Re: xls output and wrong file format on Excel 2007 [message #764699 is a reply to message #764481] |
Mon, 12 December 2011 17:39 |
Nicklas,
The content type is set in the plugin.xml for the emitter and the
extension used is set in the viewer.properties for the deployed viewer:
# [EXTENSION SETTING]
viewer.extension.html=html
viewer.extension.pdf=pdf
viewer.extension.postscript=ps
viewer.extension.doc=doc
viewer.extension.xls=xls
viewer.extension.ppt=ppt
viewer.extension.ods=ods
viewer.extension.odt=odt
viewer.extension.odp=odp
You could change both but I do not think it will work because the xls
emitter does not generate xlsx files.
Jason
On 12/12/2011 4:21 AM, Nicklas Karlsson wrote:
> I read some topics on the "The file you are trying to open is of
> different format..." and I tried to make a filename-generator-impl that
> would produce .xlsx files but that didn't help either. Is there any way
> to control the response content-type headers?
FUDForum. Page generated in 0.03423 seconds
