Re: How to deal with two plugins contributing each other [message #766068 is a reply to message #765764] |
Thu, 15 December 2011 07:14 |
Daniel Krügler Messages: 853 Registered: July 2009 |
On 2011-12-14 17:32, Behnil wrote:
>> Simple: Don't do that.
> Well, my client needs it. I used Table and List for simplicity, but in
> fact the first UI plugin visualizes the model in graph and the second UI
> plugin visualizes model in Table.
I just recognize that I misunderstood the sentence to which I replied
that way. You might have noticed that, because both solutions were
intended to realize what you wanted to do.
>> Yes, so why doesn't the first and second UI plugin provide the
>> corresponding "show model in a ..." contribution?
> I don't understand. Those two plugins are independent each other. But I
> think its regular requirement from users to see the model in the table
> and then to open the same model in List (or graph, or something else...).
Well you have not given much context information to us: It was
completely unclear in which way the model plugin would have any
opportunity to provide these "show model in a ..." presentations,
contributions, what ever you meant.
> The situation:
Yeah, would have been great if you would have described the situation in
the first place ;-)
> You are looking at a table showing a model. The table is within an
> dialog which is from UI plugin A. Now you would like to see this model
> in graph (or list in this simplified example)
So UI plugin A has a table with a context menu, and other UI plugins can
extend this - what is the problem with such an approach?
> So you, as a user, expect a context menu item "show this model in graph
> (list)" which would open an dialog with graph (list). This dialog is
> from UI plugin B.
> This one side contribution is easy, because I can create an extension
> point in UI plugin A and let other plugins (B) to contribute theirs
> actions.
Exactly.
> There would be an interface which contributor would implement
> in theirs contributions.
Here the fuzziness factor increases again: What interface are you
talking about? Why isn't it sufficient to depend here on types from the
model plugin?
> So all plugins contributing to the UI plugin A
> would be depended on that plugin.
I would expect that this is the model plugin, so what is the problem? If
it isn't you should move this dependency to a "base UI plugin" that all
real UI plugins depend on.
> But I also need "show this model in table" in context menu of the graph.
> The graph (list) is shown in a dialog which is from UI plugin B. And
> this is problem.
This shouldn't be a problem, if the mystical interface that you
mentioned above is part of the model plugin. If that doesn't work, it
should be part of a very base UI plugin that you need to supply.
> Because I can't create the same extension like in plugin A and let
> plugin A contribute to it. It would mean the plugin A is depended on
> plugin B and it's forbidden to have cycle dependencies.
Not only forbidden, but just plain bad design, because for non-obvious
reasons UI plugin A has some preferences over UI plugin B.
>> Alternatively your model plugin could provide an extension point that
>> allows other plugins to contribute a "show model in ..." extension. Both
>> UI plugins would register correspondingly.
> I think that model plugin should be just a "stupid"" container for model
> classes. It shouldn't have any UI.
Well, you didn't really explain what you mean in the first place. I
understood your explanation that the model plugin has the responsibility
to show these texts.
HTH & Greetings from Bremen,
Daniel Krügler
Re: How to deal with two plugins contributing each other [message #766106 is a reply to message #765823] |
Thu, 15 December 2011 08:32 |
Hi Behnil,
> They are shown unfortunately in dialog. I know the way to contribute to
> menu using the org.eclipse.ui.menu extension point. But this is not the
> situation.
In my understanding this would mean that there is a third UI plugin
which provides the dialog? Let's call this third plugin C. Why don't you
provide an extension point in C which A and B will extend? Then I
wouldn't do so much trouble with popup menus in plugins A and B. No, I
would provide tabs. In each tab one extension is displayed having the
name "table" or "graph" and the respective visualization of your model.
best regards,
Gilbert
FUDForum. Page generated in 0.02226 seconds
