Home » Modeling » TMF (Xtext) » separate spec generation from model
separate spec generation from model [message #761939] Wed, 07 December 2011 05:22 Go to next message
I'am working on xtext for canonical data model (sd-dsl on eclipse labs)
I want to separate an Xtext spec model generation to model.
1 model entity
Model
Entity
2 model spec gen reference the entity model
Spec
Root=[Entity]
When I change the model and save it, I want to read the spec generation to customize the generation.
its possible to associate a spec file whith same name and differente extention.
myentity.entity
myentity.spec
in generator retreive the spec model to generate whith spec
do you have solution to do that simply ?
thank a lot for yor wonderfull work.
Re: separate spec generation from model [message #762128 is a reply to message #761939] Wed, 07 December 2011 10:35 Go to previous messageGo to next message
Either I don't understand the question or it is almost trivial to accomplish this in Xtext. I'm guessing that you need 2 Xtext DSLs: one for the .entity files and one for the .spec files. Implementing a generator for the spec gen DSL would take care of the generation. You would need some extra work if the 2 files matched on the basis of their name instead on some explicit import.
Re: separate spec generation from model [message #762557 is a reply to message #762128] Thu, 08 December 2011 04:51 Go to previous message
Hi ,
The spec point on root entity representing the message root view.
the spec instances modification start the generation
The entity model change frequently
When I save model entity instances after modification I need to refresh or force the spec model generation for entities.
Sorry for my poor english
best regards
Previous Topic:Is Xtext good solution for my project?
Next Topic:What is the intention of invoking serialization when calling XtextResource.save()?
Current Time: Wed Nov 05 17:01:31 EST 2025
Powered by FUDForum. Page generated in 0.03808 seconds
