Birt Runtime Error [message #764610] |
Mon, 12 December 2011 14:23 |
Dear All ,
I have Error in Birt Run-time (web Part)
When I use it to view My Reports .
I am using Tomcat application server
note : The image of Error appears in my Uploaded image.
Attachment: Birt.png
(Size: 127.74KB, Downloaded 189 times)
[Updated on: Mon, 12 December 2011 14:26] Report message to a moderator
Re: Birt Runtime Error [message #764707 is a reply to message #764610] |
Mon, 12 December 2011 17:51 |
Do you have cookies enabled?
Jason
On 12/12/2011 9:23 AM, magd wrote:
> Dear All ,
> When I tried view My Report
> note : The Error appears in my Uploaded image
> Thanks
Re: Birt Runtime Error [message #765737 is a reply to message #765301] |
Wed, 14 December 2011 15:40 |
What app server did you deploy the viewer on? Is it behind a proxy?
Try using the /run mapping instead of the /frameset mapping as a test.
Jason
On 12/13/2011 3:05 PM, magd wrote:
> Please see the uploaded image because it show the Error.
> Magd
Re: Birt Runtime Error [message #766329 is a reply to message #765835] |
Thu, 15 December 2011 15:03 |
How did you deploy the viewer? Can you try just copying the
WebViewerExample folder to tomcat's webapps directory?
Jason
On 12/14/2011 1:45 PM, magd wrote:
> The Run mode is not working
> The frame-set mode is not working
> The preview mode is working successfully
> Thanks
> To you MR Jason
Re: Birt Runtime Error [message #768124 is a reply to message #767579] |
Mon, 19 December 2011 16:07 |
Win 7, should be fine. I am running the viewer on tomcat on win 7. Do
you get anything in the tomcat logs?
Jason
On 12/18/2011 6:47 AM, magd wrote:
> what is most os you like to use it ?
Re: Birt Runtime Error [message #768328 is a reply to message #768165] |
Mon, 19 December 2011 23:07 |
Only if I set the log level in the web.xml of the viewer.
Jason
On 12/19/2011 12:28 PM, magd wrote:
> I don't get any thing in Birt logs files. Do you get any thing in Birt
> logs ?
Re: Birt Runtime Error [message #768703 is a reply to message #768657] |
Tue, 20 December 2011 16:23 |
Do you get this error with Fire Fox and IE or just Chrome.
Jason
On 12/20/2011 10:02 AM, magd wrote:
> The problem is getting empty files in Birt log.
> what is solution in this problem?
Re: Birt Runtime Error [message #768831 is a reply to message #768780] |
Tue, 20 December 2011 22:20 |
I do not know why this is happening on a vanilla viewer install. Can
you try a different version of Tomcat as a test?
Jason
On 12/20/2011 2:31 PM, magd wrote:
> firefox and google chrome
> make this problem
> firefox create lck file
> chrome create text file
Re: Birt Runtime Error [message #769746 is a reply to message #769688] |
Thu, 22 December 2011 16:12 |
I do not think this is a logging issue. Did you try a different version
of tomcat?
Jason
On 12/22/2011 9:37 AM, magd wrote:
> can I use log4j to avoid this problem ?
Re: Birt Runtime Error [message #771586 is a reply to message #770518] |
Tue, 27 December 2011 17:31 |
I do not know what the issue is. Can you show me your setup on Skype?
Jason
On 12/24/2011 9:09 AM, magd wrote:
> also I tried to put log4j jar files
> in platform but I still facing this problem
FUDForum. Page generated in 0.05233 seconds
