.InsertTag$InsertHandler.doEndTag(InsertTag.java:889)
at org.apache.struts.taglib.tiles.InsertTag.doEndTag(InsertTag.java:462)
at org.apache.jsp.WEB_002dINF.jsp.baseLayout_jsp._jspx_meth_tiles_005finsert_005f0(baseLayout_jsp.java:147)
at org.apache.jsp.WEB_002dINF.jsp.baseLayout_jsp._jspService(baseLayout_jsp.java:88)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:388)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:313)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:260)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:646)
at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:436)
at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:374)
at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:302)
at org.apache.struts.action.RequestProcessor.doForward(RequestProcessor.java:1083)
at org.apache.struts.tiles.TilesRequestProcessor.doForward(TilesRequestProcessor.java:295)
at org.apache.struts.tiles.TilesRequestProcessor.processTilesDefinition(TilesRequestProcessor.java:271)
at org.apache.struts.tiles.TilesRequestProcessor.processForwardConfig(TilesRequestProcessor.java:332)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:232)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1913)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:462)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at org.displaytag.filter.ResponseOverrideFilter.doFilter(ResponseOverrideFilter.java:125)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:291)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:602)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
at java.lang.Thread.run(Unknown Source)
It works fine in Web application using Servlets only.
But when i execute it through struts application.
It gives above exception.
Here is code where for action method
public ActionForward generateResignReport(ActionMapping mapping, ActionForm form, HttpServletRequest request, HttpServletResponse response)
LOGGER.info("Generate Resignation reprot");
ReportForm reportForm = (ReportForm) form;
EXCELRenderOption excelOptions = null;
PDFRenderOption pdfOptions = null;
String reportFile = "resignationReports.rptdesign";
ReportGenerator generator = new ReportGenerator();
IRunAndRenderTask task;
try {
if ((reportForm.getReportType()).equalsIgnoreCase("excel")) {
// Create task for rendering the reports
task = generator.createTask(request, reportFile);
// task.setParameterValue("RP_VERSIONNING", 0);
excelOptions = generator.generateExcelReport();
// response.resetBuffer();
response.setContentType("application/xls");
response.setHeader("Content-Disposition", "attachment; filename=\"ResignationListReport.xls\"");
excelOptions.setOutputStream(response.getOutputStream());
task.setRenderOption(excelOptions);
else {
pdfOptions = generator.generatePdfReport();
response.setContentType("application/pdf");
response.setHeader("Content-Disposition", "attachment; filename=\"ResignationListReport.pdf\"");
pdfOptions.setOutputStream(response.getOutputStream());
task.setRenderOption(pdfOptions);
// run report
task.run();
task.close();
catch (EngineException e) {
LOGGER.info("EngineException :" + e.getMessage());
catch (IOException e) {
LOGGER.info("IOException :" + e.getMessage());
catch (IllegalStateException e) {
LOGGER.info("IllegalStateException :" + e.getMessage());
return mapping.findForward("showReports");
Plz, If you have any suggestions for tackling this problem, let me know.
Thanks in advance.
Re: java.lang.IllegalStateException: getOutputStream() has already been called for this response [message #766921 is a reply to message #766845] Fri, 16 December 2011 11:49 Go to previous message
Take a look at this post, it is Struts 2 but it may be helpful.
http://birtworld.blogspot.com/2010/02/birt-and-struts-2.html
Specifically Struts 2 with the report engine.
Jason
On 12/16/2011 9:32 AM, Rohit wrote:
> Hi, I am using Birt in struts application with tiles.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> try {
> else {
> // run report
> task.run();
> task.close();
> Thanks in advance.
Previous Topic:Programatically setting a value in crosstab cell
Next Topic:Dynamic BIRT help
Current Time: Thu Aug 07 22:57:33 EDT 2025
Powered by FUDForum. Page generated in 0.04138 seconds
