Re: Warnings when rendering chart to svg [message #762245 is a reply to message #761893] |
Wed, 07 December 2011 18:54 |
Are you using the chart engine api or the report engine api? If you are
using the chart engine api are you setting this property?
idr.setProperty( IDeviceRenderer.UPDATE_NOTIFIER,
new EmptyUpdateNotifier( cm, gcs.getChartModel( ) ) );
Jason
On 12/7/2011 3:48 AM, js wrote:
> When I render my chart to svg using the birt api (3.7) I get all these
> warnings:
> 07-12-2011 09:40:50
> org.eclipse.birt.chart.device.svg.SVGInteractiveRenderer groupPrimitive
> WARNING: !exception.missing.component.interaction!
> 07-12-2011 09:40:50
> org.eclipse.birt.chart.device.svg.SVGInteractiveRenderer ungroupPrimitive
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> any ideas?
Re: Warnings when rendering chart to svg [message #762876 is a reply to message #762847] |
Thu, 08 December 2011 18:46 |
You get those warnings when you have chart interactivity features in the
chart model and you do not specify a handler for them. If you use a
show tooltip on the chart is that working?
Jason
On 12/8/2011 12:41 PM, js wrote:
> I am using the chart engine. Specifying the option below removes the
> warnings but is it good to just ignore those warnings? It seems that
> specifying the option does not solve the problem instead its simply not
> reported.
> "Jason Weathersby" wrote in message news:jbococ$p2r$1@news.eclipse.org...
> Jason
>> warnings:
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> any ideas?
FUDForum. Page generated in 0.03640 seconds
