Home » Eclipse Projects » Eclipse 4 » Bug persistance model Part
Bug persistance model Part [message #766207] Thu, 15 December 2011 06:11 Go to next message
When parts are created through the EPartService and when these parts register events initialized with @UIEventTopic, the references to these events are never removed when the parts are closed with the function partService.hidePart(LogView.ID, true);
Controleur.java
MPart part = partService.findPart(LogView.ID);
if (part == null) {
part = partService.createPart(LogView.ID);
if (part != null) {
part.setLabel("DBLogView");
part.setTooltip("Tooltip");
partService.showPart(part, PartState.CREATE);
PartTest.java
@Inject
public void onEventReceptionListeLocalites(
@Optional @UIEventTopic("com/test/mon/topic") String test) {
if(test!= null) {
// Ok
In the EventObjectSupplier file, the functions unsubscribe and/or dispose are never executed. The part still has in memory a reference to these events.
Otherwise, is there a means to remove the reference to an event declared with an EventTopic or UIEventTopic annotation?
Re: Bug persistance model Part [message #766827 is a reply to message #766207] Fri, 16 December 2011 08:53 Go to previous messageGo to next message
Do you mean your MPart implemented is hidden and @PreDestroy is called, but the topic keeps firing into it?
PW
Re: Bug persistance model Part [message #766855 is a reply to message #766827] Fri, 16 December 2011 09:54 Go to previous messageGo to next message
Yes. The function with the @PreDestroy annotation is called and the topic is still firing into this MPart.
Witch seems to be a memory leak, right?
Is there a workaround to avoid this problem?
Re: Bug persistance model Part [message #766981 is a reply to message #766855] Fri, 16 December 2011 14:36 Go to previous message
No, there's no workaround as we haven't seen that problem. Please open a bug with a description (and some example code) at https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform&component=UI
PW
Previous Topic:Create dropdown menu in toolbar
Next Topic:Branding not working
Current Time: Sun Nov 09 06:51:54 EST 2025
Powered by FUDForum. Page generated in 0.03425 seconds
