Re: Can Buckminster headless launch a *.launch file for external tools? [message #765553 is a reply to message #765542] |
Wed, 14 December 2011 09:41 |
Hi Matthew,
For reasons unknown to me, the externaltools where written without a clean separation between headless and UI
components. This means that it's less straight forward to run it headlessly. First, you must install all needed UI
components which will make the headless tool quite large.
So, the answer is yes, Buckminster is able to launch it, but a lot of stuff must be installed first.
- thomas
On 2011-12-14 10:31, Matthew Webber wrote:
> I attempted to use the headless buckminster "launch" command to run a *.launch file that specifies an external tool. I
> got the following error message:
> Launch configuration type id "org.eclipse.ui.externaltools.ProgramLaunchConfigurationType" does not exist.
> Possible causes:
> Missing specification of a launch type (missing plug-in)
> Incorrect launch configuration XML
> Is headless buckminster able to run this type of launch file?
> Thanks
> Matthew
FUDForum. Page generated in 0.02686 seconds
