Home » Archived » BIRT » IRunTask run output to a database
IRunTask run output to a database [message #761538] |
Tue, 06 December 2011 16:07 |
Peter Cliff Messages: 14 Registered: December 2011 Location: South West England |
Folks,
I'm trying to work out the best way to store the output of an IRunTask (the reportdocument) to a database and I'm a little confused...
IRunTask supports a String parameter which saves to a file named in that String, or it Supports an IDocArchiveWriter - the documentation for which is not clear - it states, for example, that this "Writer" is for "reading"...
Is there somewhere I can go to find information on IDocArchiveWriter (I've tried the Integrating and Extending book, this forum and the BIRT documentation to no avail) or does anyone have any other pointers that would, for example, enable me to send the output of the RunTask to a stream? (I'm considering changing the BIRT code at the moment!)
I could use a temporary file, but it seems clunky to save the file, only to read it again...
Any ideas would be gratefully received!
Pete
Re: IRunTask run output to a database [message #761587 is a reply to message #761538] |
Tue, 06 December 2011 17:35 |
Pete,
I do not have an example of this, but there are two interfaces for
writting/reading a rptdocument. IDocArchiveWriter, and
IDocArchiveReader. If you write a specialized writer most of the time
you will need to specify a specialized reader. In your case I assume
you will use the input stream to open the report document once it is
generated? BIRT supplies FileArchiveWriter(/Reader) and a
FolderArchiveWriter(Reader) classes that you could use as examples to
add your code to write to the db. I think this would be very interesting
to do. If you need some help with it let me know.
Jason
On 12/6/2011 11:07 AM, Peter Cliff wrote:
> Folks,
> "reading"...
> to read it again...
> Pete
Re: IRunTask run output to a database [message #765246 is a reply to message #765207] |
Tue, 13 December 2011 17:30 |
Peter
Is anything being written? Do you get the /design stream, etc
Jason
On 12/13/2011 11:11 AM, Peter Cliff wrote:
> I think I've made some progress... I've got a IDocArchiveWriter that
> outputs the individual streams to the database (via JDBC & Blob).
> Now I'm trying to verify if the data written is correct and have started
> putting together an IDocArchiveReader. I can get so far with this, but
> it keeps falling over with an uncaught EOFException when reading the
> /core stream. Looking in the database, /core is indeed empty.
> So my question is this - should I be seeing anything in the /core stream
> (hopefully that makes some sense!) and if not why does everything stall
> when it cannot find anything there?
> Pete
Re: IRunTask run output to a database [message #765785 is a reply to message #765521] |
Wed, 14 December 2011 17:19 |
I think I've hit a wall. I'm going to describe that wall here in the hope it either clarifies things for me or strikes a chord with someone and they say "actually, you can do it like this!"...
BIRT (using IDocArchiveWriter) seems to want (if my interpretation of the relevant interfaces/abstract classes is correct) to be able to open and non-sequencially write to multiple output streams at once. (In practice I'm not sure it does use the random access of the API, but it is there all the same). When writing blobs to Oracle you have to get the stream, write the data and then commit. I do not think it is possible to (safely) open another stream with the same connection when one is open.
I have implemented an IDocArchiveWriter, along with an associated RAOutputStream, where the Oracle connection belongs to the OutputStream and maintains the stream, etc. and the commit is called when IDocArchiveWriter is closed using a similar mechanism to that found in FileArchiveWriter. This works, but it requires a number of open connections to the database which is fairly expensive. Further, BIRT appears to always be calling write(int b), and I'm keeping it simple in this experiment I've not yet implemented buffering. As you'd expect this gets pretty slow writing a byte at a time to the database... (Though the data there now looks correct at least!)
So that leads to buffering and here I looked at the RAStreamBuffer classes which use buffer to memory and then to a RandomAccessFile and here I get confused trying work out how I might implement RandomAccessFile-like functionality to Oracle BLOBs.
Which brings us full circle. Perhaps the most straightforward way of doing this is to simply use either FileArchiveWriter or FolderArchiveWriter, "buffer" the file to disk, and when complete write the BIRT streams (as BLOBs) to Oracle sequencially. This feels wrong - I'd prefer to be able to stream direct to the database - but I'm not sure BIRT's expectations are compatible with Oracle's and being the man in the middle is proving tricky!
I could, possibly, create a IDocArchiveReader to make direct reads from the database possible rather than reverse the process on reading (extract BLOBs to disk and use FolderArchiveReader).
There you have it! Thoughts, consolation and ideas most welcome!
[Updated on: Wed, 14 December 2011 17:26] Report message to a moderator
Re: IRunTask run output to a database [message #765816 is a reply to message #765785] |
Wed, 14 December 2011 18:05 |
Peter,
I know creating the file and then writing to Oracle feels wrong, but it
may end up being faster. If you write the file to a tmp, then commit it
to Oracle and then delete it. Any chance you can open a bugzilla entry
for this, because this has been asked for many times. I want to have a
look at it using MySQL and see if I get the same results. Any chance
you can share what you have so far?
Jason
> and they say "actually, you can do it like this!"... :)
> BIRT (using IDocArchiveWriter) seems to want to be able to open and
> write the data and then commit. I do not think it is possible to open
> gets pretty slow as writing a byte at a time to the database... :)
> in the middle is proving tricky! :)
> There you have it! Thoughts, consolation and ideas most welcome! :)
Re: IRunTask run output to a database [message #766903 is a reply to message #766744] |
Fri, 16 December 2011 16:10 |
Sounds good. If you can maybe you and I can do a skype session to look
it over.
On 12/16/2011 5:49 AM, Peter Cliff wrote:
> Hi Jason,
> I've asked if it is OK to share the code. I'm in a new job and I'm
> unsure of the policies here.
> I'll let you know!
> Pete
Re: IRunTask run output to a database [message #767539 is a reply to message #766903] |
Sun, 18 December 2011 08:58 |
przemyslaw.bech Messages: 3 Registered: December 2011 |
Hi All,
I was thinking aboute moving from jasper to birt but after seeing this topic I dont think I'll use birt. Such a simple thing, as beeing able to provide rptdocument as a stream, is not available here...
In every application we ware building we always store xml reports in db and load them when needed to run the report and print paginated results. With BIRT this basic scenerio seems unavailable.
I dont see any possibility to take rptdesign, xml file, as a stream, than create rptdocument object without saving it to file and than use it to generate paginated report. So I dont wont to store rptdocument neither in file nor in db, just as an intermediate object in seesion. Even if I generate rptdocument with designer I would like to be able to upload it to the application server and run it but I suppose its impossible without saving this file to a directory on server.
If I'm wrong please show short code sample.
[Updated on: Sun, 18 December 2011 09:28] Report message to a moderator
Re: IRunTask run output to a database [message #768108 is a reply to message #767539] |
Mon, 19 December 2011 15:36 |
przemyslaw.bech, I'm not sure I'm clear what it is you are trying to do, but it sounds like it would be possible and there is some confusion over "rptdocument".
In this thread, when I talk about a "rptdocument" I'm refering to the intermediary data file that is the result of compilation of a report design and the data. This "rptdocument" is then rendered to whatever format you want and the resultant file streamed or saved or thrown away as you please. I think you are confusing the output document with "rptdocument" (and who could blame you? The terminology is confusing!)
For what you are talking about, I see no reason why you could not use BIRT.
You could wrap your XML (sourced from the database) with Java objects that form the data source for the BIRT report and then when you run & render the report you can stream it directly to where ever you want.
This is the crux of my issue - a rendered report can be streamed, a "rptdocument" (pre-render) cannot.
So, assuming you have a fancy report design with XML hooked in somewhere a servlet that did something like this would do:
EngineConfig config = new EngineConfig();
// ... set some config options ...
ReportEngineFactory ref = new ReportEngineFactory();
IReportEngine engine = ref.createReportEngine( config );
// read the report design - could be from a db or where ever...
IReportRunnable design = engine.openReportDesign( designStream );
// set up render options - here a HTML output
IRenderOption opt = new HTMLRenderOption();
opt.setOutputStream( outputStream ); // any output stream - to the browser for ex.
IRunAndRenderTask task = engine.createRunAndRenderTask( design );
task.setRenderOption( opt );
task.run();
So don't give up on BIRT because I'm pretty sure it can do what you're after!
[Updated on: Mon, 19 December 2011 15:55] Report message to a moderator
Re: IRunTask run output to a database [message #778171 is a reply to message #766348] |
Wed, 11 January 2012 14:23 |
Hi Jason,
Happy New Year!
As requested, I'm attaching the IDocumentArchiveWriter to an Oracle database I've been working on. Hopefully this'll be helpful for you!
I've been using the following table for the tests:
CREATE TABLE "STREAMS" (
"ID" NUMBER NOT NULL,
"DOCID" NUMBER,
"PATH" VARCHAR2(1024),
"DATA" BLOB
CREATE SEQUENCE "STREAM_ID_SEQ" START WITH 1 INCREMENT BY 1
I've also attached the test design I've been using.
This version of the code runs slowly (I think because it doesn't buffer writes) and there are a couple of exceptions being thrown.
Some of the data going into the database looks fine - the design is there for example, but as mentioned in a previous post, a large number of the document streams appear to be missing...
Let me know how your own experiments with it go! Should be simple enough to migrate to MySQL as it uses JDBC but you'll probably need to change the sequence bit - MySQL has auto-increment I think?
[Updated on: Wed, 11 January 2012 14:24] Report message to a moderator
Re: IRunTask run output to a database [message #778406 is a reply to message #778171] |
Wed, 11 January 2012 18:35 |
Thanks Peter
On 1/11/2012 9:23 AM, Peter Cliff wrote:
> Hi Jason,
> Happy New Year!
> "DOCID" NUMBER,
> "PATH" VARCHAR(1024),
> "DATA" BLOB
Re: IRunTask run output to a database [message #909195 is a reply to message #761538] |
Thu, 06 September 2012 18:05 |
Madhav Suram Messages: 10 Registered: August 2011 |
Hi Peter, Sam,
We have a requirement to save the generated reports into the DB and it was a simple task for PDF, PPT and XLS formats. For HTML it has the complexities of the images not present in the same file as the content. Hence only for HTML, we plan to save the .rptdocument created using IRunTask and then at the time of "download" plan to run this through IRenderTask just like how you mentioned in your earlier post.
Following your experiences, I have written the output to a temporary physical file and then saving that into the DB. And in the return too, fetch the blob data from DB and write into a temporary physical file which gets passed onto IRenderTask. When I try to save the .rptdocument into the DB, the way I'm doing it, doesn't seem to be saving it right into the DB. Is it possible for you to share the code snippet on how you read the file and save into DB and fetch and write into a temporary file?
(http://www.eclipse.org/forums/index.php/t/371194/)
Thanks & Regards,
Madhav
Current Time: Fri Apr 26 03:58:03 GMT 2024
Powered by FUDForum. Page generated in 0.05588 seconds
