Re: Dynamic Report; No Values Appear [message #764657 is a reply to message #763413] |
Mon, 12 December 2011 15:49 |
So you use a list item bound to your dataset and have a nested table in
the the list item detail row? If you you want labels for each row why
not use a grid instead of a table. Why are you inserting a row into the
table? Is the code that inserts the row called before the report is
executed or is it in an event?
Jason
On 12/9/2011 1:12 PM, John Roberts wrote:
> Any help would be appreciated:
> I have a report structured as follows; A list where each item is a
> table. The table is 2 columns with item name and item value.
> ID 2
> Name Sam
> ID 4
> Name Sue
> etc.
> So I see the table created the expected number of times, e.g., I expect
> three return records and I see three tables. The field names are there.
> But the field values are blank.
> I cannot paste the code in because it's on an internal network - but
> here's some snippets;
> table.insertRow(new RowOperationParameters(2,-1,row));
> RowHandle rowHandle = (RowHandle) table.getDetail(row);
> CellHandle valueCell = (CellHandle) rowHandle.getCells().get(1); //
> value cell
> TextItemHandle text = designFactory.newTextItem("someName");
> text.setContentType(DesignChoiceContsants.TEXT_DATA_CONTENT_TYPE_HTML);
> text.setContent("<VALUE-OF>row[\"FieldName\"]</VALUE-OF>");
> valueCell.getContent().add(text);
> Any ideas?
Re: Dynamic Report; No Values Appear [message #765738 is a reply to message #765303] |
Wed, 14 December 2011 15:44 |
John,
Is the text element in a table that is bound to a data set?
BTW are your setting?
text.setContentType( DesignChoiceConstants.TEXT_CONTENT_TYPE_HTML );
Jason
On 12/13/2011 3:08 PM, John Roberts wrote:
> Ok - I tried a grid instead of a table - same thing. The problem is that
> text.setContent("<VALUE-OF>row[\"FieldName\"]</VALUE-OF>"); does not
> produce a value.
FUDForum. Page generated in 0.03561 seconds
