Re: How-to install RAP 1.4.1 as target platform [message #761979 is a reply to message #761969] |
Wed, 07 December 2011 11:30 |
Hi and welcome to RAP!
>> This is a target platform, do not try to install it into the Eclipse IDE
> Q1: What does that mean?
> In the zip file I see the folders eclipse/plugins and eclipse/features.
> Which means it is intended to be installed into my Eclipse IDE, isn't it?
No, it's not! It's intended to go into your target platform, not the IDE
itself.
> Q2: How to upgrade to 1.4.1?
> In my sample RAP project I see there is target file "myproject.target"
> containing a folder to the RAP jars:
> <location path="${project_loc}/target/rap-platform" type="Directory"/>
> In this folder I see all the 29 rap jars (org.eclipse.rap.XXX) and also
> other jars. Looking into your zip these has change among other jars.
> I guess I just remove all jars in this rap folder and replace them by
> the jars provided in the zip?
Yes, that will work. I'd recommend to extract the zip to a folder, name
it rap-runtime-1.4.1, create a new target definition (New ... > Target
Definition), and add this directory to it. There are other ways to do
it, but this one is the easiest.
> Q3: Which configurations changes are needed?
> In the sample project I see in the MANIFEST.MF file this entry:
> Require-Bundle: org.eclipse.rap.ui;bundle-version="1.4.1"
> I changed the version from 1.4.0 to 1.4.1.
> But after that I get an error from eclipse: "Unsatisfied version
> constraint". Also I get compile errors.
If your application works with 1.4.0 as well, there's no need to change
the version range. Just install the new target platform, that's it.
Hope this helps, Ralf
Ralf Sternberg
Twitter: @EclipseRAP
FUDForum. Page generated in 0.02259 seconds
